It is okay to walk up steep hills
#51
Quoted: 377 Post(s)
Liked 221 Times
It's okay to walk if you need to, no shame in doing so.. Just try to go a bit further the next time or heck, even zig-zag it if possible.. Eventually you'll be able to pedal up it and that will be a great feeling..
#52
Quoted: 4570 Post(s)
Liked 5,105 Times
I feel like so much engineering goes into making it faster to climb hills. From ebike systems to lightweight frames, to the gearing drive train systems.
It's okay to just walk up the hill. If you are pedaling up a hill you're also fighting the rotational force backwards so oftentimes it makes more sense from a physics perspective to just walk up the hill.
Basically if you are physically able to pedal it is invariably quicker than walking with your bike.
Likes For PeteHski:
#53
meh
Quoted: 1112 Post(s)
Liked 1,013 Times
I find in practice it has to be a gradient of over 30% before I can maybe walk up it faster than I could cycle. But that's with a lightweight road bike with appropriate gearing. In road biking events I've done over the years I've never seen anyone walking up a hill (while pushing a bike) faster than those cycling, even if the speed difference is small.
#54
Liked 5,105 Times
Agreed that's a different scenario i.e. traction issues. For example it's not uncommon in cyclocross and mtb to walk/run muddy climbs.
Likes For PeteHski:
#55
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2667 Post(s)
Liked 5,882 Times
And climbs with tons of small rocks about the size of golf balls that just give you zero traction. Those are even less fun when descending and doing a tight turn and the bike wants to come out from under you.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
#56
Quoted: 528 Post(s)
Liked 230 Times
But even then, walking up a steep incline on your cleats pushing a bike can't be much less arduous than pedalling up that incline. I dare also say the effort to speed ratio is better cycling than pushing the bike.
#57
Quoted: 4862 Post(s)
Liked 4,008 Times
One of these days, I'll formalize the max grade attainable at steady speed for a given gear inch (GI). (This will assume no slippage and no wheelies. Obviously not always possible.)
#58
Liked 4,008 Times
Now that was deep gravel. Big ball bearings on a hard packed dry clay is another story.
Likes For 79pmooney:
#59
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,099 Times
I don't ride without real foot retention because I hate not being able to pull up and worse, the thought that if the grade exceeds X%, physics says in cold, easy to calculate numbers that I can stand with all my weight on the pedal and I'll still go backwards. (There's a steep pitch on a climb from Portland downtown to the Zoo where I "test" my fix gear's toestraps. Good straps, I can do those two or three full body pulls and make it. Poor straps, my foot comes out and I'm walking.)
I can't wear any foot retention as any "pulling up" against resistance will just destroy my ankles, but I think I climb pretty well. On a road, I never walk unless the bike is broken, and I climb some pretty steep hills. I don't measure grade, though, so I refrain from comparisons.
#60
Bikes: Historical: Schwinn Speedster; Schwinn Collegiate; 1981 Ross Gran Tour; 1981 Dawes Atlantis; 1991 Specialized Rockhopper. Current: 1987 Ritchey Ultra; 1987 Centurion Ironman Dave Scott Master; 1992 Specialized Stumpjumper FS
Quoted: 214 Post(s)
Liked 181 Times
It is also OK to stop and catch your breath. I have a 12% grade on one of my routes home that recently did for the first time a couple of weeks ago (500' in about .8 of a mile. I think I calculated that correctly). (Never again, it sucked in 95 degree weather!)
I did it on both my road bike (no bags) and my SUB (sport-utility bike) with 25 pounds of crap loaded in panniers. I stopped three times on the way up on the road bike, four times (I think) on the loaded MTB. No shame at all. Thirty seconds or so to let the heart rate drop, I usually don't even unstraddle the bike.
Likes For Chinghis:
#61
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,053 Times
In honor of this thread, today I rode the super steep hill behind the football stadium (I think about 30%) in a 34 inch gear and the thing I was watching for was the front wheel lifting up since I was riding in the saddle.
By the way, the last time I did this route I was running a single speed and the speedometer said I jogged up it at 5 to 5.5 mph. I think I was going a similar speed today when pedaling. So I think 30% may be a good guess at the break even point. It helps to be using platform pedals and running shoes if you are going to hop off and hurry up the hill.
Otto
Likes For ofajen:
#62
Likes For Racing Dan:
#63
Quoted: 528 Post(s)
Liked 230 Times
#64
Quoted: 2629 Post(s)
Liked 1,979 Times
Tip: if you try this on a big ride, grab a camera when you stop and turn around like you're about to (or just did) take a picture. Saves everyone who passes asking if you're OK.
Likes For pdlamb:
#65
meh
Liked 1,013 Times
This hill even has a sign!
The fully loaded tandem
#66
Tragically Ignorant
Liked 9,099 Times
Your standing pedal force can exceed your weight, since you can counteract a higher pedal reaction force with an upward pull on the handlebar and not fly backwards (and up) off the bike. (Actually, seated pedal force can exceed body weight and lift your seat off the saddle. This happens to me on steep grades sometimes if I stay fast in a high gear and pull really hard on the bar tops.)
Otto
Otto
To be clear, I'm agreeing with you.
I think standing on the pedals is really the equivalent of running, and your muscles are definitely capable of producing more watts than the simple application of gravity. Not sure how much bracing against the handlebars is responsible for this, I think it's the leaning forward like we tend to do when we run.
Obviously, there has to be a grade where climbing is physically impossible for any given rider or runner. That's why humans invented stairs, ladders, switchbacks, ramps, etc.
#67
Tragically Ignorant
Liked 9,099 Times
That's circular reasoning. If you don't mind walking, then the gearing isn't inadequate. If one doesn't want to walk, but "has to", then you have a point about the granny gear.
#68
Tragically Ignorant
Liked 9,099 Times
On a very hot day, I will absolutely stop for a rest mid-hill. Risking hyperthermia is just not worth it.
#69
Tragically Ignorant
Liked 9,099 Times
Really? Who sez? Several people including the OP (not me, mind you) have posted that they actually like the break provided by walking the bike.
I don't think "a bigger cog on the wheel makes it easier to pedal uphill" is exactly a newsflash to anyone btw.
#71
Quoted: 8378 Post(s)
Liked 9,258 Times
Some years ago I did a charity century and in one flat section the headwind was so strong many riders were walking their bikes, like way more walking than riding. I had never seen that before.
Likes For big john:
#72
Quoted: 214 Post(s)
Liked 181 Times
LOL, that's great advice. But I think you're betraying your age - these days, just hold the phone up and make murmuring sounds. Obviously it was an important call to make, that's why I stopped
Likes For Chinghis:
#73
Cancer survivor (twice)
It’s ok for ME to finish a hill by walking the rest of the way up. Circumstances dictate appropriate actions.
#74
Grupetto Bob
Liked 5,882 Times
#75
Grupetto Bob
Liked 5,882 Times
Now a days, if you stopped to do that a kid might ask, Hey pops, do you need some help how to work that thing.
Likes For rsbob:
