Carbon Fiber Bikes - the material science
#76
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 690 Post(s)
Liked 1,021 Times
Maybe French boutique steel frame builders are not the right business when looking for a carbon repair.
Carbon repair in France is definitely a thing though, as you might reasonably expect with many thousands of carbon bikes sold there. First Google result:-
https://www.sportscarbone.com/en/reparation.php
#77
Quoted: 8449 Post(s)
Liked 9,409 Times
Likes For big john:
#78
Steel is real
Quoted: 690 Post(s)
Liked 1,021 Times
#79
Mad bike riding scientist
Quoted: 6297 Post(s)
Liked 4,333 Times
Steel is easy to weld … if you have a welder …. And are really pretty good with it. Modern bike frames are pretty thin-walled, as others have mentioned. Welding is a skill, and whiel you might be able to weld a couple reinforcing plates onto the frame of your pick-up truck, but good luck with a tube thinner than a tin can. Also, you might want to build a frame jig, because if the tubes twist a little as they shrink after heating ….. .
CF? Yes, I can do home repairs with Carbon Fiber, and it really is about as easy as wood-working. Much easier than metalwork. Does that mean that it is easy? Heck, no. The edges have to mate perfectly, or you have to fill in gaps with layers of cloth, and you have to make sure the cloth is completely impregnated with epoxy …. Even if there are several layers of cloth. And again, if the frame twists as it dries …. Or if the person didn’t line up everything perfectly … then the frame will be out of line. Or, the frame will look fixed but still be weak …. Or the repair will be sloppy and heavy and ugly ……..
CF is indeed and by far the easiest material to repair at home … but repairing a broken bike frame is never going to be that easy … unless to fix it with money.
Stuart Black
Stuart Black
Likes For cyccommute:
#80
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,116 Times
Even so it's a design escape, not a problem with steel per se, which was my original point. Choice of which steel is part of the design, and if they think it's ok to make that feature from the material they ordered, and it isn't, that is an error. The design was changed.
Genesis 49:16-17
Genesis 49:16-17
#81
Liked 4,333 Times
A carbon tube repair would be less than the paint job to repair a steel tube replacement. I've only had one fixed but have considered buying a carbon frame where the idiot in the shop crushed to top tube and I did get a quote for that replacement, so, I am pretty confident in my statemen
When the one steel frame that broke on me could not be fixed in Los Angeles, I learned my lesson. The idea that anyone with a torch can repair 531 is hogwash.
Stuart Black
Stuart Black
#82
Habitual User
Quoted: 5120 Post(s)
Liked 8,458 Times
I get it now. You were just guessing about something you really don't know about. It seems like you expanded your knowledge a bit.
Likes For Eric F:
#83
Quoted: 4645 Post(s)
Liked 5,180 Times
#84
Steel is real
Quoted: 690 Post(s)
Liked 1,021 Times
Because you never crashed with them or maybe that you ride carefully and on a side note all your bikes in your signature are not dating from the mid 90's but are all 4 years old at least. So my question is why haven't you kept your old bikes??
#85
Quoted: 1291 Post(s)
Liked 1,392 Times
Not according to this business. Compare that to the prices from Rodriquez Bicycles for steel repairs. All of the prices are without paint which adds significantly to the cost.
On that I fully agree…for any frame material. The idea that you can do a reliable repair of carbon fiber in your own home is on a par with the idea that any village smithy can make a permanent repair on a steel frame or use JB Weld as for a frame repair. ‘Tis a silly idea. Have a professional repair the frame if the frame is worth repairing. Few bicycle frames, however, are worth the extra cost of a proper, professional repair.
Likes For Atlas Shrugged:
#87
Habitual User
Liked 8,458 Times
#88
Habitual User
Liked 8,458 Times
EDIT: I have a CF MTB frame that I bought new in 1999. It's been crashed more times than I can remember. I had never needed repair, still gets ridden regularly, and still rides great.
#89
Quoted: 7740 Post(s)
Liked 3,691 Times
Just face facts. Most people never break a bike frame unless they crash hard, and in a hard crash any kind of frame might break. And most bike frames get traded or sold or thrown away after a lifetime of unbroken service.
How about YOU show some facts? You have told some lies, now post some facts. Where is your third-party-supported evidence that some sort of bike frame fails more often in normal use?
A lot of people have bikes less than four years old ... they sold or traded their old bikes or gave them to friends and got newer, better technology. Not because the bikes broke, but because they wanted more tire clearance, 12-speed or electronic shifting (or both,) or disc brakes, or just new bikes ....
All of the bikes in my signature are more than four years old ... my oldest CF bike is a 2015 Workswell which is still in excellent condition after eight years ... and sadly I have crashed a few times on it, and a few times on my other CF Workswell. Sorry for you, neither broke.
Maybe just learn the actual facts: CF, steel, aluminum, and even bamboo are all materials used Successfully for bike frames, and any bike made from any of those materials can last a very long time. Sorry for you .... but it is a demonstrable fact.
Of course, any bike can be broken, no matter what it is made of ... if you get hit by a car, run over by a truck, lose control on a very high-speed descent, hit a hole or a deep ditch or whatever .... you can break whatever you are riding.
Facts: .... There re are bikes. Bikes demonstrably exist. Bikes can be made from many different materials. This is provable. Those bikes can all last a long time and this too is provable.
Likes For Maelochs:
#90
Liked 5,180 Times
I rarely crash too, which always helps.
Likes For PeteHski:
#91
Liked 1,392 Times
Keeping these old bikes in is not the issue what is a reality is these old bikes are not ridden for any distance or regular frequency. Most keepers of C&V bikes have numerous bikes, and the acquisition and ownership is the goal, not riding one particular bike. Go to any place cyclists frequent or mass participation events, and the number of older bikes is very few to nonexistent. Sure from time to time there are show and shine type of gatherings where the key purpose is to display their rides.
Likes For Camilo:
#93
Liked 3,691 Times
Troll feeds popcorn to corpse of horse while yelling at clouds.
Likes For Maelochs:
#94
Liked 4,333 Times
Dude, give it up. You have been proved to be talking about things you don't know about already .... don't keep doing it.
Stuart Black
Stuart Black
#95
Liked 4,333 Times
And, since most C&V riders are retrogrouches by definition, they probably aren’t likely to attend most mass participation events.
Stuart Black
Stuart Black
#96
Is there any way to know the quality of the carbon frame? I mean not the knockoffs. Even the major brands, even those brands that appear in the Grand Tours.
What I see is the price of frames with the major manufacturers. A company such as Specialized has different price levels, as do many other brands. The guesswork is to look at what are being used by the teams in the Grand Tours. Even then, the manufacturers may have done something special for those teams that they support.
#97
Liked 3,691 Times
On to bikes .... where the "rule of thumb" might be, "If it broke, they are getting sued and going out of business."
No one ever knows or ever has known anything about the specific frame on thee specific bike s/he bought. No idea if there was an electricity surge and the robot welder didn't penetrate or the hand-welder was hung over, or whatever. No one ever knew, and no one knows now.
However ... there have been recalls, when a certain number of a certain model of frame or fork failed in large numbers ... so stuff happens.
If nothing ever went wrong there wouldn't be recalls. But there are. Why? ... to avoid lawsuits.
If a manufacturer produced a lot of frames or forks which failed in an unreasonable fashion, said manufacturer would be facing class-action lawsuits. Said manufacturer would go broke (or declare bankruptcy to escape form paying.) So ... if you are buying a frame from a company of which you have heard, it is probable that you are buying a frame which will suffice for all your cycling needs.
Seriously ... do you know what the frame of your car is made of? Do you question if the frame is sufficient? When is the last time you thought about it?
I am not saying that you should not waste your whole life worrying about nonsense. You are free, and may waste your life in any fashion which suits you. I am poking fun at people who go on and on about baseless imaginations with illogical and fact-free thinking.
I didn't ride today ... my legs were sore from yesterday. I am looking forward to riding tomorrow. I am well aware that as it happened today, it is my physical failure, not my biker's which is likely to limit and one day end my time as a rider.
Type less, ride more,. Don't worry, you can still obsess over imaginary dangers while you ride, so the time won't be totally wasted. Difference is, when you get back, you might be too tired to share your obsessive worries with us.
We will soldier on. Don't worry.
Likes For Maelochs:
#98
Liked 5,180 Times
If you buy a carbon frame from a well known major brand like Specialized you can expect it to be safe and of reasonable quality. The higher end frames are simply lighter and sometimes stiffer.
#99
Liked 1,392 Times
I find it amusing that those most concerned about the longevity of carbon are pretty far along themselves. A 60 year old bemoaning that carbon is only good for twenty years or Di2 parts are going to be difficult to source in their 80th year
