#6751
You converted a 6200 UG freehub to HG?
Please, more details!
#6752
I believe this was the 6261 hub? Uniglide, but with the oil port and spring clip and old Shimano branding.
This hub didn't have the mounting bolt for the freehub body. The bearings hold the freehubs body on the hub shell. Seems like it works okay?
The only other thing making this trickier than other HG conversions is the splined interface on the 6200 hub shell is different. No matter, once I took apart the freehub body everything else seemed identical to my donor freehub body internally (pawls lined up well).
So I just put the longer HG outer part over the original freehub body inner part (with the pawls) and it mated perfectly.
Haven't fully tested it out, but it spins one way and not the other, which is hopefully all that matters! And it fits hg cassettes just fine.
Likes For jPrichard10:
#6753
OOOps. Having let a LBS take the fixed bb cup out for me I had assumed it was English threaded...lol. French bicycles...whew. Turns out the BB is Swiss threaded. They look reusable but I'd like to put a new bb assembly in. Anyone know a source for new Swiss bb (cups or complete bb).
The frame is 77-78 GT or GJ, I'd like to do a period correct rebuild but would consider a cartridge bb.
Thanks, DA
Thanks, DA
#6754
seņor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,657 Times
Likes For SurferRosa:
#6755
seņor miembro
Liked 6,657 Times
The trough where the cable sits was too deep on my new Victory rear derailleur. The cable kept slipping. I looked at my old one, and, sure enough, I used JB Weld to build it up. So I did it again.
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/1540x2000/img_20230901_074755278_dae85ed74abbb3702b78fc1f9a19d89971c26a5b.jpg)
I'm still using the same two little epoxy tubes from about ten years ago. Such a great product.
#6756
#6757
Bikes: Motobecane C41, Matsu$hita Nashonaru
Liked 439 Times
Thanks, DA
Thanks, DA
If you are OK with more modern solution, IRD makes catrtridge bottom brackets with replacable cups. You can buy IRD bottom bracket in various spindle lengths and replacement cups in Swiss threading (you swap the cups yourself). Downside of this solution is that their spindles are JIS only. So unless you're using mid 80's Japanese made crankset, you might again have some chainline problems. These are nice BBs though, I've been using the cheapest version for about 3 years now with no issues. And this is probably the easiest option for JIS taper.
There are also some "no name" (or several names, like Token or Neco) cartridge bearing bottom brackets and I think they come in ISO taper. There's a German seller who sells them (look for Schweizerisch gewinde). No idea how good or bad these are.
#6758
Bikes: 1993 Diamond Back Sorrento, 1965 Schwinn Racer 3-speed, 1987 Schwinn High Sierra, 1990 Specialized Sirrus, 2020 Specialized Sirrus 3.0, 2013 Giant Seek 1
Liked 787 Times
Got started on the rehab of the 1982 Trek 412 I bought back in March. It has lived a hard life apparently and is rather crusty.
New tire, rim tape, tube, hub and freewheel serviced.
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/1024x768/img_3253_xl_b6870d4fd915ddef169ba93909b7af8a86dc8af4.jpg)
Likes For zookster:
#6759
Liked 1,110 Times
I had a slipping FD cable slipping. It may have been from using a new shift cable thats thinner than the 1984 cables the FD was designed for. I simply made a shim out of beer can wall and it has held quite nicely. Could have used copper or brass shim too as I have a drawer full of metal bits too small to throw away.
Likes For Prowler:
#6760
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Liked 342 Times
...just need to build a back one. It was cathartic activity this weekend, the man who taught me how to build wheels passed away in November but I just found out last week. I built the wheel in exactly the manner he taught me. Shimano 105 hubs, DT dbl bt spokes, and MA 3 rim 36h. All NOS from my stash. Been holding on to these parts for 10+ years.
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/pxl_20230807_031911884_a9b08eeefb74175253c75102e4397e2b8607020b.jpg)
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/pxl_20230807_031844856_e8e09f973d0c6aab0a1c06f1bc9986c61d1daf24.jpg)
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/pxl_20230902_130836650_cc47aea84f9abfcca8e64f831271e1bb03405423.jpg)
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/pxl_20230902_130932911_a7b2ad35b6fa0a55d2379b5f80e3e8bfb110c5b9.jpg)
Likes For mechanicmatt:
#6761
Liked 2,101 Times
Bathtime.
While this one soaks, Ill dismantle my new Le Champion and use the same bath water for it.
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/ec5b1245_34de_42ff_8cb6_06c146bce2a4_ea9588145c39a79fbd7100fc9de5ec4b0a6d6e79.jpeg)
Likes For Classtime:
#6762
Liked 2,101 Times
Dismantling the new to me L.C. Maybe the 26.4 is the wrong size
for a 74-75 Motobecane L.C. (NR rear mech pat 74) and got the DS cup soaking. I keep reading it should be Swiss
![foo](vb/cache//ds.jpg)
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_9107_a514bf9a91eb3582840b231037ebf488c9b4394a.jpeg)
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_9108_a61cba3ff205e38058ad9c7dfa2cf37e1923f909.jpeg)
#6763
I was at a friend's cabin fishing and he had a neat 1989ish TREK 820 leaning against the garage.
Luckily it was under a tarp and an overhang. As you might imagine, spiders galore.![Smilie](images/smilies/smile.gif)
He asked me to take it home, as he has succumb to the ebike craze.
I got it home and have it currently stripped down to the bare frame.
In the process of greasing all greasables.
It will will have fresh Schwalbe Billy Bonkers, Kool Stop brake pads, a Ritchey straight/wide handlebar, a Brooks saddle (haven't decided which one), a Wald newspaper boy front basket and an old Blackburn MTB rack rack.
It will need new cables all around. Not to mention a chain.
Luckily I have everything here except for the Schwalbes.
For a max couple hundred $$$ outlay it should make a really fun fishing/gravel touring bike.
Stock foto included for grins. Thrilled this didn't end up in their township landfill.
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/1200x782/ws1347578_09_97fd7a82d552e62cd274dcec61daa2a8d650eb07.jpg)
#6764
Cantilever believer
Today, even though I have 40+ bikes surrounding me (most of which are C&V-eligible), 30+ of which are going back out again after some work on them, I took advantage of a sub-100 degree day to reorganize the back yard work area, and the tool bins. It's almost like a free yard sale when you find long-lost and long-sought tools in the back of the bin - including a few "Brev Camp" ones I forgot I had. Now I'm that much closer to being ready for what promises to be a very busy bike-fixing season.
Likes For RCMoeur:
#6765
seņor miembro
Liked 6,657 Times
New Cinelli stem/bars, Fizik tape and Athena brake levers on the Bottecchia.
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_20230902_185250534_hdr_e99e1e7b52cb5241ca4045ec4d9656a0397be3f5.jpg)
It had been sooo long since I routed aero levers. I didn't even remember if the rear cable went inside or outside the front!
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/1400x2000/img_20230902_185019168_hdr_58dd6f0c258c6a0d7e8fcc8da5f92595a071cfdd.jpg)
#6766
Bikes: Teledyne Titan, Bob Jackson Audax Club, Bob Jackson World Tour, AlAn Record Ergal, 3Rensho Katana.
Liked 623 Times
This frame was bought, shipped, lost. refunded, found, offered back to me at a better price, bought again, shipped again, and finally received today.
A 1985 53cm Dave Moulton Recherche. The spec and materials are the same as the Fuso, built as a private label frameset it differs from the Fuso in cosmetic details. this is S/N 009 out of 200 ish produced.
The photos are as received, no rust, no dents, lots of paint chips, and very dirty but otherwise sound. Clean up has started, this will take a few days
Untitled by nemosengineer, on Flickr
: Mike
![](https://live.staticflickr.com/65535/53160297914_6a641425fe_3k.jpg)
![](https://live.staticflickr.com/65535/53161014383_dd9300f80b_3k.jpg)
![](https://live.staticflickr.com/65535/53160517530_69af72f3cd_3k.jpg)
![](https://live.staticflickr.com/65535/53160092656_90287d6736_3k.jpg)
: Mike
Booyah Hubba-Hubba!!!
Likes For Nemosengineer:
#6767
Polymultiplié
Bikes: Yes, please.
Liked 4,901 Times
For an upcoming vacation trip I wanted to add a front bag to mrs non-fixie's De Vos. So a small front rack and a bag support were needed.
This bike is fitted with single pivot side-pull brakes which limits the possibilities when it comes to small racks. The only one I had that would work was nr 1 from the line-up:
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x833/afbeelding2_70a7bc24e9cf92a84a544fc420502f8e2b2b39f0_9e8e9ac11a77ef0f01007c62a38ab45efff52fd6.jpg)
To support the top of the bag I decided to cobble together something, using a piece of aluminum tubing, a threaded rod, a lamp bracket and a couple of nuts which originally held a water bottle:
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/1_3fb3ab3b2786ab70429a0866a36dd506674251cc.jpg)
The result felt sturdy enough and didn't look too bad, IMO:
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/1488x1985/2_c029b2fbd8561dfc42ed3c699b0038bcbb058708.jpg)
How it looked on the bike:
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/3_193ff6f38f20e5dec4ff451dc268b866ab405307.jpg)
With the bag:
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/4_aa6ab00b5c5c20de569b10ab45c4b538965f6775.jpg)
We did a test ride later today, and mrs non-fixie was happy with the result. Apparently the the interference with the DL-80's I feared wasn't an issue:
With the bag:
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1105/img_20230903_171814867_hdr_1cec1672ff25b9fd05b6d540784dc84b86902e9d.jpg)
#6768
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Liked 453 Times
on the spectrum
…. in bike salvage purgatory
finally got enough seat post dissolved to call it done. I think. Any sane person would have given up. But no. I gotta be on the spectrum!
attemped to roll out a bit of this significant ding.
declaring it bondo time.
added some cable stops
thought I needed fender bosses but there’s some threaded holes in the drop outs
i got a fork made by Mission Bike- I think I’ll add fender bosses to it. I guess. Later.
going to clean it up for primer. I’m not planning on stripping bear. bare. Stripping Bear- could be a good heavy metal band name.
cheers
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/1280x960/img_4712_334d10dded91b27cd76f63a7b0b1c7daf0bfbaf7.jpeg)
It’s no lie. It’s lye. And now a dead patch of grass.
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/960x1280/img_4854_14bc9be2499e328f2ea04d351d34c8f3ab309705.jpeg)
Should have used a saw with a wide kerf
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/960x1280/img_4855_f424728ce327ba9d84103b9e6f032b6ec61d9768.jpeg)
cheers
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/960x1280/img_4856_76ea2e4d6044d97037db9ea5e39eb792ad7d9698.jpeg)
#6769
Bikes: 91 Ritchey Ultra, 1992 Specialized Stumpjumper, 1990 Klein Rascal, 97 Trek OCLV9700, 90 Minnelli Eclipse, 95 Marin Bear Valley SE, 1991 Breezer Lightning Flash 1991 Diamondback Axis 1992 Stumpjumper Comp 1983 Stumpjumper Sport
Liked 689 Times
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_4014_88762916d395d94cc70c039d2bec1c8c79d73eb5.jpeg)
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_4033_f69df522db9c2d1c4a3c76668d42f86bc7d63eac.jpeg)
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/71526491638_cc7bc9d3_fa07_4692_ad02_03b6f8091822_a8a375c4e293d4cbadf9fec459c43034cceedd83.jpeg)
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/img_4042_3068207fc88a41feab5c09c19859de73f466df4b.jpeg)
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_4043_67bc2ee04c19d161f81784ad6332fb289cf17f4a.jpeg)
Unknown BMX I found at the dump
Likes For victorm:
#6770
Bikes: Only my riders left...
Liked 799 Times
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/image_0175d3a60f96168221b5a405f01263a74096fde5.jpg)
As found, Specialized Rock Hopper Comp! Took it apart, lubed it, put it back together Ive got one more original cable to change It was a summer company favorite! Great purple to brown fade paint! Everything was adjusted very little about 10 years ago! All Deore LX One of the bicycles that will never go!
#6771
Here is the winner of the Walla Walla County Fair Demolition Derby, curtesy of Melody Muffler
and my own creativity for bar wrap. Cup 'o joe, leather, a pick, waxed cotton cord, and a rule
You got to pickup every stitch...
Must be the season
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_2138_9238982a72f5cd9b41677114bf443896a16aecad.jpg)
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_2139_ac0ccd26396bb99e8b8b6c54dc1a05daabd81709.jpg)
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_2141_b5cf1498a03e66c81b3703442cabdd26a6c4d201.jpg)
Likes For Mr. 66:
#6772
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Liked 502 Times
I'm in the middle of converting my '60s Triumph three-speed to run square taper. Finding the right 70mm (as Sheldon recommends) spindle to get the chainline right and work with the existing cups has been a challenge. I know - horror of horrors, a winter photo - but that's the best photo I have. I like old steel cottered cranks, they look fantastic, but for whatever reason (q factor maybe?) my knees hurt, so I've converted my bikes to run square taper. I found a very nice Surly steel chainwheel to look the part. This bike normally runs a 1980 Sturmey Archer S5.1 five-speed hub, which I'm going to rebuild this winter as low gear is slipping. Right now it has a 1950s AW three-speed that I rebuilt a few months back as a place-holder. I'm torn as to whether I'll build an aluminum wheelset for this bike - maybe just the front wheel to aid braking.
PXL_20230112_131500857
![](https://live.staticflickr.com/65535/52622389477_952e0593b5_b.jpg)
Likes For Ged117:
#6773
1991 PBP Anciens
Bikes: 1954 Robin Hood, 1964 Dunelt, 1968 Raleigh Superbe, 1969 Robin Hood, 197? Gitane, 1973 Raleigh SuperCourse, 1981 Miyata 710, 1990 Miyata 600GT, 2007 Rivendell Bleriot
Liked 370 Times
I guess if it has wheels, the wrenching is never ending.
![](https://i.imgur.com/AMCUCfrl.jpg)
![](https://i.imgur.com/lw7C6Phl.jpg)
![](https://i.imgur.com/r2jV9RLl.jpg)
A hot day in a slow parade. Over heated and burned a couple of valves. This going to cost some money.
I did put air in the tires of my Technium yesterday, that's sorta like wrenching on a bike.
Likes For bikamper:
#6774
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_3151_fce5a6ad2a21a1ef05891d9578325593f7148543.jpeg)
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_3149_6821de7ea151632a4bdb833629ed3c6ce51b5a97.jpeg)
My old R300 Touring I put together for a friend
"It's a fine line between absolute genius and sheer stupidity"
Likes For etherhuffer:
#6775
Liked 689 Times
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_4047_eee6e2f0877f56e6bd8908773464ee68b9d0a55e.jpeg)
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_4048_3d4143c778cf6b3545124e5946bec18b0aafc713.jpeg)
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_4050_845c140c27ca6263979519dd3e2f377778d49f11.jpeg)
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_4052_3774b8aed90ee1623900afa5478cde9d548777b2.jpeg)
Struggled with this seatpost for the last month but today victory was mine. Let the rebirth commence!
Likes For victorm:
