#8327
Bikes: A few too many
Liked 2,193 Times
I have 4 office rooms plus a warehouse. The room behind the window opening is the actual office area. The rest of the rooms are storage/extra rooms. They have bike stuff in them also. It's very nice. I've got to get the main bike room organized, as well as the one with the blue Lejeune.
After the headset servicing, I am working on the Team Miyata and the green Mixte for my son and daughter respectively. They are tired of walking the neighborhood and want to bike instead. I rotate rides on the various bikes. At the moment, I am having to rob parts to get bikes ready for the wife and kids.
Ben
Last edited by xiaoman1; 03-29-20 at 11:28 AM. Reason: counting the rolls of T.P. and googeling the address
#8328
How to mechanic Headset bearing service time!
With the aero levers, limited housing, we have to remove the front brake cable. Turn the fork for easier access. 5 mm Allen head is the size.
#8329
How to mechanic headset bearing service continued.
Use an adjustable wrench to loosen the headset lock ring. The ruler on top of the wrench shows 11/16" or metric equivalent. Use a 6mm Allen wrench to loosen the handlebar stem bolt. Pull the stem out and move to the side. You might have to put some penetrate to loosen the stem. Don't use PB Blaster. This headset has rubber seals. The PB might eat them up. WD40 will work.
#8330
Remove the keyed washer and the top part of the headset. Take a picture for future bearing placement reference. Remove the bearings and put them in cleaning solution.
#8331
Next, hold the fork/wheel and flip the bike over. Remove the wheel, then the fork. Take a pic of the bottom bearings configuration for future reference.
BTW, fork is stamped with Tange 5L Made in Japan.
#8332
How to mechanic BB service continued.
Now to the fixed cup. If the fixed cup is on the bicycle, getting the loose bearings back in is no easy task. Here is how to do it. Lay the bike on it's drive side with the open/adjustable side up. Use a plastic knife or something and grease up the bearing race going in through the top opening. Take the bearings one at a time and push them up through the opening in the fixed cup into the greasy bearing race. Use a screwdriver in the other hand from the top to help guide them into the race. For caged bearings, put them in from the top. Note the correct alignment.
#8333
It will, but I don't know the correct size. Someone else will answer that. RT or rccardr should be able to go over your options.
#8334
Next, clean the cups/bearing races/bearings and check them for pitting, brinelling, etc. Be careful with the seals. If the seals are shot you can find an O-ring that will work. In fact, one of my vendors makes one that works. Contact me if you can't find a replacement.
#8335
If you have some bare/rusty spots on the bottom of your frame now is a good time to to touch them up with rust stopping primer.
#8336
Hopefully, the cups/bearings are in good condition. Time for reassembly. Grease up the lower bearing cup. Insert the bearings using the pic you took as reference. Put some more grease on top. Insert the fork.
#8337
Next. Mount the front wheel the front wheel and flip the bike back over to the original position.
#8338
Next, grease up the upper cups and insert the bearings correctly using the pic you took for reference. Connect the cups and screw the cup onto the threaded tube. Put the keyed washer on and the lock ring also. Hand tighten.
#8339
Take the expansion bolt out of your stem and clean it. Clean the stem also. Put some grease on the threads of the expansion bolt and reinstall.
Cinelli stem, sweet! Is that OEM?
#8340
Reinsert the stem/handlebar assembly into the headset/tube. Hand tighten the top bearing cup until it snugs up and you feel resistance. Check that the fork is not loose, but moves freely. Similar to the BB bearings you want the magic point with some bearing load. Not loose, but moving freely. When you find it, tighten the lock ring down while holding the upper cup steady. This is tricky because the tool for the cup has to be thin. I am using a big pair of vice grip needle nose pliers with thin fingers.
#8341
After getting the lock ring tightened, align/adjust your bars and tighten your expansion bolt. You are done!
We still have to do the hub bearing service and some other minor services. I'll do the hub bearings in a day or two.
Questions or comments? As usual, get them posted.
#8342
Nice write up Pat!
I would also add that you cover the stem with grease where it will be inside the fork steer tube. this will help prevent the dreaded "Stuck Stem" syndrome.
Good job Seypat, where were you 30 years ago?
BTW, cenelli stem is not OEM to the '86 Ironman, the Nitto stem is.
#8344
Cinelli stem, Nitto bars. Stock looking bike. Doubtful the PO changed it. Someone did in the past. My gain.
#8346
BB-6207 600 series. 116mm
BB-1050 105 series. 113mm
You will need the Shimano cartridge BB that replaces those.
#8347
Well, I had to service the hubs on the Miyata, so I decided to do the ones on the project loaner IM. Good news and bad news. The bad news first. One of the hub cones is pitted. It will need to be replaced as well as the bearings.
The good news a cone is pitted. The cones and bearings need to be replaced. We get to go through the process of finding the replacement parts and learn from it. When I get the parts in I will finish and post the procedure.
#8348
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Liked 175 Times
Can I swap my 6-speed MF 6208 (13-21) for a 7 speed freewheel? Maybe something with a bit more low end?
Would the width be the same, or close? Will my 600 shifters have enough clicks? (Front is a 53/42 Biopace.)
