#6226
Cantilever believer
This afternoon's project is another "get something off the back porch" affair, where a 30+ year old Roadmaster frame, some old Huffy coaster brake wheels, and assorted odd parts are now assembled into a "frankenbike" that won't win any beauty contests but should serve someone well as a work trade bike.
I'm not saying the frame is no-name steel, but I was able to cold set the rear triangle from 120 to 110 by hand without tools without pushing all that hard (and even overshot and had to hand-bend it back a bit). I swapped the stamped steel spot welded triple chainring for a single and added a basket to increase the usefulness. And made sure to adjust the message on the decals so as not to misrepresent its new status:
Likes For RCMoeur:
#6227
I want to re-cover a Vetta LiteGel seat. I've removed the original covering and looks to be some sort of faux leather (vinyl bonded to a cotton or poly blend). Anyone know of a suitable fabric to replace this?
Thanks,
DA
Thanks,
DA
#6228
Liked 2,175 Times
I have used real leather I picked up at Hobby Lobby about $20 for enough to cover at least six saddles. Smiles, MH
#6229
Bikes: Miyata 618 GT, Marinoni, Kestral 200, Soma double cross 2002 Trek 5200, KHS Flite, Koga Miyata, Schwinn Spitfire 5, Mondia Special, Univega Alpina, Miyata team Ti, Santa Cruz Highball, Waterford rs11
Liked 3,055 Times
I went to a local auto upholstery shop and picked up a nice scrap piece for one.
#6230
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Liked 498 Times
Wrenched the cranks off
But couldn’t wrench the pedals off the cranks
A little wrenching on the stuck stem- but mostly pounding on the stem bolt hoping to get it to move.
Now I’m debating- more time & money on this- or just get that slick Team Fuji an hour away….
#6231
that is one stuck stem! you can always cut it out but yeah- trouble and obviously destroy the stem.
#6232
Liked 4,321 Times
Took off the winter tires on my 1992 Trek 950 and cleaned up the bike. Snow and ice is a tough environment for any bike.
Likes For bikemig:
#6233
Liked 4,321 Times
#6234
Liked 2,326 Times
Got a flat on the car yesterday. 2" drywall screw. Pulled and plugged even though that approach is not recommended for radial tires. It worked to get dinner and drive it to the tire shop.
Decided to take a bike to ride back home while the car is being shoed. Pulled the Rockhopper down and change the fork to the original rigid fork and swapped the rear tire. Since the front had the fender mounted, I also mounted the rack and rear fender. It is back to commute or like I call it, the truck configuration. I know bad lighting but you get the concept. Rode it 6 miles home. Likely use it to pick up the car too.
04272023RockHopper on Flickr
#6235
buy my bikes
Liked 498 Times
Originally Posted by bikemig;[url=tel:22872836
22872836[/url]]That's such a pretty bike. I'd keep working at this. Earlier this year I picked up a 1970s SekineSHR with a stuck stem. Nice bike for its day with a double butted chrome moly triangle and decent quality parts. I picked it up for the velo cheapy contest. I rebuilt the bike but left the stem alone as it just wasn't worth my time for a $20 bike. Your bike is worth it though. This is the Sekine on my first trip on it. I sunk a total of $18 worth of parts into the bike bringing the total cost to $38. This will make a fine lock up bike,
For my stuck stem, I'm trying to cook up a way to start pulling on it. My thinking is to get the fork and stem under TENSION, and just increase the tension slowing over time. (Like pulling a car out of mud - long steady pull. Versus pulling out of sand with a quick kinetic snap.) -- and I got a rock up my rear fender last night ( I think it was a rock) and it pulled half the fender under the other half. So now I got to sort that out.
why? just why?
#6236
Liked 6,808 Times
These are the plugs you seek, they are truly self vulcanizing.
I have plugged 100's of tires with these, worked at a full service Chevron station back in the day, we used these and kept a lot of tires going in a very challenging part of town and never had a failure.
I have used them ever since with zero failures when the instructions are followed.
#6237
Liked 2,326 Times
[MENTION=425004]merziac[/MENTION] - Thanks, that is close to what I used. Part of a kit.
When I was in India, I fixed 4 flats in 1 week using the car jack to break the bead to patch internally. Seating the bead with an air supply from a hose that connected to a spark plug fitting, using the engine as a pump, was a real challenge. The Firestone tires bought through the embassy commissary just fell apart on the road. Had to use inner tubes to try to keep them inflated. This was on a trip from New Delhi to Agra.
#6238
Liked 6,808 Times
No blah, blah, blah, tire shops and companies condemn them because of an invented liability so they can sell tires instead.
The rep at the Chevron station had a test wheel and tire with 100 plugs in it including sidewall which is a no, no except emergencies.
He would put it on his car and take you for a test drive including freeway.
When we did replace tires that had been plugged with them, you could put a screwdriver through the loop on the inside and with a foot up on the machine it would take all your strength to pull it out of the tire, many would break without coming out even on thin bald tires.
Its amazing to me how unprepared so many people are, I carry plugs, flat fix and a mini compressor in all my cars, jump box and more on any trips as well.
Bikes too, I carry an inflator, mini pump, Silca, patch kit and tube most all of the time.
Likes For merziac:
#6239
I'm currently working on a Motobecane Mirage from the 1070's. Not sure the year because of mixed components when I got it. Paint is in great condition. When it is reassembled, I will have new gum-wall tires and Huret derailleurs. Then I will move on to a Grand Touring and a Grand Jubilee. Both have poor paint. I will strip them down to the frame and repaint.
Good luck on your project.
Likes For Mike.delaney601:
#6240
señor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,975 Times
I did a job I've never done before, twice over. So, after acquiring the biggest bike I've ever wanted to keep, I started feeling like two bikes in the stable were a little short. So I changed out two Cinelli stems for slightly longer versions. Without wanting to buy new $30 bar tape, I removed the old tape and brake lever on one side, Changed out the stem, and then reused the tape.
It's Fizik classic on both bikes, which I guess made it a lot easier than I expected. I used a sharpie to dot where the wraps come together. And then a little bit of acetone cleaned up the marks. Was kind of regretting doing this, but felt pretty blissful afterwards. Here's one of them...
#6241
buy my bikes
Liked 498 Times
Likes For mrv:
#6242
Bikes: Motobecane C41, Matsu$hita Nashonaru
Liked 443 Times
Stem is a different story though. I had one recently I couldn't remove, so just repacked the headset with grease and I'm happily riding the bicycle. In hope next time I get back to it, it will be less stubborn.
Likes For VintageSteelEU:
#6243
Cantilever believer
This afternoon I'm experimenting with the few "project" bikes remaining on the back porch. And after I got an old 1990 silver/blue Trek 930 on the stand, I was pondering about how best to, um... X-Press myself.
Edit: the bike was so grubby I stripped the bike down to bare frame (7.5 lbs F/F/HS) and carefully put the complete black X-1 group away for some serious future cleaning.
Likes For RCMoeur:
#6244
Cantilever believer
Is that a XCD crank?
#6245
buy my bikes
Liked 498 Times
Originally Posted by RCMoeur;[url=tel:22873578
22873578[/url]]"Because we're here, lad."
this is the low end Panasonic Mountain Cat 3500
when I got it on BF last year, I believe it was the original hardware- non consumable stuff
I’ve gotten lighter wheels, seatpost handlebars.
https://cimg6.ibsrv.net/gimg/bikefor...d5bcf2780.jpeg
#6246
Finally I found a pair of Tricolor brake levers, they were mounted to the Mercian and the bars are taped. I also tried my hand at some touch up. Worked out good, I would say that it fit under the 3ft rule, barely can tell. Invisible at 5ft. Good practice, but I couldn't find right brush. The brush I used, Windsor-Newton 000, was way to small to maintain a wet tip.
Probably can't tell but the blemish on the headtube lug is now disappeared. The others not bad. While I had the paint out I panto the branding on the Nitto stem.
Likes For Mr. 66:
#6247
KHS Flite
I've started putting together the KHS Flite 300 I purchased (frameset) last year. It's a 2000 steel frame. I have most of the parts I need, and am looking for some thumbies to mount 7-speed indexing dt shifters to and a nice set of city bars.
DA
DA
#6248
Bikes: 2024 A Homer Hilsen, 1987 Mercian Pro, 1985 Shogun 500, early '70s Falcon San Remo, 1972 Peugeot PX-10, 1972 Schwinn Paramount P13-9, 1971 Raleigh International, 1971 Peugeot PX-10, 1970 Raleigh Professional Mk1
Liked 3,569 Times
Replaced the Delrin washers on the Mk I’s Mafac Competitions with spiffy brass ones. The bushings are already brass, or I would have done those as well.
2024 A Homer Hilsen, 1987 Mercian Pro, 1985 Shogun 500, 197? Falcon San Remo, 1972 Peugeot PX-10, 1972 Schwinn Paramount P13-9, 1971 Peugeot PX-10, 1971 Raleigh International, 1970 Raleigh Professional Mark I
Likes For ascherer:
#6249
Bikes: Teledyne Titan, Bob Jackson Audax Club, Bob Jackson World Tour, AlAn Record Ergal, 3Rensho Katana.
Liked 623 Times
I have been away for a few years, starting a new project so I'm back..
A 53 Cm Stratos NJS Keirin frame spread to accept a Shimano Alfine 11 speed hub (32 hole) with Jtek bar end shifter, Dura Ace 7600 track hub (28 hole), Ambrosio Excellight rims, Campagnolo Record Pista crank + bottom bracket and yes the chain line works, NJS Nitto bars, stem, and seat post. (TBD) braze on bits to accommodate cantilever CX brakes.
All parts are on hand and have been for a while. I have one last project to get out of the way before I start this, its for the big bike, should be wrapped up by the middle of May.
Untitled by nemosengineer, on Flickr
: Mike
: Mike
Booyah Hubba-Hubba!!!
#6250
Liked 512 Times
Rebuilt a C'dale Slice yesterday...new cockpit toys, rear saddle cages, replaced all cables/housings, etc. Came out nice.
No name adult tricycle that hadn't been used in years...covered in cob webs and spider egg nests...ick...replaced tubes, rim strips and the usual tuneup stuff. Always funny to adjust the leather band style rear brake...still working well.
