Retro roadies- old frames with STI's or Ergos
#5201
Quoted: 7378 Post(s)
Liked 2,534 Times
It occurs to me that modifying the frame in a drastic way would solve the problem, but it could be hard, and it seems risky. Either crush the ends of the stay near where it meets the dropout or put two bends in the right stays so that they flare out and then back in at a better angle.
This is a picture from above of my Lemond Ti bike. The stays swing out and then the dropouts are attached in parallel fashion.
The frame is from about 1994, and it was easy to put in a 10-speed rear wheel. The wheel fits perfectly and precisely and easily.
#5202
Bikes: 84 Coppi - 94 Hujsak - 82 Colnago Superissimo - 78 Ciöcc - 70's Galmozzi - 73 Lambert - 78 Motobecane Grand Record - 87 Peugeot Triathlon - 66 Peugeot H-40 - 78 Peugeot U08 - 85 Raleigh C-40 - 82 miyata 310 - 82 Univega - 85 Sterling SIS Mixte
Quoted: 39 Post(s)
Liked 42 Times
#5203
Bikes: 1981 Bianchi Limited 650B conversion (sold), 1985(?) Guerciotti retro-roadie, 2018 Specialized Allez Sprint, 2012 Specialized Crux, mid 80's Focus MB-400
Quoted: 67 Post(s)
Do you want to be able to use the smallest cog? If not, you could try using an 11-to-whatever 9 or 10 speed cassette while setting your high gear limit stop on the rear derailleur to prevent shifting onto the 11 tooth cog.
#5204
Liked 2,534 Times
@peugeot mongrel, good question. No, and I will.
Thank you for the idea, @rowebr. I guess it might be worth sacrificing a gear. 11t cogs are dumb, anyway.
#5205
Quoted: 378 Post(s)
Liked 1,412 Times
Not STI/Ergo, but 7800 shifters are new, just traditional.
56cm frame/fork, Shimano 600EX headset.
FSA SL-K BB386 crankset/BB, Wellgo Optigo Magnesium pedals. SRAM PC1070 chain.
DA cassette, 6500 hubs, DTSwiss R585 rims, stainless spokes, Michelin Lithion 700x25's.
Nitto Young stem, Nitto Olympiade (B115-420) bars, Bontrager Gel wrap.
Gipiemme seatpost, Bontrager Inform RL saddle, Transit bag.
DA 7800 shifters, Shimano 5700 RD, FD on an Origin8 mount.
The black cage that comes on the silver 5700 RD was swapped with a silver cage from a black RD.
Jagwire cables/housing, Modolo Pro brake levers and Shimano 5700 NOS calipers.
I was looking for a little "lighter" look, so the cage is Elite Ciussi in lieu of a black carbon.
#5207
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
I have a couple of questions for people who have made this conversion. My 1971 Raleigh Super Course and my 1974 Raleigh International are made similarly, particularly where the chainstays meet the dropouts. The ends of the dropouts are close to each other and leave little room for cogs. I was unable to put a 7-speed freewheel in either, because the last cog would scrape the chain stay. Converting to a freehub with an 8- or 9- or 10-speed freehub looks dicey. Has anyone dealt with this, or does anyone have an idea?
Here are pictures shot from above showing the small clearance between the frame and a 6-speed freewheel. I'm currently using 6-speed freewheels on both.
Thank you for any help you can offer.
(This is on my Bianchi Sprint 76 that I cold-set to 130mm (using Sheldon Brown's "2x4 + a chair" method) and I'm running Campy Khamsin wheels w/a 9-speed cassette.)
#5208
I've done this before, it works. Jeunet required it on the front wheel to have clearance for the Suntour GPX hubs that were on there- the original hubs are amazingly low-profile. Makes getting the wheel in a bit harder as you have a loose washer in there and the axle spacing is a bit wider than before.
A more refined way is to re-space the axle. Cassette hubs are basically the same process as freewheel, although you don't always have to remove the cassette. Just remember to remove however much spacer from the NDS as you add to the DS. And then re-dish the wheel of course.
#5209
Other than Campy and Velo Orange, what Shimano friendly cranksets are folks using? I look at the 105, etc. and the spider looks so thick and "heavy" or bulky. The Campy ones look better, aesthetically, but I've got Shimano stuff.
Suggestions appreciated.
#5211
If you want standard (130mm BCD) than almost any vintage square-taper Shimano is good and cheap. Compact? I dunno...I put a Tiagra on my wife's 80's Marinoni and while it's not "correct" it's shiny silver so it looks updated without being out of place. And it's Hollowtech II, which, while also not "correct" is my favourite crank interface.
#5212
Quoted: 110 Post(s)
Comes in standard and Compact varieties.
#5213
Still up in the air. I took off the Shimano Tiagra 10 speed "brifters" off my Straggler, along with the Tiagra rear derailleur. Have wheels with capability for either 9-10 speed cassette. Don't have a specific bike yet, although the Univega Gran Rally might be the one (it just looks so darned good as an all original 5 speed). Don't have a bb yet or a front derailleur. I own a pristine VO Grand Cru Mk II doublt (30-46), so was going to buy a bb for it if I decide to use it. Would use a Shiman CX70 fd simply because that's what's on the Straggler and I know it will work with the shifters and with the VO crankset.
What I'm actively looking for is a 50cm or so Centurion. There's a 21" locally, 1989 Le Mans purple smoke fade which has been butchered into a ss. Anyway, I just think the big black modern chainrings are a little bulky looking. Just trying to get options.
#5214
Quoted: 5 Post(s)
Quoted: 39 Post(s)
Liked 42 Times
#5216
Quoted: 4258 Post(s)
Liked 2,974 Times
I have an Arabesque, a 7400 and a 7700 all on old frames with 9 or 10 speed STIs. I have the early 9/10 speed 53/39 rings on all (before they started getting that thicker, webbed look). The flats on the spider of all Shimano cranks are all the same thickness, the spacing for the number of cogs comes from the rings (the small ring is offset). The earlier square taper cranks take a little longer BB, whatever spec is for the crank.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
#5217
Quoted: 3260 Post(s)
Liked 2,571 Times
Centurion ironman racing bike
[h=2]Centurion ironman racing bike - $100 (Norfolk)[/h]
condition: good
Centurion racing bike for sale great condition!
#5218
Quoted: 378 Post(s)
Liked 1,412 Times
What I'm actively looking for is a 50cm or so Centurion. (a sign of intelligence, of course)
I'd also say +1 to Falcon3, the 6500 crankset looks great on vintage bikes. Octalink BB's are plentiful.
#5219
@seypat - thanks so much for the offer, but I will pass on that one.
@RobbieTunes - It's not that they're not around, but either the wrong size or the wrong price.
#5220
Haven't used it but the holdsworth retro crank looks pretty nice.
Holdsworth Retro Crankset | Planet X
#5221
sorry for the hazy pic, grease on my phone lens or something.
but here is the run-down on this one that just knocked my socks off today after the first ride. its a modification to an earlier build but..
88 Centurion ironman "expert" frame
6500 brakes/brifters/FD
7400 crankset
XTR RD
116 link KHS chain
11-34t 9speed SRAM cassette (cant see in the pic, but the interior is red and matches the frame.. sweet)
7400 crankset
XTR RD
116 link KHS chain
#5222
Quoted: 1625 Post(s)
Liked 2,686 Times
7400 crankset
XTR RD
116 link KHS chain
7400 crankset
XTR RD
116 link KHS chain
#5223
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 541 Post(s)
Liked 1,042 Times
Parts Bin Kabuki Super Speed
I counted parts from at least 9 different bikes, not including a few parts that were new, so had never been on a bike before. The only things left from the original Kabuki frame are the fork and headset, downtube cable stop, and seat post. I used Testors Gloss Sunburst to touch up the many scrapes on the frame. I had a triple crank, but the brifter is a double, so I adjusted it to the outer two (50&40) rings. NW Ohio is flat, but if I need lower gears, I can readjust to shift the inner (30&40) rings. There is a lot of clearance, so I could put bigger tires on and use it as a gravel bike. It weighs 26 lbs. using the bathroom scale, vs. 30+ as original. Some of the parts were acquired at garage sales, some are take-offs from other bikes, and a couple came from BOC II.
Parts list:
Shimano 105 8 speed brifters, $5 antiques mall score
Shimano Rapid Rise rear derailleur, on clearance a Nashbar a few years ago
Shimano crappy front derailleur, scavenged off a cheap MTB
SRAM 11-30 8 speed cassette, Nashbar clearance sale
Alex DA16 wheels, $20 garage sale score
Bianchi stem, BOC II. There was no bolt, so I adapted a seatpost binder to fit.
Modelo bars, used at LBS
Vitoria Zafrio tires, bought for another bike
Shimano cranks came from another bike when I switched to a Biopace crank
Crank spindle from BOC II. It formerly had cottered cranks.
Parts list:
#5224
Aspiring curmudgeon
Bikes: Guerciotti, Serotta, Gaulzetti
Quoted: 111 Post(s)
Liked 26 Times
I bet you get going downhill real fast in that 52-11 combo @jetboy. What is that, like 125 gear inches?! Nice build.
"Party on comrades" -- Lenin, probably
#5225
its sunny today in the bay area! but here it is in the sun: a bit clearer-
and yes, 53 -11 is ridiculous and basically unusable by me unless I am already going downhill... though I got pretty close on the flats in oakland when I opened it up to see how it would go- for all of like 10 seconds before I faded. I am still pretty weak and trying to train up.
i made it for the santa cruz mountain ride we have coming up. hopefully will be able to handle it all. and yes, the seat was too loose and got pushed to the back. got to tighten that.
