Old 10-14-23, 11:46 AM
  #6901
georges1
Steel is real
georges1's Avatar
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 688 Post(s)
Liked 1,012 Times in 672 Posts
Originally Posted by billnuke1
Should’ve washed’em first!
‘Nother of my barn/garage finds!
Original tires on the 850?!
This is a big bicycle!
Driveside…
Super quiet for in my in house shop! Quick recovery…stupid quiet! I think my garbage disposal makes more noise the this compressor!
Next! In the queue…
Original tires on the 850 which is rare to find. I like the ATX 760 , it was a very responsive and maoeuvrable mountain bike , the exage mountain is a very durable and bulletproof transmission
georges1 is offline
Likes For georges1:
Old 10-14-23, 12:43 PM
  #6902
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Quoted: 2172 Post(s)
Liked 3,508 Times in 1,230 Posts
New tire day. Finally wore out the Gravel King 38 on the back of the Davidson. It had seen a bunch of hard miles, both pavement and gravel.
rccardr is offline
Old 10-14-23, 01:39 PM
  #6903
billnuke1
billnuke1's Avatar
Bikes: Only my riders left...
Quoted: 350 Post(s)
Liked 783 Times in 390 Posts
Giant…
Yup!
The Giant seems to be my principal rider for where I live now.
billnuke1 is offline
Likes For billnuke1:
Old 10-14-23, 01:57 PM
  #6904
VintageSteelEU
VintageSteelEU's Avatar
Bikes: Motobecane C41, Matsu$hita Nashonaru
Quoted: 215 Post(s)
Liked 439 Times in 255 Posts
Originally Posted by Mr. 66
The Lygie gets some time in the light. Here I put some black Dura Ace 120/100 hubs on black ukai rims. I have not tried these out yet, they just did not have the right look I wanted on the silver frame. They look better here but still not great.
I installed Campy band clamp shifters, but they are shot. The pivot post for the front has lost its grip on the peen, so it tightens and loosens upon shifts. It works still but I have to maintain the 'd' screw. The clunky Regina chain shifts good, or better than I thought they would. I like cranks' the ring guard, and the ramp in the middle is a new thing for me as well.
This was purchased with 27" high flange Campy that have floated to another. The brakes are Dura Ace, a drop hanger bolt has been added to compensate the reach factor. The brake levers are newer Campy. A B-15 Brooks is the saddle. The stem is SR Royal with eagle crested SR Custom bars. I'm not a fan of the bars but they do look right for the Lygie. I'll cable up the brakes and it will be ready for testing.
24lbs 0oz as pictured
I think if you add black tape, hoods and cables, it will be looking looking pretty decent with the black rims and hubs. Black and brown makes a nice combo.
VintageSteelEU is offline
Likes For VintageSteelEU:
Old 10-14-23, 05:08 PM
  #6905
colnago_zuub
colnago_zuub's Avatar
Bikes: Colnago C96, Urban Arrow
Quoted: 5 Post(s)
Liked 4 Times in 4 Posts
What am i polishing??
Okay, need a little help here. I was removing some rust, and now I have this chrome metal and dark metal. What in the world is what here…sorry new to this. Is the black part steel I should keep polishing? Is it rust? I feel like there may be a chrome coating I’m removing to expose more of the dark metal? Thanks.
colnago_zuub is offline
Likes For colnago_zuub:
Old 10-14-23, 06:13 PM
  #6906
markwesti
markwesti's Avatar
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times in 175 Posts
Hmm ... Just my 2 cents . First the black is discolored bear metal , IMO . I would carefully sand with a Dremel 80 grit disk to get the big pitting off , then de rust it with a de rust gel . Then paint in a rust neutralizing primer . Level it up with regular primer , and then paint your color .
markwesti is offline
Old 10-14-23, 08:47 PM
  #6907
RCMoeur
Cantilever believer
RCMoeur's Avatar
Quoted: 565 Post(s)
Liked 1,950 Times in 878 Posts
"It's the most patchable time of the yeearrr..."
Testing and patching dozens of tubes for Recycle Your Bicycle, and not even halfway through the bin from today's removals. Should keep me from being bored for a bit.
RCMoeur is offline
Old 10-15-23, 06:40 AM
  #6908
bikamper
1991 PBP Anciens
bikamper's Avatar
Bikes: 1954 Robin Hood, 1964 Dunelt, 1968 Raleigh Superbe, 1969 Robin Hood, 197? Gitane, 1973 Raleigh SuperCourse, 1981 Miyata 710, 1990 Miyata 600GT, 2007 Rivendell Bleriot
Quoted: 74 Post(s)
Liked 356 Times in 140 Posts
The cylinder heads, rings, and gaskets finally got here for the top end rebuild of my Ural engine.
It will be back together today. Maybe even running.
bikamper is offline
Old 10-15-23, 07:24 AM
  #6909
Kai Winters
Quoted: 249 Post(s)
Liked 473 Times in 278 Posts
Continuing my build of an SWorks SL8 with Dura Ace Di2. Finally got the drive train parts in and connected on my work bench...battery charging and shifters/derailleurs working as they should.
Having a lot of 'fun'...not really...figuring out how much of the seat tube will have to be cut and holes drilled to attach the battery holder 'fiddly bit'...the seat post is narrow and the battery does not slide inside so Spesh designed this nifty little hanger that has two arms that clicks into place inside the seat post. The battery 'hangs' from this part and just sits inside the seat tube...BUT...the seat tube narrows two thirds of the way down towards the der. hanger and it also has the bottle cage mounts inside which prevents the battery from going deeper into the seat tube. Not really a big deal...UNLESS...you are on a small frame which is around your correct size then there may be a problem as you may have to cut quite a bit off the seat post in order for the battery to fit...SRAM has a huge advantage over Shimano on battery fitment/location and size...Fortunately the frame I'm working on is a 54cm so I'll have room for the battery and the cut seat post but drilling the holes is a pain in the ass. It requires precise measurement. Because I'm trimming a good bit off the seat post I'm able to measure and cut more than once for practice and a precise cut and alignment. I'm also a bit concerned that the battery may tap the sides of the seat post when ridden over less than smooth surfaces and there is not a lot of room for some sort of cushioning. I'm thinking a bit of butyl tube at the base of the battery to snug it up a bit and cushion any noise will do the trick or perhaps a layer of electrical tape...depends on how much or little room there is.
All in all the build is going well and would have been finished but for the lack of a couple of parts we are waiting for any a lovely vacation I've just returned from.
Kai Winters is offline
Old 10-15-23, 06:35 PM
  #6910
Nemosengineer
Nemosengineer's Avatar
Bikes: Teledyne Titan, Bob Jackson Audax Club, Bob Jackson World Tour, AlAn Record Ergal, 3Rensho Katana.
Quoted: 215 Post(s)
Liked 623 Times in 245 Posts
The Rossin is chain and cables away from being completed. Shimano should be shot for not putting adjustable pad holders on the DA 7700 brakes, all is ok with a set of Swiss Stop pads and holders.
Untitled by nemosengineer, on Flickr
And Introducing "The Pink Panther", soon to be "The Black Panther". Yeah Its really pink. Late70's, Early80's Nag.
: Mike
Booyah Hubba-Hubba!!!
Nemosengineer is offline
Likes For Nemosengineer:
Old 10-16-23, 04:04 PM
  #6911
bark_eater
Quoted: 755 Post(s)
Liked 741 Times in 423 Posts
Stripped down a sad Hardrock from the scrap yard. Just a few salvageable bits for the Indexed Suntour box, but the frame may get a second life as a single speed beach bike.
bark_eater is offline
Likes For bark_eater:
Old 10-16-23, 06:58 PM
  #6912
2cam16
2cam16's Avatar
Bikes: TRIMMED DOWN THE HERD
Quoted: 1096 Post(s)
Liked 951 Times in 607 Posts
After tearing it down and washing the frame last week, this morning was all about polishing,paint touch-up and waxing:
IMG_4656 by 2cam16, on Flickr
IMG_4655 by 2cam16, on Flickr
IMG_4651 by 2cam16, on Flickr
IMG_4649 by 2cam16, on Flickr
2cam16 is offline
Likes For 2cam16:
Old 10-16-23, 07:09 PM
  #6913
SW84
SW84's Avatar
Quoted: 136 Post(s)
Liked 118 Times in 78 Posts
Since I'm replacing the tires on my mtb I decided to true the wheels. Fell on the bike while riding with the grandson and the wheels show a little lateral movement. Removed the tires and tubes, and trued them both.
SW84 is offline
Old 10-16-23, 09:33 PM
  #6914
SurferRosa
seńor miembro
SurferRosa's Avatar
Bikes: '70s - '80s Campagnolo
Quoted: 3933 Post(s)
Liked 6,591 Times in 3,265 Posts
Originally Posted by Nemosengineer
SurferRosa is offline
Likes For SurferRosa:
Old 10-16-23, 11:16 PM
  #6915
Nemosengineer
Quoted: 215 Post(s)
I need a painter...
Old 10-17-23, 03:46 AM
  #6916
jdawginsc
Edumacator
Quoted: 2526 Post(s)
Liked 3,348 Times in 2,098 Posts
I need a painter...
Is the paint bad? It looks really decent in the picture?
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
jdawginsc is offline
Old 10-17-23, 08:48 AM
  #6917
jPrichard10
Quoted: 228 Post(s)
Liked 279 Times in 117 Posts
Wrenching? No. Knifing? Yes.
This truly took hours and was one of the most frustrating and tedious bike projects I have done in a long time (and I build wheels, so that's saying a lot).
jPrichard10 is offline
Likes For jPrichard10:
Old 10-17-23, 09:56 AM
  #6918
xiaoman1
xiaoman1's Avatar
Bikes: A few too many
Quoted: 1367 Post(s)
Liked 2,188 Times in 1,189 Posts
My thoughts exactly...........
Voltaire
xiaoman1 is offline
Likes For xiaoman1:
Old 10-17-23, 12:36 PM
  #6919
capnjonny
capnjonny's Avatar
Quoted: 343 Post(s)
Liked 637 Times in 231 Posts
While browsing the bike smorgasboard at the Bike Exchange last week I came upon a couple of Diamond back Accents, one yellow and this one a beutiful blue/green. I was told that neither was "good" enough to fix up and sell but I just couldn't let the blue/green one go without playing with it. It is going to be donated out and I thought "someone is going to get a REALLY nice custom bike when I'm done".
My work consisted mostly of cleaning and putting new tires and cables on it. I looked at the tires we had on hand and decided on these cruiser white walls. I also changed out the blue bars for aluminum ones with an inch more rise than stock and swapped the black cables for white. I noticed that although the bike had a 7 speed index shifter, someone had installed a 6 speed freewheel so that was replacd with a 7 speed hyperglide clone. I think old rigid frame mtn bikes like this make great city cruisers and utility bikes. Hopefully the person that gets this one will cherish it.
One feature somewhat unique are the braze on's on the front forks for a rack . This would make this bike able to mount front paniers as well as a rear rack.
capnjonny is offline
Likes For capnjonny:
Old 10-17-23, 05:56 PM
  #6920
jdawginsc
Edumacator
Reclamation of garage
...and so I have room to build up the 32,458 projects bike and other wise...
Phew...
Three mid-tint paint cans! $33. Garage doesn’t care
Phase 2
Phase 3 and complete
Gotta use every nook and cranny...
Likes For jdawginsc:
Old 10-17-23, 09:55 PM
  #6921
Nemosengineer
Quoted: 215 Post(s)
The sad thing is the paint is in decent shape and and the decals are complete (exception being the Columbus sticker) with nice patina. But it's so very Pepto-Bismol pearl pink and in direct sunlight it looks like salmon that's gone bad, it could be a prop for the Barbie movie. I don't have a ton of money in it (yet). Pretty sure this one is going to be painted black, decaled as original or...
I have pinned the year down to 1982 late or 1983 early and the model is a Colnago Super Specialismo with SL tubing, not a SLX Superissimo. If I have screwed up the ID on this bike please chime in, I'm a Colnago virgin.
: Mike
Old 10-18-23, 08:56 AM
  #6922
RCMoeur
Cantilever believer
RCMoeur's Avatar
Quoted: 565 Post(s)
Yesterday, a family at the church said they needed an inexpensive cruiser for a teenage exchange student. Since the bike will be used in places prone to theft, I figured a less-shiny one would be a better fit. Got an old Huffy frame and started building, but realized the seatpost was seized. As it's a simple steel vs. steel problem, I employed a few minutes of Liquid Wrench, a pipe wrench, and my medium-sized "persuasion device".
Some serious torque was applied, and with a satisfying "thoonk" the seatpost decided to cooperate. Now on to the rest of the build...
RCMoeur is offline
Likes For RCMoeur:
Old 10-19-23, 09:53 AM
  #6923
RCMoeur
Cantilever believer
RCMoeur's Avatar
Quoted: 565 Post(s)
I was able to finish that singlespeed cruiser this morning. It ain't the prettiest, but it works. Now time to deliver it to the family at church, take a break from wrenching for an, ahem, "medical procedure", and move on to new disasters over the weekend.
RCMoeur is offline
Likes For RCMoeur:
Old 10-19-23, 11:08 AM
  #6924
tcs
Palmer
tcs's Avatar
Quoted: 1702 Post(s)
Liked 1,886 Times in 1,091 Posts
... it's so very Pepto-Bismol pearl pink and in direct sunlight it looks like salmon that's gone bad, it could be a prop for the Barbie movie.
Hmm. I took one look and thought 'pink jersey::Giro'.
tcs is offline
Likes For tcs:
Old 10-20-23, 02:55 PM
  #6925
Dovetube
Quoted: 13 Post(s)
Liked 9 Times in 8 Posts
Seems to have a hop
Continuing to discover things I don't know anymore how to do, changed spoke direction at least thrice lacing, and very nearly have lighter g. spokes on drive side. Mission was only to prepare a 7-speed spacing wheel because I didn't feel like overhauling my go-to wheel-hub for that spacing. Worst failure in multitasking is trying to listen to podcasts while reading e.g. this site.
Dovetube is offline
