Training Status??? (IV)
#5101
Rides too much bike
Quoted: 232 Post(s)
@PepeM I will give you my perspective as a "break rider". I think that we fall into more than one category. One is the long distance, the other is the short distance and both require slightly different profiles. A long break rider typically is someone who does better over long period, and is able to do more repeated efforts. A short break rider tends to be someone who has better overall power.
For me I know that I do better in longer breaks. My 5 minute power is my true strength, along with a pretty good 20 minute. My 1 minute is atrocious apparently and might explain why I don't do well in thing like 3 lap to go breaks or anything that is short but super fast.
YMMV
YMMV
#5102
I honestly think the trick with being a break rider isn't about W/kg at different durations as it is picking the right moment. You can beat yourself into the ground trying to get something established for 3/4 of the race, only to fail to go with the decisive move when it happens. Okay, power can tell you something about your chances in a solo break - my W/kg for 20' is okay, probably around 4.7 at this point when I'm fresh. But that's less than 270. Not a lot to work with when solo, even with a good Cda. But that doesn't rule out breaks, it just means I really need some help so I can go over during my pulls and recover in the draft. Though hey, who knows, it could even work given the right circumstances. Breaks generally don't stick because they're collectively stronger than the rest of the field, they stick because they've got a gap and more strength among the riders committed to working the break than those committed to chasing it down. Enough disorder in the peloton and even puny li'l me could ride away solo. I'm not holding my breath, though.
#5103
**** that
Quoted: 1099 Post(s)
Liked 104 Times
I thought that too, until I started winning field sprints.
That made me want to win a field sprint really bad, so I did!
#5104
Answer, right now, is that my sprinting technique sucks. Need to work on that but once I get better at it I agree with you that the only way I'll find out is by giving it a try. But yes, every time I try to sprint I just either wobble or my butt ends up back on my saddle. Just can't seem to put the power down.
#5105
**** that
Liked 104 Times
Therein lies the problem, doesn't it?
Look up "form sprints", and try those. Practice the motions over and over again.
Another thing about sprinting is when you're really trying to sprint, literally try to rip the bars off. Try to break the bike with your sprint. CDR has written books on the subject, I'm sure he can add to this!
As a side-note, I gained 200w in my sprint when I switched from (old, loose) SPD cleats to (new, tight) Speedplays. It also took a lot of practice - working on form, working on power, etc.
Once you get all that down, then you have to work on doing it in a race - timing, tactics. That part makes sprint practice seem easy!
Also: my sprint power has me in the cat 3 column, I'm certainly not a "sprinter" by power profile. I just like to do them.
#5107
In a way that's good - sounds like there is a lot to improve on, and it's mostly around sprint form.
I am aware of the importance of timing and positioning, but that seems even harder to figure out. Still trying to but there is a lot of improvement to be made. The one time I felt I was well positioned we ran into some lapped riders occupying the middle of the road and I had to take the wide lane around them, which made me lose my wheel.
In summary, I'll try to win the sprint out of a breakaway tonight.
#5108
**** that
Liked 104 Times
I have done some form sprints in the past. Really need to get more of that done. I also do remember doing better when holding really tight to the bars, but I forget to do that most of the time. Wish I didn't read about the SPD cleats as that's what I have right now, don't need upgrade ideas lurking in my head right now!
Also mine were just really loose (had some give when pulling up).
Anyway good luck!
#5109
ouch, in an effort to avoid thunderstorms that aren't seeming to materialize, i did a zwift race in my basement. avg 231w (NP 234) for 55 mins. that was toasty
#5110
more 1' on off efforts today. wanted to do a second workout after work, but i'm pretty sleepy and taking a nap sounds more appealing.
#5112
Quoted: 2953 Post(s)
Liked 3,106 Times
Speaking of sprints, I did more drag race sprints this morning before work. They hurt, but they're over quickly.
#5114
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2780 Post(s)
Liked 3,371 Times
Kicked down a hard one this morning:
48.42 mi w 3.5k elevation in 2.4 hrs, good for 19.9 mph on 215w AP/235w NP
Up next: eating while I try not to pass out at my desk
"Your beauty is an aeroplane;
#5115
Thunderstorms held off yesterday evening, so I went and did 7x2' repeats. Goal being repeatability rather than max power, so I targeted 350W for the first six, only went bonkers on the last one. 389 for the last one... makes me think next time I should shoot for 360 or 370, if I had that much left.
#5116
Did none of those. Largest field I've ever seen last night and also the fastest race. Tried to shake things up a bit mid-race but nothing materialized. Dropped into the bunch a bit to rest and then got stuck in there. With five laps or so left I saw the winning move go and it was clear that was the good one but I just couldn't find a way to move up, so I didn't. I don't really get why no one who was better positioned went with it, but I guess that's what makes it a winning move as opposed to another one that gets caught. Then the last two laps I couldn't move up either, so I rolled in with the pack. Sucks when you leave with a bit something extra to give but don't get the chance. I guess 'moving up' needs to be added to the long list of things I need to learn. NP was 276 for a 1.10 IF, so maybe I'm fooling myself thinking I could have done much. But I wanted to try, darn it!
#5119
Rides too much bike
Quoted: 232 Post(s)
Been so long since I have done 3X20s . They were both glorious and horrible. I ended up far closer to Z4 than SS. Which is good. But they felt bad. I am confused.
I guess this means I can still ride breakaways.
#5120
Liked 3,106 Times
#5121
Liked 3,106 Times
Had a somewhat heated political/philosophical argument with my training partner on what was supposed to be a tempo ride this morning. Came within a few watts of my 30' best.
#5123
**** that
Liked 104 Times
Asked someone else today (at work) who they voted for, they refused to talk about it.. probably smart! I'm not that smart tho.
#5124
**** that
Liked 104 Times
Did the training crit yesterday - got there with literally three minutes until roll out, clipped in just as the pack was rolling out and caught on to race (no numbers required, I paid later, they were cool with it).
Basically just attacked a lot. Never got away.
Came down to a field sprint, which I attacked about 800m out. Unfortunately about 30m too soon... but it was really good training!
134 TSS for the 1:08 race, 269w AP/325w NP (way higher than normal). Either my pwoermeter is broken or I got stronger recently. Or I just tried harder than usual.
