Show your Trek Multitrack!
#901
Work in progress, but my 2x7 to 1x10 is already done
Up next: shorter stem, bartape, and in the longer term a paint job
This will be my winter-gravelbike.
#902
Quoted: 1461 Post(s)
Liked 2,096 Times
Likes For t2p:
#903
Good work! A good mix of the old and the new. I used the same threaded to threadless stem adapter and it works pretty well IMHO. I've also switched back and forth between flat bars and drop bars. I also did the 1x10 conversion with updated wheels. I look forward to seeing any other mods that you make.
#904
WV is not flat..
Just finished the clean and tune on this 750. Such solid well riding bikes.
Likes For hokiefyd:
Likes For Tradarcher:
#907
Bikes: 1993 Giant Rincon, 1993 Trek MultiTrack 720, 1977 Raleigh Super Course, Giant Innova, 1995 Trek MultiTrack 700 (stolen from my possession but still mine!)
Quoted: 18 Post(s)
Liked 12 Times
#908
Would anyone know what's the chain line on MultiTracks? 1991 750 in particular. Looking to get a new crankset for mine.
I wanted to share some photos of my 750 but I cannot post with photos still
#909
My second convert in a week. This time, it was my sister. I saw a 750 on FB marketplace for $50 and went on and on about how great these are to my sister and she figured, at $50, why not? But the seller never responded. Then I saw this frame listed and asked if she'd wanna build a bike. So now we're building a bike. I already had the racks and cages, so I threw them on because they were just sitting around.
(The clamp isn't pressing down on the top tube, just cradling it.)
How do you find these fresh Multitracks in FB marketplace? Is there a specific word you include when searching?
All I could find are really beat up or maybe it depends on the location.
#910
nivekelyk Not sure where you are located but in many parts of the country you'll see a few nicer Multitracks popup up per year on Facebook marketplace and/or Craigslist. I occasionally have seen them in stores that carry used bikes as well. If you have the patience you can setup your search range to the distance you are willing to drive to get one and get in the habit of checking what's available every few days and you'll find one eventually. I wouldn't rule out the tig 750s as they are nice rides as well and some of the components are easier to mix with newer stuff since they run Shimano and not Suntour (the lugged 750s were mostly/all suntour I think).
Of course, someone watching this may have one that they are looking to get rid of as well so it's always worth asking like you did.
#911
Bikes: '72 Raleigh Super Course; '90 Cannondale ST1000; '98/99 Cannondale T700; 2002 Cannondale CAAD5 R700; 2022 Cannondale Topstone 2L
Quoted: 170 Post(s)
Liked 364 Times
I recently built up this mongrel; a 520 frame with a 790 fork that had eyelets brazed on. It now has grips, a black Brooks Flyer, and a matching set of 700x43c Gravelking SS's. Currently installing some Velo Orange Zeppelin fenders, but I need to trim the rear fender where it meets the chainstay bridge to get clearance.
Likes For Rooney:
#912
Quoted: 39 Post(s)
Liked 31 Times
Tire Size Fitting
Hello all, my 90, 750 will fit 45mm front and rear, probably larger.
Question; do all steel MT frames fit tires of 45 wide without fenders?
Thanks Ruben in So Cal
#913
Clark W. Griswold
Quoted: 4520 Post(s)
Liked 4,220 Times
Basically check your frame or a frame you wish to purchase and go from there. Generally if it is the same year and model likely it will have the same clearance at least for the middle and larger sizes sometimes smaller sizes might run into some issues not always but sometimes. Measure twice cut once!
Likes For veganbikes:
#915
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 766 Times
The simple answer is no. I have a 1997 MT 750 and I might could squeeze a 45mm tire in there without fenders, but it'd be very tight. A 42mm would be tight. It'll comfortably run 38s or 40s but much larger than that is more difficult. It's also more than raw frame clearance. If I fit wider than a 38mm tire on my MT, I have to deflate the tires to remove the wheels to clear the front brake pads. You can get special short-style pads to help clear fork blades, but it's definitely a consideration (brake pad clearance).
#916
Liked 766 Times
After thinking more about the frame clearance I really have on my '97 750, and seeing just what actually would fit, I dismounted the 35s I had on it and tried something larger. Much larger. I have a set of 29x2.0" first generation Schwalbe Hurricane tires from a previous bike in my tire pile, so I dragged those out to see if they'd fit. On my 750's rims (which are only about 15 or 16mm internal width), the tire casing/carcass itself measures about 44 or 45mm wide and tall, though the cosmetic knobs on the side do push the overall width to an actual 50mm. But as far as the tire height goes, it's about 45mm above the rim edge...so likely similar to a 45mm tire that actually measures 45mm.
They did fit in the bike...like...barely. I did have to have them mostly deflated to slide them up between the brake pads, but they do fit, and actually ride pretty nicely. Traditional fenders would not fit on this bike. The clearance is tightest down at the seat stay bridge near the bottom bracket (and front derailer area), and there's not enough room to fit fender mounting hardware down there (with the tire in place). The brakes are Tektro Mini-Vs (to work with the factory short-pull levers), and the brake cable yoke just barely clears the tires...there'd be no problem here with longer brake arms or with cantilever brakes.
Pictures below. Again, except for the side knobs, these are basically 45mm tires.
Likes For hokiefyd:
#917
Bikes: 1974 Masi GC, 1982 Trek 728 (aka 720), 1992 Trek Multitrack 750
Quoted: 124 Post(s)
Liked 235 Times
#918
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1325 Post(s)
Liked 3,790 Times
Here is my mid-90s 750. Just a fantastic bicycle, rides so smooth. Looked everywhere for some mx style handlebars, and something that would work with a 31.8 stem. Then I found a pic and the owner graciously responded back and said that they were Cannondal Cruise Control bars. Finally found a pair a few months back and it has improved the ride quite a bit.
#919
Quoted: 5926 Post(s)
Liked 3,599 Times
1993 Trek 750
I've been trying hard not to pick up more bikes but I couldn't turn down this pristine Trek 750 when it popped up last fall at $125. I stuck it in the garage and pulled it out recently to take a few pictures. I haven't decided on the build yet but I'm strongly leaning towards trekking bars. They're comfy and versatile.
This is how the bike came to me in the wild. Bit of an odd set up with the drops and thumb shifters but otherwise the bike is pretty much all original. I picked up a set of Schwalbe 700 x 38c green guard tires to turn this into a trail and gravel bike. I plan on bringing it along on car camping trips in the summer and I wanted stout tires especially for riding out west where the goat heads are plentiful.
The cantilevers will need to go but I may keep all the other parts other than the pedals. They're not top of the line Shimano parts but they work fine and the cost is right. I've overhauled the wheels and they're in great shape. I need to overhaul the headset and replace consumables. I'm a big fan of Treks and this is my 5th (!) lugged steel Trek (3 road bikes and a 1992 950).
I'll pick up a set of MKS Allways pedals. They're a little pricey but MKS makes great pedals and this is a good design. I'm not sure what I'll get for cantilevers. I really like the Tektro CR720 cantilevers; they're cheap and they work great but it looks like Tektro has discontinued them. I suspect I'll hunt around the parts bin and go with what I have on hand.
Likes For bikemig:
#920
Happy banana slug
Quoted: 1561 Post(s)
Liked 1,577 Times
@bikemig, I like the Tektro Oryx's on my RockHopper; they stop the bike and look stylish doing it.
Likes For Korina:
#922
Quoted: 583 Post(s)
Liked 1,030 Times
Winter is long over here in NY; was a very mild one overall. Time to put the winter bike away. Here you can kinda see the full length liners on all the cables, which have done a great job of keeping the cables clean.
#923
Cantilever believer
Quoted: 567 Post(s)
Liked 1,961 Times
Just finished fixing up this 750. I think this one is from around 1991ish from the component date codes. It looked like heck when I got it, but it cleaned up nicely. Full Suntour XCE, except it came to me with a set of thoroughly trashed Grip-Shifts. The cleanup & rebuild went fine until selecting replacement shifters - the Accushift cassette would not play well with the Rapidfire or GripShifts I tried on it, and I had to break into my Emergency Strategic Component Reserve and commit a set of XC Pro thumbies to it in order to get decent shifting.
Update: I swapped the XC Pro thumbies for a pair of refurbished X-Press shifters, which worked fine; however, the bike has gone on to a new home as a bike for a local teen who is a friend of a friend. I hope it does well for many years to come.
#924
Quoted: 124 Post(s)
Liked 235 Times
Trek Bike Models by Year and Color
Likes For HelpSingularity:
#925
Bikes: Most of my bikes are Single Speed Conversions
Quoted: 267 Post(s)
Liked 3,067 Times
I put my MultiTrack 730 back together today and took it for a short spin around the neighborhood.
probably the lightest bike I own .
