Yet another try at "Is carbon faster?"
#76
Quoted: 6556 Post(s)
Liked 58 Times
Buy these are generally not, particularly on stock bikes. Additionally, shape and certain structural characteristics of carbon fiber frames are difficult to achieve with aluminum and steel. Keep in mind also that for some reason, top end aluminum bikes just aren't spec'd as well as carbon fiber bikes.
He didn't ask if he could upgrade all of his components, buy better wheels and tires, and commission a hydroformed aluminum frame, would that make him faster. He asked if someone having an aluminum framed bike, not cognizant of all of the details that make a bike and rider faster, could expect more speed if he bought a "nice carbon bike".
rpenmanparker's suggested testing method would work, is valid scientific method in my opinion, but wouldn't answer the question. If you really want to know the answer, take a number of representative bikes, put power meters on them, and run the tests. Or else ask the cyclists who have experience with upgrading from an aluminum bike, as OP did.
#77
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Or you could take it with a grain of salt, and note that a large preponderance indicates a likely result.
#78
Super Moderator
Quoted: 1175 Post(s)
Liked 938 Times
Some of us suggest that rigorous testing protocols may show if one frame material enables a bike to go faster than a different frame material.
Others think that riders can feel the difference, and we should accept their "feeling" as a conclusion.
OK, difference of opinion here I guess.
#79
Bikes: Ritte 8055, Felt TK3, Cervelo S2 & P3, Giant TCR
It looks like he's saying that you're putting artificial constraints on the OPs question. Don't really know for sure though and the "study" is flawed anyway, if you wanted to know if you'd ride faster the riders would need to ride at the same W every day to ensure a valid test, since the OPs W is presumably the same day to day
#80
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
i do go faster on my carbon.
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
#81
Bikes: 2009 Kestrel evoke SL frameset with SRAM Red/Force 22 components
Interesting question, and one without a simple answer. I can say that I personally rode a Felt Z4 carbon bike after riding a Felt Z85, which is a decent practical comparison between carbon and aluminum, with the same geometry by the same manufacturer but different materials. I was certainly able to ride more quickly on the Z4 because it was less jarring, so I felt better pressing harder. The ride was more comfortable, so I was more comfortable riding at a higher speed. Is the carbon frame itself "faster" than it's aluminum brother? Not likely. Did it allow ME to go faster? Definitely.
#82
Super Moderator
Liked 938 Times
Yes, it would be very difficult to actually carry out a valid test. But saying "I feel faster" is not much of an answer. At least testing, if possible, would give a legitimate answer.
You'd need to set up a robot cyclist, putting out a constant wattage, in an indoor velodrome, on the various bikes, then measure the elapsed distance after a specific time.
#83
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
i don't just feel faster. i am faster by half an hour over 100 miles.
#84
Super Moderator
Liked 938 Times
How many centuries have you ridden on each bike ?
And what are the differences between your bikes : Wheels ? Tire pressure? Fit ? Body aerodynamics ? Weather conditions ? # of poops each day ? sleep the night before ? hydration ? nutrition ? Were you on the drops/hoods/ tops the exact same amount on both bikes ?
Plenty of factors than can have a cumulative effect.
#85
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
the faster carbon rides are consistent.
#86
The truth is, almost any scenario can be picked apart. The problem with a velodrome, in your example, is that it would essentially be constant speed, as offered by constant wattage from a robot. So except for the initial acceleration, there wouldn't really be much in it, because after that the bike would reach steady state, and unless one or the other were significantly "lossy" due to flexure, they would be roughly the same. The reality is that you would need to engineer two largely identical frames to have the same deflections under constant load, and basically test them under dynamic load with your robot, to see if they performed differently dynamically. The lore of a Ti frame, for example, is that under small deflections the frame will "give", but Ti stiffens under larger deflections, so it rides comfortably over road imperfections, but is responsive when accelerating or climbing.
Now, a robot that could ride all the hills and descents and flats of the Tour de France by itself, once with a steel or aluminum frame, and once with a carbon frame, that would be a start. You think Google would hook us up with the test equipment?
#87
Super Moderator
Liked 938 Times
Miguel Indurain ?
#88
Bikes: Cannondale CAAD10 Team, Giant TCR
... Say Joe Schmoe does his normal weekend hard 50 mile ride on his steel race bike. He always goes "all out" on this ride. He always tries to beat his personal best time. He buys a nice cf bike, say a Madone or something, with similar components and wheels to his steel bike. Does easily beat his personal best? ...
Geometry, positioning, components, wheels, placebo.
Buy these are generally not, particularly on stock bikes. <sic>
#89
Liked 58 Times
I should say that I accept all the implications of using a particular material in producing a faster or slower result. So CF's ability to be shaped to a greater degree as well as laid up with complexity not possible in the metals would be necessarily inherent in the frame chosen and the result obtained. I regard that as a component of what we mean when we say CF bike. Same for the relative limitations of each of the metals.
#91
Every persons situation is different. For me going from a late 60's steel bike to a average weight carbon bike has been a huge difference.
Now that I have my legs under me after 4 rides I've attained a goal I was trying to meet on my old bike; 20 miles in an hour.
#92
I'm doing it wrong.
Bikes: Rivendell Appaloosa, Rivendell Frank Jones Sr., Trek Fuel EX9, Kona Jake the Snake CR, Niner Sir9
Quoted: 9742 Post(s)
Liked 2,812 Times
I gained two miles per hour going from one steel bike to another steel bike. I believe the speed improvement comes from wheels and body positioning on the newer steel bike with the positioning being a combination of fit and design geometry. The weight is a couple of pounds difference, but climbs are not the only place I am seeing gains. I'm faster on the new steel than on an older carbon Madone I owned.
I think that buying yourself a good bike will help you improve your speed, be it steel, aluminum, ti, or carbon, but don't buy that frame material will automatically make you faster.
#93
at elite levels? maybe? But My Biggest noticed change is fatigue from my aluminum bike. much less. Its quite noticable. Frame was the only change in my case.
#94
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
a lot of people in denial.
#96
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
what makes you think it didnt?
#97
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
one thing that was noticeable was my arse was more comfy and i didnt have to ease off to stand up as often.
#98
pan y agua
Quoted: 1483 Post(s)
Liked 768 Times
A high end CF frame is going to be faster than a steel frame for several reasons. Problem is that the difference is pretty darn small.
My perosnal points of reference would be to compare my OS Paramount, with my Wilier. The OS Paramount used shaped oversized tubes, and still is fairly close to state of the art for steel racing bikes.
The Wilier frame and fork is almost 3 pounds lighter than the Paramount's frame and fork.
3lbs will save you about 1 minute on an 5 mile, 8 percent grade.
The 3lbs will also save you some energy, or increase your speed a touch, every time you have to accelerate from a stop, or out of a curve, or to respond to a surge. The difference again is very small, but over the course of a long race can add up.
Biggest difference for me in speed, is that the stiffness of the front end increases my confidence descending and cornering, which allows me to go faster into corners. I'm sure you could corner as fast on the comparitvely flexy steel bike, but in practice, the confidence that the Wilier inspires results in me going faster.
There also may be a small difference in efficiency in the transfer of power from a stiffer bb, although that is subject to debate.
Net, net, there are small, but real advantages to the CF frame. However, anecdotal reports that "my speed increased 2 mph" are either fantasy, placebo, position change, calibration error or a combination therof.
You could get lost and die.
You could hit a tree and die.
#99
Bikes: Specialized Roubaix Comp, Soma ES
From the OP first post:
Aero tube shapes can be done with aluminum through hydroforming, but not so in steel. As far as structural characteristics is concerned, aluminum and steel are stiff enough. Where CF trumps aluminum or steel is in it's stiffness-to-weight and the ability to "tune" the system. But tuning can also be done on aluminum or steel but not as good as with carbon.
Demented internet tail wagging imbicile.
