Addiction 2021.3
#5951
Silver Comet Fred
Likes For DougRNS:
#5952
Silver Comet Fred
#5953
Mostly Harmless
Bikes: Have two wheels
Liked 4,651 Times
Interesting experience on today's ride. Recall I still run Ultegra 6700 on my bikes. Also recall that the exposed parts of the shifters are notorious for rusting, and there is a bit of rust on mine.
When I started the ride, my inner paddle (to shift to a smaller cog in back) would sometimes just move but not shift, and sometimes would "catch" and shift properly. Oh crap. The outer shifter would shift crisply to the bigger cogs nice and crisply. So I am pretty sure the problem is NOT a fraying cable or a cable problem at all, but something in the shifter mechanism that is not engaging properly. I am not enough of an expert on the shifter innards/mechanism to make a definite diagnosis. Luckily, as the ride progressed, the weak "catch" or inability to shift at all became less frequent, and within 15 minutes it was working fine.
My suspicion is that whatever ratchet or other gizmo inside the shifter may have gotten stuck due to rust and lack of use (this is my first ride on the bike in 2 weeks), but I am torn whether to just leave it alone versus spray a bunch of WD40 and/or lube up into the mechanism to help clear out whatever the cause was.
Suggestions???
Suggestions???
#5954
Mostly Harmless
Liked 4,651 Times
Sometimes that happens because the original assembly lube has degraded and essentially gums up the mechanism. I usually spray some Clean Streak or similar degreaser into the shifter and then some wet spray lube. Work the shifters a bunch, while in the workstand. That often solves the problem. Assuming that's what the problem is.
#5955
Klaatu..Verata..Necktie?
Liked 12,427 Times
I've been finding that I spin >100 rpm a lot on my 80s bikes with 170mm cranks, vs 95-100 on the newer ones with 175s. That, and with fewer gears and DT shifters I tend to shift less often.
#5956
Mostly Harmless
Liked 4,651 Times
Sometimes the non-cycling world attempts to appropriate cycling with hilarious results. To wit, a $28,900 Louis Vuitton single speed bike that is probably less capable than anything from State:
https://theradavist.com/2021/08/__tr...Bkuqtqbtl52A8U
#5957
Mostly Harmless
Liked 4,651 Times
#5958
Silver Comet Fred
Revealing factoid:
one of my favorite albums.
Likes For DougRNS:
#5959
Liked 12,427 Times
#5960
Mostly Harmless
Liked 4,651 Times
#5961
Mostly Harmless
Liked 4,651 Times
It’s a good suggestion but the Habanero has external cables and setting up Di2 that way is fugly. I do plan to get a brand new full groupset next year, and my hope is the next-generation Shimano 12 speed Di2 will be available and also semi-wireless. That fits right into my plan. However I suspect delays and/or supply problems may be an issue.
#5962
Mostly Harmless
Liked 4,651 Times
#5963
Liked 12,427 Times
#5964
Mostly Harmless
Liked 4,651 Times
No shifters available?
#5965
Should Be More Popular
Liked 9,206 Times
#5966
Silver Comet Fred
#5968
cowboy, steel horse, etc
Bikes: everywhere
Liked 8,021 Times
Get a load of this abomination spotted at the Phillies game. Shame on you Yuengling.
#5969
Silver Comet Fred
#5970
Silver Comet Fred
#5971
Bikes: everywhere
Liked 8,021 Times
#5972
Bikes: everywhere
Liked 8,021 Times
#5973
VFL For Life
Bikes: Velo Volmobile
Liked 1,942 Times
#5974
Bikes: everywhere
Liked 8,021 Times
They got em in El Paso, still a bit of a drive for Yuenglings...
#5975
Bikes: everywhere
Liked 8,021 Times
Likes For LesterOfPuppets:
