Show Us Your Vintage Cannondale!
#1176
Hi guys,
I recently purchased an old Cannondale and would like to find out which model/ frame it is. Unfortunately the forum isn't letting me post a photo. Is there a way around that?
Edit: It is the bike in my avatar.
#1177
This is my latest creation. I did not want to do a exact restoration since I wanted something to ride and not have to worry about getting it scratched up. I started with just a frame and fork. After stripping it down and painting it I used parts I had in my bin. I went with a 9 speed 11-40 cassette and a 34t narrow/wide crankset. It rides and shifts nicely. My total investment is about $75. $40 for the frame $35 for paint. It’s actually a Delta V 1500. I couldn’t find decals for the 1500 so ..
Likes For Wes in Missouri:
#1178
#1179
Wow it came out real nice! I just picked up a 92 v1000 myself for $40 too! I'm hoping to get it as nice as yours at some point. I'm confused about that front shock, mine compresses with little effort, and I noticed there's a presta valve on the top of the stem, is that supposed to be filled with air or something else? Most of the original parts are there besides the shifters, brakes, and wheels.
#1180
Well I found a service manual for the headshock, and from what i can see my headshock is missing that dampener adjusting knob. Withh that being said, I may not even build the bike up and just sell it on ebay,if possible. It seems to much of a hassle to get it running at this point.
#1181
WV is not flat..
I'm sure there have been many able to rebuild them, but I had no luck at all. They are a pain. I did find this set of adapters to be able to use a standard 1 1/8" threadless fork. It doesn't look that great, but got the bike functioning again.
https://www.treefortbikes.com/Proble...dshok-Headtube
#1182
Liked 526 Times
#1183
Liked 526 Times
schundog Sweet R800 what year is it? I had a 1998 R800 that I rode for about a decade.
#1184
Bikes: Masi CXR, Trek Crossrip 3, Trek 5500 OCLV, 1982 Bianchi SS, Civia Kingfield Belt-Drive Commuter, Cannondale T700, Cannondale R600, Cannondale R800, Centurion Dave Scott Ironman Expert, 1988 Peugeot Nice, Marin Bobcat Trail 3 29er MTB.
Liked 54 Times
Likes For schundog:
#1185
Liked 54 Times
My 1992 Cannondale T700 I purchased from MStategolfer (I think that’s his handle). I love this bike.
Likes For schundog:
#1186
@misctrader @brandenjs this gentleman can repair Headshok's https://www.mendoncyclesmith.com/
@schundog sweet bike.
#1187
Team Crest
My 1988 Team Crest bike. 54CM. I ordered some new Gatorskins and I just got in red bar tape to rewrap the bars. It doesn’t need anything. Maybe that’s why I’ve let it sit? I like projects.
Likes For thejohnreyes:
#1188
Pretty Pink
I got this bike a few weeks ago, I finally got it put back together. It came out pretty.
The tires I used were Ritchey Race Slick comp, handle bar tape was Cinelli Caleido, and the saddle was a Concor America.
Likes For misctrader:
#1189
One of Cannondale's better colors. That and Blueberry.
#1190
Port
Liked 2,220 Times
Actually, nice bike any month.
#1191
@misctrader Every time I see one of these Pretty in Pink bikes I want one even more. Very nice example, enjoy.
fasthair
fasthair
#1192
dollar-store reject
it's because you don't have the required ten posts to be able to post photos. It's a spam-protection thing. All photos are uploaded to your album.
#1193
Bikes: 1987 Schwinn High Sierra, 1991 GT Tachyon, 1999 Bike Friday Air Friday, 1986 Bridgestone MB-2, 1995 Trek 970 SHX, One One Inbred, 1986 Specialized Rockhopper Jr., 1987 Schwinn Sierra, (formerly owned): 1995 Cannondale R800C, 1988 Schwinn High Sierra
Liked 8 Times
Likes For HopHornbeam:
#1194
Cannondales have stiffer chainstays than most steel frames but they will still flex easily enough to accommodate the wider hub. I did the calculation once, as someone had posted some fear-mongering link off the internet suggesting that bad things would happen if the dropouts were not realigned. IIRC, assuming the dropouts were perfectly straight to start (unlikely), they'd sit at ~0.5 degrees after being stretched. If you can eyeball that, you are better than me! As noted already, don't even think twice about it. It will be fine.
I can't let a question go by about going threadless on a vintage frame without commenting, or at least inserting a pic. Below is an SR500 I built up on a budget using some Mavic wheels (early 2000s but Mavic got lucky and made them with a freehub that accepts modern 11 speed cassettes) and Shimano 105 5800. The headset is something I designed allowing threadless stems to be cleanly fitted to threaded forks. These old fat-tubed Cannondales work well for this type of conversion, in my opinion. I left it uncut for this pic but the stem can be 'slammed' down on top of the upper bearing or fitted with up to 50mm of spacers as shown.
Likes For zachleft:
#1195
Pop over to this thread if you want to read more about the headset/stem details: https://www.bikeforums.net/classic-v...n-headset.html
Likes For joejack951:
#1196
#1197
39-28 is tough but manageable on the hills I have around here. The capacity is a bit more than the RD can wrap, the chain might sag a tad in small-small, but I don't ride like that of course.
#1198
Shimano 6400 parts. FC-6400 53/39 crank. Hub is the 126mm freehub 7-speed that accepts both uniglide and hyperglide cassettes (FH-6401 I think). Cassette is a new HG-51 8 speed 11-28, but I'm not using the 11, so it's 13-28. I needed a 1mm cassette spacer as well. Also using 8-speed shifters (SL-6401) to match the spacing on the cassette.
#1199
https://www.sheldonbrown.com/k7.html
https://www.sheldonbrown.com/cribsheet-spacing.html
Likes For jeffmendoza:
#1200
Cannon-dad
1988 sr500
This bike has been with me a while now. Picked it up at a swap meet in Chicago about 10 years ago. The original wheels were gnarly and it had lots of worn out components. I worked at a bike shop at the time, so I had help making it rideable with some donor parts... It looked appropriate for a broke 20 year old, rampaging around the city.
Finally decided to give it the love it deserves and dress it up. Very sentimental bike to me because of all the adventures. Usually very fast adventures, it doesn't do slow very well.
Still waiting on some parts, but most came off of a CAAD 9 I'm not riding at the minute. Brown bar tape, pedals and a new saddle should make it feel loved 🥰🤣
Likes For oldtimeyirv:
