Immersive waxing / it should be more popular
#701
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
#702
Should Be More Popular
Quoted: 22770 Post(s)
Liked 9,169 Times
Likes For datlas:
#703
Liked 9,169 Times
#704
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2826 Post(s)
Liked 3,426 Times
I'm still of the opinion that waxing can be done with low cost and low labor. Solvent cleanings, ultrasonic baths, high cost fluorinated waxes.... I don't do any of that. Same block of paraffin from Ebay I bought 5 years ago. Easy Peasy. Although I might feel differently if I didn't live in such a dry climate.
"Your beauty is an aeroplane;
Likes For TMonk:
#705
Quoted: 3261 Post(s)
Liked 2,583 Times
Darren Mcgavin would know how to kill a zombie. Anyone remember the Night Stalker episode where Kolchak was in the junkyard trying to kill the big African American zombie? He was asleep in a junk car. Kolchak gets on top on him. He pours salt into his mouth and starts to sew it up. Then the zombie wakes up and things get interesting!
Edit: Found it. Awesome.
https://www.nbc.com/kolchak-the-nigh...zombie/3980758
#706
Quoted: 4079 Post(s)
Liked 7,666 Times
Likes For tomato coupe:
#707
Liked 9,169 Times
Likes For datlas:
#708
Liked 7,666 Times
Well, a good fraction of the posts are from naysayers that are trying to quell the enthusiasts.
#709
Quoted: 8445 Post(s)
Liked 9,402 Times
Wax is great. No, it's not. Yes, it is. No, it's not.
Likes For big john:
#710
Not actually Tmonk
Liked 3,426 Times
There is a new thread on "the other forum" started by someone that wants to try waxing for the first time, and is asking for advice on cleaning his chain. Several people described pretty lengthy cleaning procedures using multiple chemicals. I think it's those types of stories that evoke skepticism from the "naysayers."
Is it better? Probably. Is it worth it? Not for me. 5 years of only cleaning new chains w overnight degreaser soak, and just paraffin in between. Nothing else. Works just fine and keeps my clean drivetrain OCD at bay.
#711
Quoted: 2660 Post(s)
Liked 3,227 Times
Just did a quick search. From KMC (the bike chain manufacturer):
"A new chain usually feels sticky at first. These are residues of the high-performance grease used during assembly. Remove this grease with a thin-bodied oil or cleaner (no aggressive grease solvents!), lightly oil the rollers and remove excess oil with a cloth. We recommend never to degrease the chain completely."
FWIW, I've never waxed a chain in my 50-plus years of riding pro-level bikes. Current chain care: when a chain starts to become a bit noisy, I clamp the chain inside a plastic chain-cleaning case (the type with car-wash-style brushes rotating in several planes), drip some Tri-Flow into the holes at the top of the chain cleaner (they're meant for degreaser, apparently, but I've never found that step necessary), and run the pedals backwards while holding the cleaner in place. It's satisfying to feel the chain running more and more smoothly through the cleaner after the first 20 or 30 rotations of the crank.
I then remove the chain cleaner and give the chain a quick wipe. Five-minute job, and the chain's good for several hundred miles.
#713
Liked 9,402 Times
#714
Not actually Tmonk
Liked 3,426 Times
been riding indoors way too much lately for the best coast. looking fwd to spring!
last week I put in 14 or so hours, and only 1 ride was outside
#716
Liked 9,402 Times
Likes For big john:
#717
Method to My Madness
Quoted: 2082 Post(s)
Liked 1,571 Times
Gulf Wax available at Walmart.com again for < $4/lb.
Gulf Wax Household Paraffin Wax, 16 oz - Walmart.com
#718
Quoted: 4639 Post(s)
Liked 1,781 Times
What is it that people think is going to happen if they simply put an oily chain in the wax for awhile?
The wax displaces the oil. The chain comes out waxed. The pot of wax looks used but is still 99.9% wax.
People is crazy.
People is crazy.
Likes For Kontact:
#719
If a dirty oiled chain is placed in wax, the wax will mix with it at a rate of about 30%. To actually remove the dirty oil, some agitation is needed. Then you'll have dirty wax. Some of the dirt will fall to the bottom, but not all of it.
I mix at least 20% heavy gear lube in my wax to soften it and improve lubricity. I then dissolve into 4-6 parts naphtha/camp stove fuel to make a wet lube.
#720
Just Pedaling
Bikes: YEP!
Quoted: 357 Post(s)
Liked 589 Times
Likes For SpedFast:
#721
If you're really concerned about absolute cleanliness, you may not like any additives. I don't handle my chains much so a tiny bit less cleanliness is OK. I'm confident that the lube will do a better job and last longer. The chain looks quite clean when I relube the chain on the bike, but I still wipe with a paper shop towel that has a little naphtha on it, before lubing. Sprockets and chain rings stay clean for a long time.
I run tubeless tires, so I carry nitrile gloves in case I have to perform a messy tube installation on the road, but that's unlikely. I had one puncture in 18,000 miles and that one sealed in seconds.
https://forums.thepaceline.net/pictu...&pictureid=945
Likes For DaveSSS:
#722
Liked 1,781 Times
It doesn't take much to make white wax look dirty. But that tinting has little to do with the effectiveness of the wax as a lubricant, or how it behaves at room temp when you handle the chain.
Along the same lines, I've cleaned chains quickly by shaking them in a bottle of citrus solvent and then rinsing with fresh water. If you don't get the water completely out of the chain, the wax will displace it anyway and the water will sink to the bottom of wax pot.
#723
The percentage of oil that can be mixed into paraffin came from my personal experiments, aimed at making a paraffin based wet lube. If more than 30% oil by weight is added to melted paraffin, you'll have free oil that's not mixed in, sitting on top of the hardened paraffin. With or without oil, you can dissolve paraffin with any amount of naphtha greater than 4 /1. At 4/1 it won't be fully liquid at room temperature.
My main point is that putting a dirty chain in to your melted paraffin isn't the best thing to do. Cleaning in mineral spirits or naphtha first is preferable.
#724
Liked 1,781 Times
#725
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 342 Post(s)
Liked 168 Times
One application of drip wax lube lasts longer than hot melt wax.
At least Rex Black Diamond does.
The resistance to drivetrain wear of a drip wax lube is almost as good as hot melt wax.
At least Effetto Mariposa Flower power wax is.
