For the love of English 3 speeds...
#9626
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Liked 445 Times
That appears to be a Glider version of the 5 speed sprite and somebody removed the derailleur and the rear brake.
Raleigh 1969 Catalogue from RetroRaleighs page 03
You'll notice in the catalogue that they all came with leather saddles as standard equipment.
#9627
That's why they labelled the shifter as 'Low - Normal - High'. I tend to use Normal for most of my riding. It gets me about at 10-12mph and feels 'nicer' than the other gears.
More 'normal' even.
#9629
Liked 445 Times
#9630
Pashley Courier 3 speed anybody?
I hope this one is in the spirit of the thread, being 'modern', but it is an English 3 speed & I see no mention on BF anywhere.
Something different for the weekend, perhaps?
Has a tough, steel frame, with 24" (47 x 507) wheel at the front, 26" (47 x 559) rear.
Sturmey Archer X-RD3 & X-RF, with hub brakes.
Quite a versatile carrier, but I ride it often with just the rear rack fitted, as a town bike, & it rides like a traditional 3 speed roadster for me: )
I can add a conventional wire basket on the front, or the 'full monte' with the cradle & basket/box for heavy duty work. (Five minutes to install/remove)
It's pretty much standard apart from the trigger & chain-wheel/guard.
(The original was pretty 'Tacky' with a brittle, plastic enclosure.)
#9631
But keep that front carrier on! Because a front carrier bike doesn't look right without the front carrier.
#9632
#9633
Bikes: My Bicycles. 1950's Dawes Unknown model, 1959 Triumph Palm beach tourist, 1960 Raleigh Trent tourist, 1967 Sun Snipe, 1976 Raleigh Scorpio (sold), 1980 Raleigh Transit, 1980 Carlton Grand Prix, 1983 Triumph team leader, 1984 Raleigh courier
I was given this rather tatty 1984 Raleigh courier yesterday, it's a 23" frame but seems really big! If I stand it next to my other 23" bikes it's a good inch taller. I did think maybe the wheel size was different but they are all 26" so maybe the frame geometry is different?
#9634
Your other bikes are probably 26" "mountain bike" aka 559 rims and the Raleigh is 26" old 3 speed aka 590 rims. So 31 mm difference in rim height or close to an inch! I like the back rack!
#9635
The guy I got the bike off is a frabricator so I suspect he made that out of scrap he found lying around
#9636
What is the current verdict on the Sturmey Archer DT shifters? I am planning to equip my 1985 Peugeot PH-11 with an AW hub from 1980, and DT shifters would be my preffered configuration. Why 3 speed on that bike, you ask? It's got 122mm droput alignment and the derailleur hanger is bent, because the rear mech caught the spokes.
#9637
Pls show pics as the project moves forward.
#9638
The hub's got the long axle and is spaced for 120mm, so I don't even need to re-align the dropouts, I just need to get a wheel built and get the shifters and anti-rotation washers, so this will be an easy project. I even calculated the weights, the bike will weigh exactly the same as before as 12 speed, so around 10,5kg
#9639
#9640
Old Boy
Liked 1,716 Times
A Brief Respite From Winter
I began training this morning for the Lake Pepin 3-Speed Tour. It was a balmy 36°F, headed for a high of 57°; I'll be in shorts this afternoon.
Took ye olde Roadster out for a shakedown cruise, and ended up at the local pond:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Everything works well but the brakes. I installed the Kool Stop salmon pads, but I don't think I have them adjusted properly. The fronts grab and let go, sort of a juddering sensation, but at least they slow and stop the bike. The rear brakes don't want to play yet - I squeeze the lever to the bar and all I get is a mild bit of drag, hardly enough to impede forward progress. I guess I have to learn how to set these up better.
Other than that, it was a very plush ride. I'm really looking forward to the `Tour.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#9641
Senior member
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#9642
What a nice roadster! Love the tires, they look great. Yellow Jersey has some good rod brake pads you might want to try. I like the Fibrax. A bit pricey, but good. Still, rod brakes is rod brakes.
Some Vintage Brake Parts from Yellow Jersey Raleigh Modolo DiaCompe Zeus Campagnolo Mafac
#9643
Everything works well but the brakes...Other than that, it was a very plush ride. I'm really looking forward to the `Tour.
#9645
Old Boy
Liked 1,716 Times
But it's a good kind of pooped...
#9646
Old Boy
Liked 1,716 Times
Since I posted earlier, I've improved the situation quite a bit with some adjustments. It's really a straightforward mechanism, but there are some subtleties to it. Cleaning both wheels with alcohol seemed to help, as did tightening up the pull on the rear brakes. As the pads bed-in, I imagine it will get even better.
#9647
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Liked 177 Times
I have the SA 3-speed bar-end shifter, and it's quite precise and crisp. It's also usable as a down-tube shifter by removing the bar-end pod. In short, I like it a lot.
#9648
On the road
Bikes: Old Schwinns and old Raleighs
Liked 948 Times
Shaping up to be a nice weekend here in Virginia. Almost 50 today, and supposedly 65 tomorrow. I'm currently riding mostly this 1946-47 Hercules roadster.
The Bike Shed: The Season Approaches...
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
#9649
Liked 445 Times
#9650
Liked 445 Times
