Addiction 2022.2
#8601
Bikes: Shmikes
Quoted: 10218 Post(s)
Liked 5,934 Times
Likes For MoAlpha:
#8602
Quoted: 10301 Post(s)
Liked 5,273 Times
#8603
Quoted: 8419 Post(s)
Liked 9,330 Times
#8604
Bikes: Shmikes
Liked 5,934 Times
Yup. That’s the ride. We are in Portsmouth RI.
#8605
Liked 9,330 Times
A lot of the older areas have roads made of concrete. These roads can be some of the worst with sharp edged and heaves and huge cracks. This is earthquake country, after all.
It costs a lot to fix roads and we have a lot of roads that need fixing.
Likes For big john:
Likes For Jack Tone:
#8607
Quoted: 9678 Post(s)
Liked 6,394 Times
Likes For Mojo31:
#8608
Liked 6,394 Times
#8609
Bikes: Shmikes
Liked 5,934 Times
#8611
Liked 6,394 Times
Boat name again?
#8612
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
What??? Where is this coming from?
The problem in north and central Texas is that the soils are predominantly clay. During wet months it absorbs water and expands. Then in dry months it contracts to the point of large cracks developing. Those cracks pass through to whatever is on top of the soil.
Putting more sand or gravel between the dirt and paved surface does not really help because then the base is not stable. Buildings are built on engineered slab foundations that include piers where appropriate. The piers either bottom on rock, or they are drilled deep with bell shaped bottoms (in this case they depend on friction so as not to move up and down). It all works well if designed and maintained properly.
People run into issues with their foundations when the soil around it is not kept uniformly moist throughout the year. You simply cannot let it dry out in the summer. That’s why irrigation systems and well-designed drain systems are so important.
We have had zero foundation issues in 14 years in our current place, and no issues with our pool deck or pool she’ll. The foundation is rock solid. We also make sure soil moisture levels are maintained as much as possible. That requires maintaining the landscape so the plants don’t suck all the water out of the soils around the foundation.
The soils do suck, but they can be managed.
#8613
Liked 9,330 Times
I met him out on the road bike. He was friendly enough but wanted to go more than he wanted to chat. Some of my friends have ridden road bikes with him. That's the extent of my interactions with the Hi-Torque guys.
Likes For big john:
#8614
VFL For Life
Bikes: Velo Volmobile
Quoted: 28878 Post(s)
Liked 1,898 Times
#8615
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
#8616
Liked 6,394 Times
When you get into the hills it gets different since you have areas of very stable limestone with pockets of unstable clay. That presents some foundation engineering issues.
The problem is that a lot of volume builders will throw a slab foundation down that is only supported with grade beams. It usually takes piers to have a stable slab. Piers are expensive.
#8617
Bikes: Shmikes
Liked 5,934 Times
#8618
Quoted: 3392 Post(s)
Liked 3,745 Times
Weird. They were showing so much in stock at the time. I blame abshipp , of course.
When I ordered it showed 4 in stock, and they appeared to ship from HK, may explain some communication/inventory delays. I didn't get a ship notification for about a week after my order.
That's super frustrating that you and Trsnrtr aren't getting yours
#8619
Liked 3,745 Times
#8620
Quoted: 530 Post(s)
Liked 230 Times
Here in the Los Angeles area it's really a mixed bag. Some areas have beautiful road surfaces while many others are terrible. Some major roads are broken and full of holes with big chunks of asphalt bouncing around. Some of this may be due to roads which were built as residential have become carriers of tens of thousands of cars and trucks.
So likely is that it isn't possible givennature (freeze and thaw in the north that messes up the road, earthquake as you describe it that breaks it, some mentioned poor soil underneath the roads in Texas).
#8621
VFL For Life
Liked 1,898 Times
#8622
VFL For Life
Liked 1,898 Times
#8623
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3305 Post(s)
Liked 1,915 Times
Wordle 4/6
I didn't know it was a word in English. I have that problem with Wordle.
#8624
Mostly Harmless
Bikes: Have two wheels
Quoted: 13785 Post(s)
Liked 4,623 Times
Just because you don't know the reason doesn't mean there isn't one. You should call the power company and demand answers.
#8625
Liked 1,915 Times
I had blood drawn this morning. An older woman ahead of me signed her name with her thumbprint. Not at all uncommon here.
#differentworlds
#differentworlds
