Question about aluminum
#51
Sunshine
Quoted: 11067 Post(s)
Liked 7,634 Times
I have over 20k miles on a CAAD 3 Cannondale with 23 mm tires.
I currently have over 10k miles on a Trek ALR5, came with 25mm tires.
Both are “fat” tubes. One bike has round tubes, one bike has shaped hydro formed tubes. Geometry is actually fairly close, wheel base is similar.
The ALR hands down, not even close, rides light years better than the Cannondale. It’s smoother, has little or no road buzz, it’s stiff and compliant at the same time. It actually rides better than my 2 CF cyclocross frames and isn’t much worse than my steel Lemond, which is my on 28’s.
On the other hand, the Cannondale was unforgiving, rough, almost brutal ride. But holy crap did it put power to the wheels and handle like it was on rails.
The ALR is now on CF wheels and 28’s - the bike rides and handles very well.
A couple winters ago I bought a trashed '97 CAAD3 r600 frame off ebay to fix up, paint, and modernize. After some frame work and driveway painting, I added a 1" carbon fork and some modern 11sp Ultegra components. The tires are 27mm actual width.
With the tires and fork, the bike has a 73.5 head tube angle, 1028mm wheelbase, 40.64mm chainstays, and 54mm of trail. It is, as you describe, a bike that handles like it is on rails.
But it also has not felt uncomfortable to me.
I tore my main road bike down over the winter, didnt get around to rebuilding it, and rode this CAAD3 this year whenever I wanted a road bike. It was quite comfortable from a 'beat you up' perspective as I never felt like the bike was hurting me- and that includes some fast 50mi group rides where I hung onto the back for dear life, an 85mi day, and multiple hard 20-25mi solo rides.
Maybe it was the tires being 27mm instead of your 23mm that keeps it from ever feeling unforgiving to the point of brutal? No idea.
I can tell you that if it did feel unforgiving like you describe, that thing would be parted out quickly. Life is too short to ride harsh and unfun bikes.
...this also sorta goes to the always interesting reality that we can perceive how a bike feels in a very different way from how others feel.
Anyways, late to the thread but figured I would respond since you mentioned a CAAD3 and thats what I rode this season for road rides.
#52
Le Crocodile
Quoted: 370 Post(s)
Liked 793 Times
Best bike that I own. $400.00 CAAD something off of Craigslist.
"Worst" bike in my collection. Funny how that works out. Anyway, this doesn't prove anything, it just goes to show that aluminum can be awesome.
Quoted: 4876 Post(s)
Liked 4,042 Times
About the rates of failure of different frame materials back then: there's a fascinating ongoing C&V thread where people are reporting their experience with frame failures. So far, the reports seem to be running about 5 or more failed steel frames to each aluminum frame---and the aluminum failures reported include Alan- and Vitus-built small-diameter-tube frames, known for being somewhat failure-prone.
Anecdotal, obviously, but I suspect that the ratio will continue to be roughly the same as the stories continue to roll in. I worked in a couple of the biggest bike stores in the area in the '80's and '90's, and that's about the proportion of damaged frames that I remember.
Cannondale's engineers were working to refine their designs throughout that period: hence the successive CAD---and, later, CAAD---series numbers, prominently labeled on each bike. They'd figured out early on that riding comfort did not decrease with increased structural rigidity and/but that the increased torsional and lateral rigidity did result in improved handling and wheel tracking. And the bikes kept getting lighter!
One of the articles SpeedOfLite posted was the earliest I've seen where the writer said that a Cannondale racing bike had a particularly hard ride. He blamed the frame but then swapped the tires (23 mm to 25, I think) and said the ride was much improved. Somehow he didn't draw the all-but-obvious conclusion. (The bike under review was a Crit Series, too. See my previous post on that topic.)
And observations I've had with good steel and titanium bikes - vibration. With quality metal in the tubes and likewise quality steel forks, there is little damping. By all I read here and elsewhere, that should make my bikes torture to ride on rough roads, especially with the not so big tires and pressures I use. My two favorite rides are the ti fix gear of my avatar photo and the recently acquired early '80s Pro Miyata. Both are stiff as those materials go (and plenty stiff for this 150 lb climber at his 25 yo best long ago). I run 25c tires on them except 23c on the Miyata rear. 90-100 psi, 110 on the 23c.
Both of those bikes are classic 1980s steel race bike rides. I feel everything. But it just isn't an issue. Yes, like I did when I raced a million years ago, I de-weight the saddle a little and use my arms as shock-absorbered springs on the rough stuff. (Good practice any time on light tires and rims; stuff I love to ride.) Those bikes are alive! And I absolutely love it. It has always felt to me that nothing is lost energy-wise on such frames. (Yet we all knew back in the day that some riders needed super stiff bikes because they otherwise lost a ton of energy into the frame. The concept of "planing" always sounded bogus to me but my 1976 Fuji Pro flexed and I climbed that thing all over New England with zero penalty.)
