Show me your cruiser.
#1226
Quoted: 817 Post(s)
Liked 3,053 Times
cruiser Boss.
another Jamis but BMX styling/
Likes For '02 nrs:
#1227
This seasons cruiser
This seasons cruiser is already in action. My wife and I do mid week night time beach rides.
Likes For Curtis Odom:
Likes For mrpickem:
#1229
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 131 Post(s)
Liked 141 Times
I couldn’t pass at the opportunity to pick up this one-off frame designed by Anthony Hobbs (Flying Machine Bike Co.) & built by none other than Robert Belyea, founder of HBBC & now HB Cruisers.
Anthony chopped off the seat post & welded on the brackets for the Harley Saddle, final build & all custom wheels laced up @ Xavi’s Bikes in Modesto CA. It’s one seriously comfy ride!
#1230
Quoted: 131 Post(s)
Liked 141 Times
Schwinn made such usefull, durable, comfortable riding bicycles. I like that this is a Chicago made Schwinn also. I ride a Varsity from the Chicago era that is still putting a great big smile on my face every time I ride it.
Likes For tallbikeman:
#1231
Quoted: 131 Post(s)
Liked 141 Times
This is my 2000 Schwinn Panther. I bought it off of craigslist in stock condition for $75. It's my little trail bike, and still a work in progress.
Some issues with it. The u brakes limit tire width in the rear to 2.1 inch. Also, the u brake bosses affect my chainring size: stock, it's 45 teeth, but I'm not sure if I can go below 44, or the chain will contact the u brake bosses. So, currently I'm running 45x19, but will change to 45x23 for better climbing. Right now, this bike is geared for road riding; it's fast.
I put a Surly Sunrise handlebar on and cut off about 3/4 of an inch on both sides.
The tires are nothing special, and a little heavy, but good for the local fire roads.
2000 Schwinn Panther https://imgur.com/a/J1tK18S
#1233
Bikes: 1961 Higgins Flightliner
Quoted: 68 Post(s)
Liked 101 Times
I love viewing all these parts that I have never seen in person.
This is my first cruiser built from the frame up. I planned to use it for a commuter.
-Specialized Globe, circa 1998 or so. Frame and fork only. Originally a 3 speed.
Got it cheap because the seat post was very stuck.
-After trying the normal solutions, I sawed off the top of the seatpost and sawed the inside if it with a hack saw Blade). Took a while, but I was able to remove it by scrolling it like paper.
-Touched up the paint. Added a front drum brake wheel and rear Nexus roller brake freewheel hub on the back. (Spent way too much).
-After a few days of commuting, I concluded that the Globe was just too small for me.
-I removed all the parts from the Globe and transferred them over to my Alum Mongoose Zuma cruiser frame. I kept the Goose a long, long time.
Likes For surveyor6:
#1234
Quoted: 818 Post(s)
Liked 1,044 Times
My Electra Cruiser....
Likes For Velo Mule:
#1236
Quoted: 131 Post(s)
Liked 141 Times
Two down cruisers back on the road
The bike in the foreground is a 1960 Columbia Torpedo with Bendix Coaster brake. I installed an aftermarket Schwinn style rack and a Wald basket. Cleaned, regreased and adjusted everything. Crank had to be replaced because right hand threads were stripped. Still has original steel rims in good condition and 26"x 1.75" tires. New grips and new tires and tubes round out the picture. I also changed out the original 48 tooth front chainring for a 40 tooth so it would be easier to pedal. Bike had a lot of gentle miles on it. Back in service.
The pink bike is a much newer Schwinn coaster brake step through. I didn't know what to expect but while rebuilding her the quality of components was higher than on the Columbia. It actually rides very smoothly and easily. Both bikes are fairly light for steel frame bikes. I installed new grips and a Wald basket bolted to its already installed rack. I equipped both bikes with locks and covered chain for paint protection. Schwinn also has new pink grips and new tubes for those meaty 26" x 2.125" tires.
I was tasked with rebuilding these two cruisers for family members. Both pedal very easily and smoothly. They turned out very nicely. They are to be used around town on shopping trips and shorter pleasure rides.
#1239
Quoted: 131 Post(s)
Liked 141 Times
Bought the Columbia Torpedo off of the local Craigslist for $75.00 dollars. The bike had surface rust but was generally in pretty good condition for such an old bicycle. The bearing races had wear but they had no pitting. Still has the original pedals which needed a session with the oil can. Bike rides smooth and easy. I had to true the wheels and tighten the spokes up some too. It has steel spokes although I own a Vuelta SL37 wheelset from this era that has steel spokes. I've gotten so used to stainless spokes but my boyhood Columbia had steel spokes as did my Austrian made 3 speed bike.
#1240
Quoted: 891 Post(s)
Liked 852 Times
I scour Craigslist occasionally, but anything similar is scarfed up immediately or priced out of sight. Probably just as well since my n=n+1 has gone far enough even though I sold four bikes in the last year.
#1241
Bikes: Most of my bikes are Single Speed Conversions
Quoted: 267 Post(s)
Liked 3,067 Times
Updated pictures of my Electra stable .
After getting into the NetFlicks show “Stranger Things “ , I swapped my bars to mini apes . Reminds me of my early years . Although I never owned a bike as nice as these .
Likes For OldCruiser:
#1242
Quoted: 267 Post(s)
Liked 3,067 Times
#1243
Quoted: 267 Post(s)
Liked 3,067 Times
I’m back in the CRUISER mood , so today I put mini apes and a B-67 on my Specialized Hardrock.
had to swap out one brake cable . Added some pedal extenders to give me the pedal width I have with my Electras , that have 1/2 to 9/16 pedal adapters on them .
I had already swapped out the 3 ring crank for a single oval ring .
Smooth riding , hill climbing 1x7 Cruiser.
#1244
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 358 Times
Converted this Mongoose IBOC into a cruiser last year. I've since added a basket to the front rack and a Crane brass bell; need to update my photos.
Sure it's got 3X8 gearing, but it cruises nicely
Likes For bOsscO:
#1245
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
I didn’t really understand why IGH until your post prompted me to look it up. SA makes an IGH that is 125mm apparently.
Do IGH bikes work OK? I’ve never ridden one.
#1246
Quoted: 267 Post(s)
Liked 3,067 Times
Back in Black !
swapped the green wheelset out for the original black wheelset after changing the rear cog to a 24 tooth for neighborhood cruising .
Put the original Electra saddle back on too . Trying to decide which is more comfortable, leather or padded.
Pulled the rear rack off my Hardrock . I think it looks better .
EDIT: Added the latest picture of my black Electra Cruiser One , which is no longer a One , I swapped the wheels again for a black custom set of aluminum rims with a two speed kick back KT hub . I swapped the cog to a chrome 22 tooth . I went with a bit smaller set of tires , Kenda 26x1.9” cruiser slicks . Brought the overall height down a little where I can touch the ground while seated with my short legs . Put the Brooks B-67 back on too . Just looks cooler
#1248
Quoted: 1629 Post(s)
Liked 2,713 Times
Likes For curbtender:
