High-end steel options?
#51
junior
eric/fresno, ca.
#53
How come all these steel gravel frames have such weak tire clearance? The only one that I can see that gives you plenty of clearance is the Rondo RUUT steel version but that's because it's identical to the carbon version. Most of these mentioned can't seem to take a 650x47 tire.
#54
FLIR Kitten to 0.05C
Liked 407 Times
The other half of it...is crankset compatibility (read 68mm std, or pressfit equivalent, roadie bottom brackets), and the usage of tubing stock. To do 700cx40+ in metal....you really need either a long rear-center or a metal-bar yolk on the DS chainstay or both. The later makes for more weight and more custom machining as opposed to a straight Reynolds tubeset out of a box. The former impacts handling.
#55
They try to keep the rear-center short and racey. That is half of it.
#56
https://fairlightcycles.com/product/...v=6cc98ba2045f
#57
Sunshine
Liked 7,731 Times
Fairlight Secan frameset (UK) takes a 650b x 57 or 700x45.
what am I missing here?
#58
Sunshine
Liked 7,731 Times
terrible hoops to jump thru just to get the price.
$1385 usd for the frameset, axles, and headset.
#60
Sapient
#61
Take out 19% VAT if you shipping to US. I think it's a little less than $1200 which isn't a bad price but I'll take a Rondo RUUT carbon frameset at that price.
#62
So many to find..
Maxway Ltd TW is a big company many companies like Surly,Salsa And Richey and several others , use to make their bikes
there are a number of small builders around the country making very nice steel bike frames..
Portland Oregon has several....
continue name dropping ...
NB; you could take a frame building class and make your own , as well..
![Thumbs Up](images/smilies/thumb.gif)
#63
I am surprised no one has mentioned the Otso Warakin.
Stainless steel frame
420-430-440mm chainstay options for racy to lax setup
Can take up to a 53mm tire in 650b and 440mm chainstay config
$1099 for frameset
Did I mention stainless steel?
$1099 for frameset
#64
Sunshine
Liked 7,731 Times
nice price, neat dropout versatility, relatively unique tubing for gravel, and great price. Oh, and threaded bottom bracket too!
- the massive 44mm headtube is an awkward contrast to the rest of the frame tubing.
- 15mm fork TA is...meh.
- no flat mount rear is...meh.
- HEAVY frame. I'd be curious to find out what the tubing specs are in terms of butting profiles. And also would be interested to find out how much weight the creative extras on the rear of the bike increases weight. That 44mm tank of a head tube has to weigh a bunch too.
my recently built road frame in 64cm with OS Zona tubing weighs 1970g. This frame in 54cm size weighs 2120g! At that weight, I would imagine the Otso in the largest size will tip the scale at something like 2350g.
Hardly svelte for being high end.
all that said, it's an intriguing frame for sure and worth looking into if the geometry works. Heck of a price if its the frame someone wants!
mstateglfr
22
12-04-18 03:08 PM
wheelsmcgee
12
04-18-17 05:06 PM
dr_lha
46
03-28-16 12:47 PM
