dynohub lighting questions
#51
Je pose, donc je suis.
Hard to say which is a better rating, unless the lux ratings take several targets into account. Otherwise you end up with a low-output, highly-focused beam being the same 'rating' as a high-output, wide one.
#52
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Liked 14 Times
Certainly there are ways to game any system. There's no question that manufacturers can and do game the system (and sometimes outright lie) to make thier product seem better than another. Nothing's perfect.
#53
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Liked 9 Times
However, in the case of taillights, the whole point of them is to smear light all over the place. I run a 3 watt main light and two 2 watt secondary lights. I don't always run all three lights so I figured 5 watts is a good number. I actually probably would only run the 3 watt on the dynamo since the whole point of having multiple lights is that so you can have an entire system fail and still have a light. For the same reason, even if I had a dynamo front light I'd still have to carry at least a hand torch and a lockblock. I've been stuck 4 miles from anywhere in the middle of a snowy, potholed gravel road in the middle of the woods at 4 in the morning before with a dead light, and it's NOT FUN. In that case I had no backup and wound up slowly making my way home by holding my taillight on steady mode in my hand. Also not fun.
As far as new lights being efficient, I suppose the Philips Saferide counts as a new, efficient light. It comes with 2300 mah batteries rated at 2 hours on high. That's 1.15 amps draw at 4.8 volts nominal, which is 5.5 watts power draw. A touch more than the 5 watts I mentioned above (where I was, admittedly, just pulling numbers out of a place).
In any case, if I continued to use a battery powered 2nd taillight, that's 8 watts of draw.
I did think of something else last night on my way home. A lot of the time in the winter (the only time I really need a light), I'm plowing through poorly plowed, rutted mush. I was doing so last night. When the conditions are like this, I'm only going about 7 to 9 MPH at best, sometimes 4 MPH, steering like mad and skidding the front wheel all over to muddle through the criss-crossing car wheel ruts, for 20 minutes at a time. And that's the time when I need the most light, because it's almost impossible to see the potholes through the rutty snow even with a bright light. Also the tail is doubly important on a road where even the cars are mooshing around all over, around bends and hills in the black with full tree cover.
Is a dynamo going to be able to deliver the power at 6 MPH to keep a 1000 lumen light and a 3 watt taillight going indefinitely? 20 minutes is too long to expect a standlight capacitor to hold.
Work: the 8 hours that separates bike rides.
#54
Plays in traffic
Liked 14 Times
I'm also of the opinion that standlights on dynamo lights dim too much and then are easily lost among the background lights of the city, my primary habitat. The last thing I want is to start from a light, having someone turn left in front of me because the standlight disappeared among the background lights and they forgot I was there.
I have a similar situation on my commute--picking my way through rutted streets and trying to assess, "will the hardpack give way and sideslip or not?" and "will the sides of that rut let me move over to the next one?"
I've found the Luxos-U running in its higher power 90 lux mode is sufficient in those conditions right up until low-speed flicker sets in at around 5 mph. Also a reason I run an auxiliary battery light.
There is no perfect system at this stage of the game--either battery or dynamo. The best you can hope for is to put together a compromise.
#55
My diy lights light up brighter at lower revolutions than my Eyc, so much for "German regulations". At my stage of the game, I don't have to compromise. I can get get battery level brightness with dynamo power without ever having to worry about the disadvantages of battery lights, namely charging them, how they function in the cold, and their limited runtime. I also never carry battery lights for short rides anymore, there's no point, I have all the lights I need.
#56
Bubble is not in Germany so their lighting minimum standards are Moot ..
Eyc on my Brompton is fine.... I dont need to blind others, or descend at 50mph..
#57
Collector of Useless Info
I'm getting one of those 12V 6W bottle dynamos, and putting together my own lights from a Costco 5W Cree LED flashlight ($20 for 3) and some custom electronics. The flashlight head goes into an old Royce-Union headlamp with a small rechargeable battery pack, for that vintage look. It will have a USB port, too, for powering i-phones and suchlike.
#58
Keepin it Wheel
Liked 3,753 Times
Directed at the OP, who said he knows "nothing" on the topic: From a quick googling I found that most dynohubs today draw 3 watts. If the OP pedals at 80 watts avg. during his summer trip, that's a bit under 4% of his power that goes into the light. That's not major, but worth noting. In addition, dynohubs weigh 1lbs and up, though the weight is at the center of the wheel, which lessens the power wasted in this (the rotational energy for a heavy wheel is higher, and it's all wasted when breaking...
#59
Keepin it Wheel
Liked 3,753 Times
I'd like to hear more about this. I'm running a cheap-azz flashlight mounted with interlocking hose clamps. I really like how bright it is (CREE XML T6, allegedly 1600 lumens, actually I don't know, but it's like a car headlight), I'm content with recharging 18650s (weekly, and I have a backup pair in the seatbag that will get me home if they fail early). I'm interested in maybe someday upgrading to dynohub, but are there super-bright CREE dynolights out there? Or starting to reach the market?
#60
#61
Liked 3,045 Times
I put dyno lights on one of my bikes last year, and I don't think I'm going back to battery lights except on my racing bike. I'm in the process of putting dyno lights on my other bikes. I like them much more than I thought I would, and I knew I would like them. I cannot perceive the extra drag at all. Maybe others can, but I challenge them to measure that carefully. The convenience of knowing they are going to work is fantastic. I can still mount a battery light if I'm concerned about a failure, but I've stopped doing that. The lights have proved very reliable. I get compliments on the beams they put out, too, which is pretty impressive for a 3W system.
The drag is so low (to me) that I run my lights in the daytime as well as the night. It might make me safer, and it might not, but it doesn't hurt to run them, as far as I can tell.
The drag from a sidewall generator is quite perceptible, so I only run one of those when I really need my lights.
#62
You also tend to recommend things that are the worst bang-for-your-bucks, and what the hell is wrong with your writing style, can you compose more legibly and less cryptically.
#64
Mad bike riding scientist
Liked 4,537 Times
Building a wheel can be expensive, yes. But if you compare the life of the hub to how much you'll have spent in batteries, the hub probably ends up being cheaper in the long run. Better for the environment too. And really, the quality and quantity of light from a dyno hub and some decent lights is better than any battery or rechargeable light I've ever had.
This is what I paid: Lights were from Peter White and I think front and back combined cost me maybe $60 with shipping. The wheel (hub, spokes and rim) was $132, so lets be generous and say it will cost about $200 to get set up. $200 would buy a lot of batteries, true. But I'm really happy with my set up and consider it money well spent.
Directed at the OP, who said he knows "nothing" on the topic: From a quick googling I found that most dynohubs today draw 3 watts. If the OP pedals at 80 watts avg. during his summer trip, that's a bit under 4% of his power that goes into the light. That's not major, but worth noting. In addition, dynohubs weigh 1lbs and up, though the weight is at the center of the wheel, which lessens the power wasted in this (the rotational energy for a heavy wheel is higher, and it's all wasted when breaking, so lighter wheels are better). In addition, setting up a dynohub requires building a wheel around it (or buying one that comes with a wheel, I suppose), which may or may not be a problem depending on the OP's skills and budget. Dynohubs alone cost $100+.
Once you have the dyno set up, it's true that you have one less thing to worry about, and you "won't have to remove your light every other day to charge." Still, I'd recommend investing in a quality flashlight, handlebar mount, and a battery charger, with a couple of spare batteries. Buy them online from dinodirect, t mart, or another such place and you can get the whole deal for <$25. I ride home in the dark 5 times a week and only need to change the battery once a month if that.
Battery systems add a tiny bit of aerodynamic drag...you don't get something for nothin'...but the drag will be tiny comparably.
Watts are a measure of power consumption, not of light output. Using watts to compare light output works only in an apples to apples situation.
If you're using watts to refer to light output, then I'm guessing you're using incandescents of some sort? (Halogens are also incandescent.) Remember that incandesents are very, very, inefficient. It helps to think of them as heaters that give off light as a waste product. Most of the power consumption goes into heating the filament, in much the same way as tube amps use most of their power to heat the tubes.
My first real light was a 10-watt NiteRider TrailRat halogen. Its light output was roughly equivalent to the pair of 200-lumen DiNotte 200-L-AA lights I replaced it with. They draw less than three watts each.
The current crop of LEDs are very efficient. Both my dynamo lights are easily 2x to 3x brighter than that pair of 200-lumen DiNottes, so, their 2.4 watts of power consumption is producing light output easily in excess of a 10 watt halogen--at least judging by my old eyes and memory.
The German lights all rate their output in lux, which is a measure of how much light actually falls on a specific target at a specific distance. It's a much better comparison than lumens, which is a raw measure of light output, not necessarily what ends up on the road.
Same goes for taillights, BTW. The pair of LEDs in my B&M Toplight Line Brake Plus draw a half-watt together, but are easily visible in daytime. This past summer I chased a bike on a sunny day to find out what taillight he was using in the daytime--a B&M Toplight Line Brake Plus. That's why I bought one.
Stuart Black
Stuart Black
#65
Eyc is a kind of a joke, this $50 chinese light washes the Eyc out completely on LOW mode. I've ridden with them both together.
All pissing aside, I love how that site markets an "1800 Lumen" light when the box clearly says "1200 lumens".
#67
Getting 10W out of useful power out of a hub would be real work: 3 Crees in series at 1A -- you're definitely heading down a steep hill.
Overall, at 'typical' cruising speeds, I'm probably putting less than 10W extra into my pedals (2 Crees, Shimano hub) and getting a few hundred lumens. Definitely noticeable difference in power/speed. I could stand to have a little more light, in my opinion, so I supplement with a crappy flashlight (soon to be upgraded) and a battery-powered tail light.
#68
Liked 4,537 Times
And this isn't about "religion" but about data that can be measured and conclusions that can be drawn from that data.
Stuart Black
Stuart Black
#69
I need a LOT more light than any practical dynamo system is going to be able to deliver. I suspect a lot more people are in my situation than want to admit it. I've had quality name brand lignts in the ~120+ actual lumens arena. I've seen people claim these lights are hellishly bright. I don't know but what I do know is the only two wrecks I've had were at night and they happened because I hit something I couldn't see. I'm not riding in Midtown Manhattan. I'm riding in semi-rural suburbia. There is just enough lighted infrastructure to make people think they can pull off a night commute with Nite Rider or Cygolite self contained lights. And maybe you will do it too for months until the night you whack something you didn't see and you fall right in front of someones SUV... crunch. You don't get to tell the DMV that you only drive in well lit city centers so you don't need to spend out for pricey DOT spec headlights. Even if you never drive at night your car better have two of whatever the manufacturer put in the front corners of your vehicle and at least bi-annually you are required to prove to an authority that they actually work. Truthfully, its not even the issue as to whether dyno lights work or not. The issue is that they cannot, in their present level of performance, serve as the sole source light source for a hardcore commuter. So why bother with them at all?
H
H
#70
Keepin it Wheel
Liked 3,753 Times
#71
Everyone here who is anti-dynamo clearly has never ridden a good really bright modern dynamo setup. The gungho dynamo oldies here also have clearly never used any of the newer $50 dual xml lights when they tout how awesome their german regulated dynamo setups are. (german regulated dynamo setups aren't that good)
#72
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Liked 6 Times
I think it would be cool to have a dynamo light system, but it just doesn't make sense in my circumstances. I have 4 different bikes that I regularly commute on. Setting up the wiring and lights on all of those bikes would be expensive and a hassle. I would have to swap my dynamo wheel among bikes or buy multiple wheels. My LED rechargeable light cost about $100 and puts out all of the light I need, and I can easily swap it between bikes. It takes minimal effort to recharge. It weighs next to nothing (100 g). My commute route is also very hilly and long, and the additional weight and effort of a dynamo system would surely slow me down.
#73
Liked 3,045 Times
cyccommute, I guess I'm a dynamo hub person by your definition, however I do admit that there's no newtons. I never implied otherwise.
And the amount of drag doesn't make a difference to me, but of course if you measure it, there will be a difference. I just can't feel it. Mine is a Sanyo, if that means anything in the conversation.
Anyway, you've often listed reasons you like battery lights. I understand them, and I understand they work for you. Dynamo lights are better for me. You're cool with that, right?
#74
Randomhead
Liked 4,049 Times
Putting on my moderator hat, this discussion is way too bitter for the subject at hand. Please tone it down a little.
#75
Liked 4,537 Times
Stuart Black
Stuart Black
