Birdy thread
#1051
Quoted: 5 Post(s)
Thanks everyone for the help. As 50PlusCycling mentioned, I'm realizing that this bike was customized much more than I expected. The good news is that it's giving me a chance to get to know my bike a lot more than I expected (with the obvious assistance of the very kind people in this forum).
On a separate note, anyone know where to get a front elastomer? I think in the process of folding/unfolding my bike, mine must have come out somewhere. Unlike the rear elastomer, the front one is surprisingly hard to find online. If anyone has any leads, ideally in North America, I'd love to hear them.
Thanks again!
Thanks again!
#1052
Bikes: 2 old Birdys (UK) 2 in Australia
Quoted: 9 Post(s)
I bought a front elastometer yesterday for £16 from Avon Valley Cycles in Bath, UK. They have hard and soft versions. However, really they are just a bit of high density foam - easy to fashion one with a razorblade and a bit of foam I reckon. The soft version has a hole down the middle you could fashion with a heated skewer or screwdriver - the hard one for heavier riders does not.
I have a LitePro 52' replacement chainring - works fine and less messy (ie no plastic retainers) than the original. I have spare 52 and 48s.
I also got a Birdy Bargain recently - a very good condition 24 speed 2001 model for £270. They are around occasionally - usually sold by people who don't know the real value of these bikes, whcih tend to run above £500/US$700 on Ebay and such sites.
On brakes, AlixPress (Chinese exporter website working in English - reliable) - do many aftermarket spares suitable for Birdys. You can get color coded lightweight V brakes, replacement suspension, chainrings, seatposts, , brake cable microadjusters, v brake adaptors to use 20" wheels , etc. Sometimes you have to dig a little deep on their site to find all the litepro parts. My stuff was delivered to the UK in 2 weeks, postage free. I got a chainring for $15. New 18" wheels, each with 4 bearings and red in color, can't remember the price but they are good and they are still selling them.
#1054
Quoted: 9 Post(s)
I have a Nitto rack and it does rattle a lot. Some plumber's tape around all the rattling bolts would help. That bike (I have 4) sounds like a bag of nails on the road!.
#1055
Quoted: 9 Post(s)
That tyre you have, the one with the central groove, is a very slow one by the way. They have not been sold for a while.
#1056
Bikes: *1998 GT Forte Ti 700c, Totem KDS-D 26" fatbike, BirdyGT 18", Brompton M2LX 16"
Quoted: 88 Post(s)
Liked 5 Times
I found the 52t with 11-32 cassette too slow so I went with a Litepro 58t because its the cheapest of the big chainrings on ebay. You can see it on the previous page; post #1008 . I wish it was faster but a bigger chainring with a tall 32 rear may make the chain might rub the swingarm.
#1057
Quoted: 576 Post(s)
Liked 119 Times
What about adding a three-speed gear hub, effectively turning that Birdy into a Sram Dual Drive while keeping a more reasonable chainring?
#1058
Quoted: 5 Post(s)
#1059
Quoted: 88 Post(s)
Liked 5 Times
Made an ID badge for my GT. The Shapeways versatile green is a bit brighter than my frame but I'm too lazy to paint it to match.
#1063
What size chain is used on the Birdy with Shimano 8 speed Alfine hubs? Being in a marine environment mine needs replacing, just need to know what to order.
#1064
https://www.sheldonbrown.com/harris/shimano-nexus.html
#1065
1/8 would be better. If you run 3/32 the chain can become stuck between the chain ring and the chain guard. If you don't run the original chain guard, it doesn't matter. But if you do, and the chain becomes stuck (when going over a bump or something), it can be surprisingly hard to dislodge.
#1067
It seems the single speed chain isn't a good fit for those with Alfine 8 hubs. Perfect for the sprockets, but rubs on the sides of the derailur cage. Will try a 9 speed instead.
#1068
Thanks for sharing. So the single speed chain you used is 1/8" wide, then? Single speed chains also exist in 3/32" width, which is about the same width as an 8/9-speed chain, so it should not rub anything. But I guess the difference between that and an actual 9-speed is small, and they will work equally well in practice. Perhaps the single speed 3/32" is a little stiffer side-to-side and less likely to derail.
#1069
Sheldon Brown says Shimano Nexus / Alfine sprockets will work with either 1/8" or 3/32" chains, so free choice. But the chainring may not because of its chainguards, so 3/32 is the safest bet I think. meaning afaik 7- 8- or 9-speed chain, or a dedicated 1-speed 3/32 chain. Kindly don't sue me if I'm wrong.
Chains are cheap though, so no bother to try another.
#1070
Ah really not having much luck with this.
The single speed chain rubbed on the derailur cage. I bought a fancy KMC 9 speed chain, but that jumps the rear sproket in about the 10 o'clock position when under any load. Only thing left to do is to try an 8 speed chain, or give up dump the hub and get a cassette instead.
#1071
If the sprocket is the non-bevelled (fully flat) kind, then you can simply take it off, flip it around, and put it back on again, since the back side of the teeth will not be worn. If it's bevelled, you'll probably need a new sprocket: https://lite.qwant.com/?q=alfine+nexus+sprocket&t=web
#1072
Looking for a decent lightweight rack for my Birdy MK2 frame. Anyone know of a supplier in the EU?
Also, I just don't get on the original v-brakes. What are my options in terms of replacements?
Here should be a picture of your Birdy but I am not allowed to add URL links
Is this something available to buy?
Cheers
#1073
First I have to consider alternative gearing setups, though. I was thinking 1x11 setup before, but it's clear now that this will rub on the chainstay unless I move the chainring outboard. And it's already further out than what it should be, for large cassettes. So two options remain: Either Alfine 11 (more or less enough range), or SA CS-MK3 / SRAM DualDrive setup with 9-speed 11-32 cassette (very good range). The Alfine setup is simpler, keeps the chain tensioner higher off the ground, and may allow a tighter fold, if the tensioner sticks out less than a derailer. By the way, they put a regular XT derailer on it, not the Shadow version, which might also have allowed a tighter fold. But maybe the shifter cable path on the Shadow isn't ideal given the cable routing inside the Birdy swingarm.
#1075
New Birdy Touring
So I'm officially a Birdy owner now. Got my green Touring delivered in the weekend. I may have to get a Kermit sticker for it, since I've already called my other green bike Yoda.
R&M Birdy Touring by gunnsteinlye, on Flickr
Extras are front & rear racks, and dynamo lighting system. Sport stem and Ergon grips. For now I'm just tuning the ride position and testing out the gearing range, to see what parts need to be replaced. I'll probably replace the Marathon Racer tyres (40-355) with regular Marathon (44-355) for better puncture protection and a bit more volume. The dealer isn't used to these bikes, he had put the seatpost on backwards and the bars at a crazy angle, but once that was corrected the ride position was quite ok, if a little stretched still. I'll probably get bars with a bit more backsweep, which wouldn't work at all with the other stem. The ride is lively, my other bikes have more relaxed steering. At my weight the standard elastomers move quite a bit and give comfortable damping, just as I like it. The fold has one more step than the Tern I used to have, and is a little confusing at first, but is more compact I think and should work well once I'm used to it.
A little worrying is that neither wheel was completely settled into the dropouts, but a bit angled. I'd expect R&M to ship it folded with the wheels on, if so it was mounted wrong at the factory. Otherwise it's the dealers fault. Either of them should know better.
Gearing: It's got the regular 52t chainring. Rear it's got an XT derailer, and a special Sunrace hub & cassette combination that isn't compatible with anything else. The cassette is a 9-32t and 10-speed, and is used instead of Shimano's discontinued Capreo system. It shifts well enough, seems accurately adjusted. The tiny 9t cog means you get lots of high end gearing with a normal chainring, despite the small wheels. The 356% range goes from 2,1 to 7,4 gain ratio, a bit low range and high gearing for a touring bike, I'd say. Something like a 42t chainring would make more sense if touring someplace not flat. A dualdrive setup would give all the high and low end I could wish for. An Alfine 11 with 409% range might also be enough. I wish they'd sold it like that. The Nexus 8 they do offer just isn't enough, with it's 306% range.
