Bad shifting Ultegra 6800 groupset
#76
Quoted: 696 Post(s)
Liked 467 Times
Yes, it has internal routing. By donut, I mean "frame protector"? It's those tiny round rubber things that the cable goes through to keep it from rubbing on the frame. The cable goes through the downtube, through the cable guide underneath the BB, and then there is a hole in the chainstay where the cable routes to the RD. That hole needs a protector, it was gone, and the cable had been rubbing on the frame at that hole. I noticed there was also a definitive kink/bend in the cable where it entered the downtube, underneath the stem, not sure if that is normal or not but it doesn't seem like it would be.
#77
Quoted: 1639 Post(s)
Liked 2,743 Times
I'm not familiar with the 11 speed requirements but I see mentioned use of a nosed ferrule. You might want to check the instruction manual on them.
#78
I assume you have a repair stand. If not, get one.
I use a Feedback Sports Ultralight because I don’t need to support a lot of weight.
Lightweight. Stows in a bag. Takes a minute to setup anywhere. Ease of use is important to me.
Not the cheapest, but has worked well for 10 years.
John
John
Yes, I have a bike stand. It has proved quite useful these last few weeks! I'm going to buy a chain whip, the proper cassette removal tool, and a pair of cable cutters. I might buy a chain tool as well, in case it's needed in the future when I buy a new chain to size it correctly. It's time I did my own work on my bike, as I know I'm the only one who cares about it as much as I do.
Choddo, you're referring to full or segmented housing/cabling, mine is internal. There isn't a "guide" where the cable goes into the chainstay, but there does need to be a cable donut to keep it from rubbing on the frame. The donut slides onto the cable and fits into the hole just right.
Likes For bikenoobDomane3:
#79
Method to My Madness
Quoted: 2068 Post(s)
Liked 1,562 Times
The smoother the derailleur cable path, the better the shifting. Maximize the radius of any bends and avoid kinks.
#80
Quoted: 5978 Post(s)
Liked 2,897 Times
FWIW the donuts are purely for cosmetic protection and have no effect on function. EXCEPT if they slide all the way to one end and get trapped, possibly causing cable friction.
Thinking about your issue, I came up with another possible suspect. Namely the ferrules on the ends of the housings, and how they pocket into the frame.
Index housing requires ferrules with flat (inside) bottoms. The conical bottom of poor quality ferrules suitable for brake cables cause the ends of the steel wires to pinch in with valuable tension causing friction and poor shifting.
Also important is how those ferrules pocket into the frame. If not solidly bottomed out, or if the housing pulls to the side, that bit of wiggle undoes all the effort to make a compressionless cable system.
One of the first things I look at with erratic shifting is housing --- usually the rear loop --- that moves sideways as I shift.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
#81
So, I took the jockey wheels off one at a time, to make sure they were super clean and in good shape, no cracks, etc. I did find some gunk built up on 1 of them. But here's my question. When I took off the jockeys, both of them had the back cover pop off when I removed it.
Should that be happening? My gut tells me no. Every video I've watched says no. Are my jockeys wheels toast if they do this? These are supposed to be sealed, right? I've replaced bearings before, and every time the cover should be sealed to keep contaminates out.
#82
I think the word you are looking for is "grommet". A bare cable (i.e., not within housing) runs through a grommet when the cable enters or exits via a small hole in the frame. The grommet is inserted into the hole in the frame, both to protect the edge of the hole and to bring the cable away from the internal surface of the frame.
By the way, thank you all for continuing to assist me with this problem. I appreciate your input and ideas, and I am learning from what we are discussing. Thanks!
#83
Liked 2,897 Times
Why would a donut be under the cable guide?
What purpose would it serve there?
The cable doesn't need protection. It's made of the hardest, strongest material found anywhere on your bike.
What it wants are clear unobstructed runs with only the minimal bends needed to follow the frame.
Basically clear freedom to move with no motion lost to flex anywhere, so every 1mm movement at the lever end causes EXACTLY 1mm movement at the RD end.
As you continue, think, What does this part do? Why is it there? How does it work?
Any part without a specific purpose is pure waste. Since manufacturers cost stuff down to fractions of pennies, you can trust that each part is a critical element of the system, so you need to ask yourself what that role is.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
#84
Quoted: 696 Post(s)
Liked 467 Times
I get what you mean about the entry hole to the chainstay but surely if the cable was scraping the frame material at the edge of the hole enough to fray the coating, it’s now going to cut through that donut thing?
The fact it’s octagonal rather than circular might mean something.
I don’t think that housing is too long. I could live with that. Are you using the Shimano OT-RS900 housing that’s specific to that job?
Likes For choddo:
#85
I am potato.
Quoted: 1833 Post(s)
Liked 1,710 Times
Car dependency is a tax.
Likes For base2:
Likes For Crankycrank:
#87
Ask yourself,
(Edit: I called a few Trek bike shops this morning and asked mechanics about this, and they said that hole is indeed bare, with no cover/protection. OK then!)
Thanks to the 2 folks that said the jockey wheels are fine, I appreciate it. I had no idea. This is all very much a learning process.
#88
Liked 1,562 Times
... When I took off the jockeys, both of them had the back cover pop off when I removed it.
With reference to this picture -- which I hope shows a towel and not the carpet -- the silver / grey metal piece is only the outer cover, which often falls off when removing pulleys from the RD; the black donut shape piece (between the two silver circles) is the actual bearing seal, which can be carefully pried off to access, clean, and lubricate the ball bearings.
Likes For SoSmellyAir:
#89
If you have Ultegra pulleys, both pulleys have ball bearings. Whereas, for 105 pulleys, one has ball bearings while the other only has a bushing; I forgot which one because I upgraded to Ultegra pulleys as soon as I learned this fact.
#90
[QUOTE=choddo;23181938]I get what you mean about the entry hole to the chainstay but surely if the cable was scraping the frame material at the edge of the hole enough to fray the coating, it’s now going to cut through that donut thing?
I don’t think that housing is too long. I could live with that. Are you using the Shimano OT-RS900 housing that’s specific to that job?[/QUOTE]
The OT-RS900 is intended for the 'Shadow' type RD, which often has a short bend. It is a 'coiled' construction housing and is able to handle the bend better, but at the expense of having a little compression. For most modern frames with the housing stop closer to the RD, the more vertical entry to the RD and shorter 'run', this is necessary.
With the older style RD, with a longer 'run' and full 180* +/- of curve, the standard 'linear' strand housing is preferable.
Likes For KCT1986:
#91
Quoted: 696 Post(s)
Liked 467 Times
[QUOTE=KCT1986;23182633]
Aha, thanks. I didn’t realise that was introduced with the shadow mechs but now you mention it, that was the first time I noticed Shimano being specific about it.
Likes For choddo:
