91 Klein Rascal
#52
4.6692016090
Bikes: yes
Quoted: 59 Post(s)
Liked 81 Times
What a beauty! Where did you source your decals?
Also digging the early Klein font rather than the later "Klingon" font.
well it’s frame reveal day. I tried to stay true to the original color scheme. Basically the pink has been replaced by the green.Still needs to cure for a bit before I can wax and polish and start to build up. Fade turned out pretty good for my limited experience and equipment consisting of spray cans. Kawasaki green with semi gloss black and purple. Fork has been powder coated high gloss black.
#53
Bikes: 91 Ritchey Ultra, 1992 Specialized Stumpjumper, 1990 Klein Rascal, 97 Trek OCLV9700, 90 Minnelli Eclipse, 95 Marin Bear Valley SE, 1991 Breezer Lightning Flash 1991 Diamondback Axis 1992 Stumpjumper Comp 1983 Stumpjumper Sport
Quoted: 103 Post(s)
Liked 688 Times
Tig welder and some stock aluminum chunk. Filed it best I could to match the existing profiles. As for decals I ordered right from https://www.kleinspainted.com/ as well as cable tubes, chainstay protector and replacement bottom bracket bearings
#54
Quoted: 103 Post(s)
Liked 688 Times
I’m throwing this out there hoping someone can help, I’m looking for a black 1” threaded headset. Would prefer XT but would entertain something else. The Chrome FSA I have won’t look correct on this build. Thanks😊
#55
Quoted: 103 Post(s)
Liked 688 Times
Chrome headset
So the chrome headset i have won’t look right on this build and payment $150 for a black Deore XT is not happening either I decided to try the Duplicolor paint option. Unbelievable how this turned out. Will try it until another option presents itself
Likes For victorm:
#56
Bikes: 1984 & 1990 Marinoni Specials - 1990 Bianchi Sika - 1993 Cannondale M800 - 1996 GT Zaskar - 1993 Kona Kilauea - 1987 Ritchey Ascent - 1996 Rocky Mountain Vertex - 2008 Kona Dogma - 1976 Schwinn Suburban - 1994 Kuwahara Makai
Quoted: 36 Post(s)
Liked 203 Times
It's actually a great idea, those cans are $20 a piece so not cheap, I've done frames with that paint where I used the Dupli base coat (the frames weren't shiny chrome so you need a proper base). Durability has been good. It's actually clear coat paint with color added. You can add more clear if needed to make even shinier. I'd just stick with this headset
Likes For retrodude:
#57
Quoted: 103 Post(s)
Liked 688 Times
Engravings
#58
Quoted: 103 Post(s)
Liked 688 Times
Pedal refurb complete
Pedals are done. Quite happy with the results. Engravings filled in fairly well and look great from 5’ 😉
Likes For victorm:
#59
Quoted: 103 Post(s)
Liked 688 Times
Prewax fitup
Have to wax it before fitting up components but seat post showed up today and I had to have a look at what she’s gonna look like
#60
Quoted: 409 Post(s)
Liked 432 Times
This bike needs some purple anodized cranks and cantis. With nuclear-waste-green Ringle Peace Sign cable hangers.
Jus' sayin'...
--Shannon
PS: Evil thought... Dupli-coloring the thumbshifter bodies and brake lever blades would look rad... until you actually rode the bike.
Jus' sayin'...
--Shannon
Likes For ShannonM:
Likes For retrofit:
#62
Quoted: 103 Post(s)
Liked 688 Times
Pullin Noodles
Well I needed to be a bit of a contortionist, and had to hold my to tongue a couple times so I didn’t curse out loud but i manage to pull the noodles through the frame. Used needle, thread, gravity and a beefy magnet to get these through. A second set of hands would have made the job a lot easier. More progress and more lessons learned.
Likes For victorm:
#63
Quoted: 103 Post(s)
Liked 688 Times
Bottom Bracket
Another one of my stresses was remounting the bottom bracket bearings. I intended to use a large C clamp to press the drive side bearing in but it wasn’t strong enough. My wife thought I was losing my mind when she found the shaft and bearings in the kitchen freezer🤓 i found a socket from a ratchet set that was very close to the bearing outside diameter and with some backing a some cautious hammering i was able to get in. Putting in the no drive side went similarly poor. Bearing actually went in more easily but the alignment was off on the drive side bearing and the shaft turned but with a lot of friction. I used my depth probe on my caliper and found that it one 1 mm out of square to the frame. Couple firm taps with hammer and screw driver I was able to knock it into alignment and she spins wonderfully. 😥glad that’s done without any damage to paint or parts
Likes For victorm:
#64
Quoted: 103 Post(s)
Liked 688 Times
As she sits
Current status, likely won’t change much for awhile as I build up funds to get the specific parts I need to continue. Likely purple anodized canti's, cable set not sure housing color black likely, Ringle purple water bottle cage and likely new saddle Flite or Turbo maybe change handle bar to Syncros if I happen across something I like and oh ya not sure about the tires white would be dreamy or maybe tan wall? so ya basically done lol......
#65
Quoted: 409 Post(s)
Liked 432 Times
Black tires.
Black housings, too. Ringle cages would be the diggety dank.
--Shannon
PS: Your bike is rad and I hate you.
Likes For ShannonM:
#66
Quoted: 103 Post(s)
Liked 688 Times
Thanks,I think lol. I can’t make a decision on chain type a sounds like you could point me in the right direction.
#67
Quoted: 409 Post(s)
Liked 432 Times
Cosmetically, they all end up kinda lookin' the same after a few hundred miles anyway, no? (Except for maybe colored BMX chains, but I haven't had one of those since the 1st Reagan administration.)
--Shannon
PS: Oh, darn... I think I just figured out what you meant by "chain type"! I was talking about the fact that the last 1/4th of the chainstays and seatstays are painted black... had nothing to do with the color of your chain.
I are dumb.
Likes For ShannonM:
#68
Quoted: 103 Post(s)
Liked 688 Times
I've been using SRAM chains for so long, I don't even know what else to recommend.
--Shannon
I are dumb.
--Shannon
I are dumb.
thanks for the input, I’ve been using KMC chains and am happy with them as I really only do city trail riding. I think something with black inner links and nickel outlets would look the part. Am really wanting to try hot wax as chain lube though. That would be new to me but it sounds like it’s the new go to.
on a side note I am the dumb one for not know what 1/4 Black chain and seat stays meant. 🤓 learning the lingo as I go.
#69
Monkey Boy
Bikes: '22 Surly Straggler, '15 Breezer Downtown EX, '19 Motobecane Record (fixie)
Quoted: 77 Post(s)
Liked 90 Times
This came out while I was deep into considering dropping out of college to become a bike mechanic full time ( spent more time in the shop than I did on homework too ) ! This is a super cool build to follow, and is bringing up so many memories of that era!
Artist | Musician | Bass Player
Life is what happens to you while you're busy making other plans. (o.o)
Likes For RobertUI:
#70
Quoted: 103 Post(s)
Liked 688 Times
New Bars…… not😥
so brain cramp on my part, the new Syncros bar I’ve been waiting for arrived, i was so excited then sooo crushed. The wide clamp portion of the stem will not accept the riser bar. Now what settle for the Titec bar, find a 1” Syncros stem with hinged clamp or a flat Syncros bar with 5 deg sweep. Hmmff I’m not great at being patient and money not endless.
#71
Quoted: 103 Post(s)
Liked 688 Times
A Win
Tried from the bottom but the threaded insert were simply pulling out. So I pondered for a few hours while at work and determined to put nuts under the topside and press from there. Had to really open it up but worked flawlessly.
#72
Liked 13 Times
Likes For tlastrange:
#73
Quoted: 103 Post(s)
Liked 688 Times
All cables up🕺🏼🎉
#74
Quoted: 36 Post(s)
Liked 203 Times
Glad you got the bars sorted! I'd forgotten but have used that trick before myself. Wasn't sure I'd like the riser with this vintage/year build but I think it really works. I typically go with all flat bars on all my 90s bikes. The Syncros bar color and logos really make it work appearance wise and you get a more comfortable riding position, nice!
#75
Quoted: 103 Post(s)
Liked 688 Times
Likes For victorm:
