ISO and for trade thread part 5
#5976
Liked 2,764 Times
If someone has been in there already there is a good chance the caged bearings were installed upside down.
Likes For curbtender:
#5977
Hi Doc, A quick search revealed: Tange-Seiki Levin CDS 1" Threaded Headset: 27.0mm Crown Race Chrome on the 365 Cycles Online Store for $20.98. It comes with 5/32 inch ball bearings. Do you think this is compatible?
Likes For rccardr:
#5978
Likes For rccardr:
#5979
Bikes: Motobecane C41, Matsu$hita Nashonaru
Liked 439 Times
These came with a set of damaged Mafac brake levers I got a few years back. The levers were shot and of no use, but I kept the clamps. If I remember correctly, they were using standard washers and hex nuts (I'm sure I have something that matches). I de-rusted them back then and they are in usable condition. Anyhow, since I won't be using any Mafac brake levers anytime soon, I thought someone might need these more. If someone has a downtube clamp for Suntour Power Shifters (LD-1500) and would like to trade, do let me know. Alternatively, yours for the cost of shipping. Please remember I'm based in the UK.
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x948/img_20230728_125303785_33cfe80211f089ea951f3523ddaa80ebb6d546c8.jpg)
Mafac brake lever clamps
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1290/img_20230728_125313473_d4706235c62a6c717f845f1a481c493fee20da6d.jpg)
#5980
is the power shifter band clamp different from the friction shifter band clamp?
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x901/img_20230728_174816290_065fe0993609f6efbc592302be2232321851329b.jpg)
#5981
Liked 2,003 Times
No, The first set of shifters have the correct band for the power shifters but are a bit different from the original in that the original did not have the cable stops. I think all three would suffice for a replacement though. HTH, Smiles, MH
#5982
Liked 439 Times
Likes For VintageSteelEU:
#5983
Suntour Power Shifters can't be used with just the usual downtube Campy standard shifter bosses or regular shifter clamps with such. The ratcheting mechanism won't engage, partly because the boss will be too short, partly because they require the boss to have a thick, round base to it. Have a look at this diagram. The cable guide doesn't do anything when it comes to the shifter mechanism. That round base firstly makes the boss good 2mm longer than usual and secondly I believe plays similar role to the thick inner washer found in regular friction shifters (which in normal friction shifters has a round hole and goes over the base of the downtube / shifter boss). So all depends on what that clamp looks under the shifter. It does look like the first on the left might have the correct construction whereas the other ones most likely don't.
#5984
And that when they do, the cup and cone rotate relative to each other?
And can he do simple maths - as the brinelled spots are about 16 degrees apart, and evenly spaced, you will get at most[1] 8 degrees of turn in either direction before the spots are again aligned.
[1] only if you get the cup and cone spots equidistant from each other when installing them in a frame with the fork pointed straight ahead.
Likes For oneclick:
#5985
What type of Power-Shifters do you have that does NOT have cable stops - every one of the Suntour ones in the bin here have them.
#5986
Liked 439 Times
The later ones, in the Sprint gruppo (mid-80's) don't have cable guides. And they don't need a clamp, work with standard braze-on shifter bosses. I think Dia-Compe makes a pretty faithful copy of them these days.
As for the earlier, 70's version, they don't really need the cable guides to work. So if someone misplaced those, the shifters most likely would still work just fine.
#5987
Yes there are other ratching-one-way-friction shifters, from Suntour and others, and some of them lack cable stops.
On Power-Shifters the cable stop is integral with the inner-most friction-plate; yes they'd work without them - if you hacksaw them off.
#5988
Liked 439 Times
On Power-Shifters (all of 'em that I've seen, stem-mount, thumbies and bar-cons included) there are cable stops.
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1754/img_20230730_203325658_2afcf69b5090111aa7fcfdce3e56b69a487c97b7.jpg)
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1325/img_20230730_203404353_6f615738ff423772f32949dec803197008392580.jpg)
#5989
@ JohnDThompson,
I did a quick search on Craig's List and called my LBS. No luck searching for a 1 inch (25.4mm) seatpost. I'll have to wait for a lucky opportunity.
#5990
Liked 2,764 Times
#5991
Likes For Schweinhund:
#5992
Edumacator
Liked 3,374 Times
Ebay has tons of choices. And cheap.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Likes For jdawginsc:
#5993
#5994
@JohnDThompson I have a couple of steel 25.4 seat posts, and possibly an aluminum one but no promises there.
Whatever actual shipping is.
#5995
Old fart
Liked 3,461 Times
![Smilie](images/smilies/smile.gif)
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/933x435/cup_remover_93e924175837788abc40ceacd7c833c5e2ea2467.jpg)
Likes For JohnDThompson:
#5997
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Liked 1,643 Times
....or just go to the hardware store and get a piece of 3/4" copper pipe and be done with it. The repurposed seat-post may be the 'preferred' DIY tool, and may last longer, but the copper will work just as well (and be easier to cut/bend). Copper is also softer, and so less likely to damage the cups as you bang them out (though damage from the seat-post tool is pretty unlikely, too).
Likes For ehcoplex:
#5998
Old fart
Liked 3,461 Times
#5999
Copper (pipe) is expensive, and pretty soft. I'm sure it works fine, I use a length of 1" copper pipe as my crown race driver. For a cup remover, I use a length of electrical "EMT", 3/4". Its very inexpensive, and harder than copper. Still, I need to dress the tines on the end, every once in a while, to clean them up so they get a good "bite" on the cup.
