Racer Tech Thread
#5277
Bikes: 1979 Raleigh Team 753
Quoted: 3377 Post(s)
Liked 371 Times
Agreed.
Now with some frames having empty BB shells (PF30) and other having threads even that is kinda hard to measure as the frame can take some of the weight. Although the threads take more weight on both parts frame and cups usually.
Any comments on pedal spindle width?
#5278
Quoted: 243 Post(s)
Solution looking for a problem in your, puppy's, case. If his foot was that broad or his fit had issues that require it you would have been well aware many years ago.
#5279
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
If you have big feet (I wear 46s) you can have issues with the heel striking the chainstays. It's very much frame-dependant; I have no issues with my new Allez Sprint frameset but have worn spots on my Look 585's stays even though the chainstays are longer on the Look.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#5280
Liked 371 Times
Coach added spacers for a PM and he liked it. I didn't think it was a big feet thing. Coach and puppy are 44.
I was wondering if it did a q-factor thing. I guess the best way to deal with that is get bigger q-factor cranks, but if you want to stick with a brand, I'm not aware of that option.
On Q-factor I always thought less was better. I don't know racers that care. I'm just ordering and it is an option, so I thought I'd ask.
#5281
Quoted: 243 Post(s)
Of the physiological issues that could incur a need for longer pedal spindles. A national level U23 rider is an unlikely candidate for most. At that level all solutions to problems are on the table because of the level of expertise being applied. If his coach/fitter/??? says they are needed for that frame, buy the longer spindle version. Otherwise it's just as I said.
#5282
Nonsense
Bikes: Affirmative
Quoted: 880 Post(s)
Liked 541 Times
A lot of it is just frame geometry. I whacked my left heel on the seatstay of my Caad 9 so often that I actually wore a hole into it. Happens sometimes on my Tarmac, happens just about never on my Felt AR.
#5284
Quoted: 693 Post(s)
chainring choice is definitely a factor; there have been stupid-light chainrings which suck (an s-works model stands out from about 8 or 9 years ago as exemplifying this), but it is hard to standardize for that as some cranksets *require* use of a particular chainring (eg DA 9000).
specialized gen III carbon arms (incl spindle) + mandatory spacers/lock ring / dust cap come to 338g (actual).
hollowgram aluminum arms (SiSL2) + spindle + spacers = 375g (actual).
same spindle width and diameter, same arm length.
that's not much of a difference, but it IS an apples-to-apples difference, and it's not in favor of the one who claimed to be lightest.
one can use the ultralight spiderring (53/39) for the cannondale at a stated 175g; a specialized carbon spider + dura ace rings & bolts (which are certainly not light but are notably better) = 200g.
that brings the hollowgram to within 12g, but a set of lightweight rings on the specialized instead of the DA rings would increase that difference.
NBD, except that cannondale has claimed the 'lightest crankset' thing for a long time.
of course, some may prefer a relatively light set of aluminum cranks to carbon cranks. i personally don't have any issue (riding OR crashing!) carbon cranks, and i use carbon cranks off-road (MTB & CX), too.
#5285
Bikes: Canyon Aeroad, Ridley Fenix
Quoted: 22 Post(s)
Regarding longer spindles. A small part of this book (https://www.bloomsbury.com/uk/bike-fit-9781408190302/ by Team Sky's fitter) talks about how in today's state of the art bike fit science, the "stance width" (q-factor, essentially) is a very ill-understood and highly overlooked portion of a bike fit. IIRC, he essentially says that if you have duck feet and if you have crank rub, then consider getting longer spindles
#5286
Quoted: 693 Post(s)
you'll rarely find someone doing apples-to-apples comparisons with ACTUAL weights.
spacers add up to a gram or 3 at the most, so that's not a huge issue either.
#5287
Quoted: 693 Post(s)
sram MTB was that way until recently (156 & 168Q), but with the move to BOOST the narrower Q cranks have gone away. not sure if they ever had different Q factors on the road side.
what pedals does your boy prefer?
i think speedplay offers different axles as an option. LOOK does not (or did not), but you could buy aftermarket spindles (they don't say they are LOOK compatible as a protective measure) to allow for a wider stance. you could also buy aftermarket Ti spindles the same way.
come to think of it, there was a time i was experimenting with different spindle widths, and i think i may still have a set of longer LOOK spindles if you need them. it's a pretty easy swap.
Edit to add: Pretty sure DA pedals come in different widths, too.
#5288
Quoted: 693 Post(s)
* the Q-factor of the crank
* how much and how soon the chain stay flares out
* position of cleats on rider's shoes
* float (more float = more chance of this happening)
* whether the rider pedals "heels-in"
* the shoe size of the rider; bigger shoes = more chance of rub
this has been more an issue on the MTB side in recent years as width at the rear hub is wider than for road and frame manufacturers have been adjusting the width of the stays to accommodate wider and wider tires.
147Q is possible on a road bike (that's for DA; specialized road cranks are narrower @ <138Q). the specialized MTB crank, on the other hand is 167Q. go check out Q for fat bikes!
#5289
Quoted: 243 Post(s)
TKP, this ties in with your CAAD in what sounds like poor bike design work to fit some shortsighted ideal of functionality. The whole compact geo/aero thing has produced a fair amount of bikes that aren't good at being bikes. I can't say what your issue was so don't take issue with the duck foot mirror.
#5290
Liked 371 Times
Don't know. Never made a thing of it. He just rides what we get and if he thinks it is better - he goes faster.
Which is why I'm asking...
They do. Settled on Shimano when buying individual components.
#5291
Quoted: 693 Post(s)
some people can feel if their saddle is out of position by 2mm and others cannot; which camp does your boy fall in?
unless you are talking some extreme, the range of difference in Q factor is not very large, and odds are a wider stance may be noticed more for the fact that effective saddle height changed.
popular thinking is that narrower is preferable (and faster, aerodynamically), but there is no right answer for everyone.
people make a big deal about a change from 172.5 to 170 cranks (or even 167.5), but the changes are small and easily adapted to -- for MOST people.
bottom line: depending on what pedals your kid uses, you can adjust spindle length to change stance even if you can't get wider Q from the cranks. i tried to ask which pedals your boy uses, but you said you didn't know.
small changes in position *tend to* matter less because a rider is on and off the bike (in CX), there's suspension involves (MTB), people are in/out of the saddle more, etc. tends to fall more into noise during actual racing.
#5292
Quoted: 1853 Post(s)
Liked 680 Times
The other issue is the spider. It should be included, but Cannondale saves weight be marrying the spider and rings.
Also, if the difference is minor, one can add an extra pedal washer to increase the spacing. I do this on my right leg as my foot naturally angles out, meaning when pedaling, my heal angles in.
#5293
Nonsense
Bikes: Affirmative
Quoted: 880 Post(s)
Liked 541 Times
there are a few factors:
147Q is possible on a road bike (that's for specialized; i think shimano cranks are the same). the specialized MTB crank is 167Q. go check out Q for fat bikes!
#5296
Rides too much bike
Quoted: 232 Post(s)
Already have sung them praises to Mikey. Wonder if there is a reason why a bunch of us ride em ?
Side note: I believe that BB386 was designed to keep the same Q-factor as BB30 cranks. If you look at the differences between the cranks typically BB30 cranks flared outwards from the frame where BB386 typically were straight.
#5298
Quoted: 693 Post(s)
Q-factor applies to cranks, not bottom brackets or pedals. Q is measured as the distance from the outside of one arm @ the pedal to the outside of the other.
BB30, BSA and BB386 may affect crank options, and the chain stays of a bike may limit Q-factor (most commonly on MTBs these days); the BB itself does not have a Q-factor associated with it.
some wider bottom brackets will require crank arms with less flare/curvature in order to achieve a given Q than a narrower BB (e.g., BB30).
also, while pedal spindle width may contribute to a wider or narrower stance, that is technically a separate from Q.
Q + spindle length + cleat positioning all affect stance.
generally spacers between crank arm and pedal are viewed as undesirable, particularly for carbon cranks. it doesn't mean one won't get away with it, but they're not typically used. (by spacer i mean more than a thin washer used to protect the crank from the pedal.)
#5299
Quoted: 693 Post(s)
this usually isn't a problem on road bikes, but bikes with fatter tires (MTB -- and even moreso fat bikes) require wider stays and the width happens closer to the BB. you don't want too wide a stance, so crank manufacturers tread a line to be compatible with frames but not hitting the frame.
there are specs for all of this.
wider BBs necessitate that crank arms are more straight to achieve a narrow Q vs. a narrow BB (all else equal).
crank arm length comes into play, too; longer arms have a greater likelihood of hitting chainstays, and they are less tolerant of float in that the riders' heels has a greater chance of hitting the stay.
i think BB386 came about to offer larger bearings (diameter) spaced further apart (width) -- kind of a best-of-both-worlds for BB30 and 24mm bottom brackets.
#5300
Liked 371 Times
In the day I had three rings on the right of the tandem (Campy C-Record), none on the left. My spacing was 140 and that was long then. That was also the day of square tapered spindles and you could find spindles that would affect the Q, shift right or left and the BB I used had lock rings on both side of the cups so I could also adjust left and right about 3 threads or so.
