The smell of fresh glue portends a great cycling season
#51
Quoted: 851 Post(s)
Liked 2,229 Times
I'm new to the tubular scene, and I have another thread going about sealants. It sounds like what you're describing is carrying some Stan's with you, and putting it in after you flat, replacing the core, and riding on. Is that your system? If so, do you carry the 2 oz. sealant injectors (seem kind of pricey), or what?
#52
tantum vehi
Quoted: 1171 Post(s)
Liked 999 Times
Doesn't Stans dry out after about 3 months? Or does it saturate the latex tube and seal it so it won't slowly leak air as tubulars usually do?
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#53
Quoted: 851 Post(s)
Liked 2,229 Times
@mountaindave, yes, 1/4 or maybe a little less from the 2 oz bottle. I don't like the idea of adding extra weight to my tires but it beats patching & sewing.
The treated tires will still leak like you'd expect from a typical latex tire. Not sure about the drying out after 3 months concern. I am still riding on tires that had a slow leak and were treated 6+ months ago without issues.
#54
Veteran, Pacifist
Quoted: 3947 Post(s)
Liked 4,950 Times
After enough weeks, my tubies (sealed w/ sm amt of Stan's) hold air better.
I firmly believe it is a permanent fix on small leaks (not valve related) where the antagonist can be found and removed. I would reapply every season if the tires last that long.
As to weight - phffft - 1 fluid oz. of liquid latex weighs mere grams.
_______________________________________________________________
For a dedicated gluing session, I confess to starting with three sets of blackwalls only one tan sidewall.
Here's hoping 25mm of Veloflex goodness makes the ride everything one expects from fricking expensive bicycle tires, lovingly glued by hand so as not to have that confounded & dreaded bump - usually at the valve stem.
#55
Veteran, Pacifist
Liked 4,950 Times
Why do i feel Specialized?
2 layers each to rim + tire.
Can't you almost see those layers bonding?
ok, maybe enough glue for 1 day.![Innocent](images/smilies/innocent.gif)
#56
Semper Fi
Quoted: 1173 Post(s)
Liked 358 Times
Put down the contact cement, now slowly back from the glue. Too much fume action for you this week.....
Bill
Bill
Semper Fi, USMC, 1975-1977
#57
Old fart
Quoted: 3619 Post(s)
Liked 3,460 Times
Tip: a multi-gauge spoke wrench that includes a 12-gauge size can double as both a spoke wrench and a valve core tool. I do bring a bottle of Stan's with me.
![Thumbs Up](images/smilies/thumb.gif)
#58
Veteran, Pacifist
Liked 4,950 Times
Did I do it wrong ???
When applying glue to the last wheelset, these Ambrosio Synthesis Durex Super Professional measured 2mm wider (outside width) than the Mavic GP4 which gets the 2nd set of tires. The tires are a 25mm vs a 30mm.
So, I put the 30mm tire on the wider rim - even tho the wheelset was due to get a tan side which I prefer on the Mondia. ?A concession determined by a rider not a collector? Can't wait for a long ride in the morning!
As an aside, these Schwalbe tires were a b___ (hard culprit) to get on. They were not pre-stretched as long as I give other tires, but it was clear that these 30mm have much thicker sidewalls and tread than a 28mm Veloflex. They will be hopefully durable and trouble free on gravel roads (the intended purpose). Around the block circles to check for bumps and 'set' the tires confirms the mounting impression = that is, at about 90psi, the road feel is still there but they seem heavy to spin-up relatively (only an initial impression).
Mondia Super pictured with 30mm and with old tan sidewalls. The new tan sidewalls will be mounted tomorrow.
#59
Veteran, Pacifist
Liked 4,950 Times
Here's the Mondia with its' intended tanwall Veloflex Roubaix 25mm. Much better than the black tires.
Final stats: 4 wheelsets completed, 2 layers of glue on each of the wheels and tyres, 3rd layer of glue on those 30mm Schwalbe monsters. No bumps, No glue on the garage floor, No scraped knuckles, No glue in the hair.
Lessons learned: Pre-stretch more; buy the BIG can of glue with its' own application brush and no worries of running out; don't get in a hurry. Beers, music and a smoke makes it almost like fun. Should have invited a friend.
Now for the summer of smooth spinning.
#60
Campy NR / SR forever
Nice job all around.
Where did you get the Veloflex tan sidewall tires?
