Cheapest fastest gears period
#76
Liked 934 Times
so the guy at the non profit bike shop showed me i have a really decent back cassete its 8 speeds 10 teeth on the highest gear , but he said my hangar and derailer are a little bent our of place im going to upgrade the front , i have a triple , do you guys ever mess with your crank arm length , if possible , shorter or longer make any difference for you
Cheers
#78
Liked 759 Times
For me, I try to keep one gear higher than what I can sustain in a short flat sprint (if that's not redundant to say.) That's in case of tailwind or downhill. I hate running out of gears.
#81
SRAM puts a 10T on many of their MTB cassettes. But, with a huge sprocket range, and I don't believe in 8s.
https://www.sram.com/sram/mountain/p...-dome-cassette
There are a few small wheel parts that also incorporate a 9T or 10T sprocket including the Shimano Capreo (9s). I think I also encountered a modified Campy cassette somewhere using a 10s small sprocket for small wheel bikes.
Any of them can be built into a road bike. But it doesn't just happen by accident.
Whether going to 9, 10, 11, or 12T is beneficial on a road bike is something that one can argue until they are blue in the face.
The benefits on small wheeled bikes is that they compensate for the wheel size, and allow using more standard chainrings. On an MTB, the smaller sprockets allow a greater gearing range while keeping the size of the derailleur in check.
1 to 4.2 gearing: 10-42 (32T) <==> 11-46 (35T) <==> 12-50 (38T)
#83
So being kind of a numbers guy, I ran some numbers on this 30mph business. There were some claims here that this requires 650 or 700 watts. Three different online calculators tell me it's more like 500 to 550. I don't know what to trust. Those calculators seem to work well to me. Anyway, at 600 W to reach 30mph at 90 rpm requires an average force on a pedal with 170mm crank arm of 38 kgf (the "weight" of 38kg or 372N if you prefer, it's 83 lbs if you like imperial units).
That's a pretty big force to be pushing around with one leg at that speed. Sure you could try to spin at 130 instead. Good luck pushing 26kg (57 lbs) around at more than twice a second per foot. These are essentially single leg numbers. Think of pressing 76 kg (167 lbs) on leg press machine. 8 reps is fine.. easy. Now do it 90 times in a minute.
#84
+ the exclusive hub to use it: FH-700 Freehub. they are produced for Mini velos and folding bikes with small wheels like 451 - 20"
The Shimano Capreo hub and Cassette
#85
The Messerschmitt KR175 had an ingenious reverse.
It had a 1-cyclinder engine that could be run forward or in reverse. So, to go backwards, simply stop the engine and start it backwards. Thus, the 4 forward speeds become 4 reverse speeds
hennypenny308
Folding Bikes
13
01-12-18 08:52 AM
WTBATS
Track Cycling: Velodrome Racing and Training Area
18
08-31-13 04:53 PM
