Retro roadies- old frames with STI's or Ergos
#6652
My son loves his dt shifters and doesn't want to upgrade or change. I guess it's all personal choice. I love not needing to take my hand off the bars.
#6653
Quoted: 7412 Post(s)
Liked 2,612 Times
Why can't I see @kingston's picture while others can?
#6654
Jedi Master
#6655
Quoted: 140 Post(s)
By quoting his message I can see he is attempting to hotlink from his Google user account, I don't think Google's storage has global permissions across the Internets. Not the best method for sharing stuff publicly.
#6656
Jedi Master
Perhaps not the most reliable method, but it's definitely the easiest. It only takes a few clicks since photos from my phone automatically synch to google photos. I'll see if I can diagnose the problem since I have dozens of photos posted from the same shared album.
#6657
Quoted: 140 Post(s)
![Big Grin](images/smilies/biggrin.gif)
#6658
Quoted: 4281 Post(s)
Liked 3,007 Times
I saw it when it was first posted, but now I no longer can.
#6659
Extraordinary Magnitude
Quoted: 2612 Post(s)
Liked 1,733 Times
I haven't figured out how to get the Google photos to show- I can see them when I post 'em... no one else can.
Commence to jigglin’ huh?!?!
#6661
Bikes: Some old steel, some new steel
Quoted: 40 Post(s)
Liked 6 Times
I've had trouble with this before too. Is the photo in a shared album? It must be "shared" so that other have access to it. Further, there is a difference between sharing the link to the photo address with the share button (the sort of less-than looking symbol) and right clicking on the photo itself to get the "image address." I always forget which is the right way and it takes a couple tries to get it.
#6662
Jedi Master
I changed some google photo settings and updated the URL for the photo in post 6656. I couldn't see the other one when I was logged into chrome as a guest, but I can see it now. Hopefully that fixes it.
#6664
Liked 3,007 Times
#6666
Bikes: 1981 Bianchi Limited 650B conversion (sold), 1985(?) Guerciotti retro-roadie, 2018 Specialized Allez Sprint, 2012 Specialized Crux, mid 80's Focus MB-400
Quoted: 67 Post(s)
Time to re-post my Guerciotti because I upgraded from a 50-34 crankset to the 52-36 ![lol](images/smilies/lol.gif)
I also changed the saddle and bar wrap to black, which looks better than the yellow combo I first built it with.
![](https://c1.staticflickr.com/5/4558/37846965514_4e66fdb976_b_d.jpg)
Likes For rowebr:
#6667
Bikes: 1994 specialized Allez with Sram 10 speed groupset
Quoted: 15 Post(s)
Finally pics of my bike
https://www.flickr.com/photos/138785247@N04/
Here is the link to my bike its a 94 specialized road bike. I upgraded the bike a little bit.I was given the 10 speed sram force shifters, Sram force front and rear derailleur and 2 force cassettes 12-28 and a 12-25t cassette for free... I have a aluminium front fork, the seat is a vader saddle that is very comfortable. I took a gamble on this 12 dollar amazon saddle... The brakes are radius, the crank is a shimano ultegra, the wheels are mismatch (until Christmas) with a 23mm tire in the front and a 25mm tire in the rear I love the combo of sizes. I also have a cheap bike computer with a cadence and heart rate sensor. The way it sits it is 21 lbs, not to bad for an older steel bike.
The blue schwinn sprint the back ground will be my winter project.(the guest bike) You can see the 10 speed shimano 105 shifter and cables on the table, this is the winter project. Another Thrift store find for 18 dollars. The bike does not have a scratch on it, the bike was completely original.
#6668
I can understand not being enthused with a compact crankset. Just doesn't add anything if you manage well enough on hills.
I like brifters but I guess that's just different folks.
Bike looks great!
Bike looks great!
#6669
Running on plenty
Recent change to the Gazelle AB. SRAM Force, Cinelli XA/64-42, Thomson Elite and self-built wheels with Ultegra 6500:
![](https://i.imgur.com/HIDgDq7.jpg)
New build. Paconi SLX New, full 5700 105 incl. hubs, SR Royal stem, slight rando bend bars, temporary pedals. Technically this was built for STI/ergo, as it has cable guides on the side of the HT lug:
![](https://i.imgur.com/OQa5JLA.jpg)
#6670
Options for 120mm Spacing
Hi all,
I have a 1979 TREK which currently has a 120mm dropout spacing. I have found a shop which I am confident can re-space/re-align the frame and dropouts but need some advise on how far to go. I realize that the further you spread the higher the risk of damaging the frame (Columbus tubing in this case). My goal is to accommodate a rear wheel large enough to use Brifters (STI's most likely). Obviously, the more gears the better in the rear and upfront I'd like a 2 ring, compact setup (50/34).
What do you guys suggest with regards to target spacing and groupset? Like I said, I am partial to Shimano STI's as I have used them for years on modern bikes but will consider other options that make sense.
#6671
enginerd
you can safely respace a steel frame from 120mm to 130mm to take modern 8/9/10/11spd wheels
#6672
Quoted: 1088 Post(s)
Liked 1,207 Times
Hi all,
#6673
If you're discussing your Trek 930 frame, a proper groupset, IMHO, would be an earlier (I prefer 9speed) Campy Ergo, or Shimano Dura Ace group.
At that point, a bigger issue than spacing becomes finding a "matching" brakeset to go with either of those groups, or pretty much any "modern" group. Your frame, unless previously modified, should accept nutted brakes, versus recessed mounting. Finding a set of nutted brakes in an STI/Ergo group is impossible. You're left adapting, using a set of aftermarket nutted units, or drilling your frame (don't).
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
#6674
#6675
Liked 3,007 Times
I don't know of adapter nuts, but you can get some nutted tektro dual pivot brakes for not too terribly much money that don't look too terrible that are nutted and don't require frame modifications. I've been told it's possible to remove their decals so it's not obvious that they are not part of whatever groupset with which you are trying to pair them.
