Show us your mixte (mhendricks' new happy place)
#1251
elcraft
If you google Atom 440 pedal, there is a YouTube video on rebuilding these pedals. In the video, they measure the size of the ball bearings needed. Good luck!
#1253
This is the Ficelle mixte that I had purchased new in ~1983 for my Mom and added a bunch of upgraded parts to for her. It maybe has 100 miles on it. Has not been used in 30 years. I think I will clean her up and sell it.
#1255
If you click on the paperclip icon you can load photos direct from your computer's HD.
Thank you for sharing your bicycle. We do not get to see many of this marque here on the pacific coast where I live. Have always thought there must be an agent for them in the east.
One thing I noticed was the elaborate routing for the cycle's rear brake cable. It is so much simpler on a mixte to fit a brake bridge to the laterals for a direct line pull and shorter cable length. Alternately, if one wishes to use the seat stay bridge it is possible to have a caliper which pulls from the bottom. Wonder what the thinking was behind this arrangement.
#1256
Please post once again when you have completed your work.
#1257
Whenever I click on the paperclip and try to upload a pic from my computer's photo files, it just says "failed" and won't upload.
If you click on the yellow and black "postcard" icon in the message window you can post photos via the URL; just "copy" and "paste." If a photo fails to load it is most commonly due to too large a file size.
#1258
I am torn about selling it or not. I have a Ficelle racer in white as well that is seldom used. I had purchased/sold maybe 30 of this brand bikes back in 1983-84.
#1259
Yea, the rear brake is not so good right now. It works but it exhibits its 30 yr age - stiff. I know that after purchasing this one I replaced the brakes, shifter, handle bar, cables, wheels, and tires.
Thanks for the response.
#1260
I purchased all of them from Island Cycle in Mpls. Hard to recall all of them. I was probably 14 at the time running a small repair shop out of my parents basement.
#1261
Operated a home workshop also. It was a full-time thing for about twenty years, ~1970-1990.
#1262
Thanks very much for sharing this handsome find. Outstanding condition for ~45 years old. A bit unusual to see a bike with MAFAC brake calipers combined CLB tourist levers. You might wish to consider replacing the Union 40U pedals with a french set which can be serviced. The handgrips look like they may be REG.
#1263
See which file it uses and find out if the size is too large. That is most likely the problem. I use jpg to upload from my computer and had to go through all my pics and resize them to work.
#1264
Thanks. It'll be a while. I have 2 projects in front of it and little time. I'll probably make a new thread for the restoration progress. Can you recommend some replacement cranks that don't cost a lot? One of the cotter bolts has been replaced with a big ugly bolt and I have a hunch the threads are stripped out.
For a chainset it would be nice to find a period plausible french alloy cotterless set. While ebay prices can get into the stratosphere there are no shortage of bargain venues. You probably know them all already... Dump, junkyard, yard sale, charity bazaar, thrift store. One many enthusiasts fail to check are the depots operated by the large thrift store chains such as Goodwill, Salvation Army and St. Vincent De Paul. They keep donated items there which are too far gone or too incomplete to send out to the individual stores. Oftimes they will have a yard (or pile!) of tired bikes sitting out in the weather.
Wheels not original. Are thos ACS hubs? Originals would have had Normandy Sport QR hubs and Rigida Super Chromix steel rims.
Please do begin a thread on the bike when she becomes a "front burner" project.
#1265
[MENTION=333224]juvela[/MENTION]
Haven't been to the bike to check on the parts you mentioned. I started a separate thread so we don't hijack this one. I was talking about the replacement cotter bolt-- It may be a random bolt that was forced into the crank arm. Anyway, I just want some cotterless cranks
https://www.bikeforums.net/classic-vi...l#post19568171
#1266
Ron
Bikes: 1988 Schwinn High Sierra, 2006 Montaque Hummer, 2006 Fuji Crosstown 1, 2012 Civilian Corduroy Rebel
Rear Center Pull Brake Question
I'm refubrishing a stripped out large Mitata 90 and am working through some unknowns.
- Would there have been a barrel adjustor on the frame? If so I'm "assuming" it's an extra long one with "something" to protect the frame.
- Would the brake have been mounted on top of the bracket, where the manufacture's name would be visible or underneath? I've seen photos of it either way.
Biggest difference that I can see is underneath puts the link cable under the top tubes. Can't see it makes much of a difference to the leverage on the pivot bolt.
I'm sure I come up with more questions, but this is it for now.
TIA
Ron
TIA
Ron
#1267
Bikes are okay, I guess.
Bikes: Waterford Paramount Touring, Raleigh Sports 3-speeds in M23 & L23, Schwinn Cimarron oddball build, Marin Palisades Trail dropbar conversion, Nishiki Cresta GT
Liked 2,484 Times
Here's a photo of a photo of our old Helium, built by Peugeot. Berseau ("cradle") frame, 650B white tires, wingnuts, 4-speed derailleur. Nice little bike, but we had no use for it and no room to spare. It was given to me, so I gave it to someone else.
#1268
TIA
Ron
TIA
Ron
As to the adjuster. Most mixte bikes do have adjusters on that stop between the two tubes. There were some variants in levers that had adjusters on top of the brake levers. Some deluxe Dia Compe, Mafac, Universal had those on the levers. I worked on may Raleighs & Peugeots but not Miyatas so I couldn't say what a Miyata had.
#1269
Ron
Thanks Rick. I'll continue my research on length etc. In the mean time, I have a pair of Dia Compe with the flip down brake arm openers, I'm going to give them a try. I'm also going with a pair of MAFAC that have a the ability to customize the length of the bridge cable to get it forward of the seat tube.
#1270
Liked 398 Times
Here is a 70s Torpado. I did a partial re-paint and re assembled with mostly original parts. It's a low end bike but a beauty.
I.C.
I.C.
#1272
Liked 526 Times
I built up a Raleigh Mixte for my Niece as her Grad School bike (Oregon State my alma mater) it started like this
[IMG]77 Record ltd Drv side profileJPG by Ryan Surface, on Flickr[/IMG]
A stuck stem was solved with amputation and a new Chrome fork.
[IMG]Raleigh record mixte finished by Ryan Surface, on Flickr[/IMG]
#1274
Liked 337 Times
Upright bars, thumb shifters, and a basket - perfect. But that rear fender line? Sorry to be critical.
#1275
Bike Sorceress
I finally have a mixte again, I just acquired this Raleigh Super Record to serve as a winter bike. It was in decent shape to start with, but steel rims and drop bars were not in my plans. I think the fenders came off a Schwinn World Tourist, and are a perfect match for the accents on the frame. Both wheels were destined for the scrap bin, but with enough hammering and truing I made them usable. My future plans involve lacing a new wheelset with a Shimano Nexus 3-speed coaster brake hub and a dynamo hub, cartridge bearing headset and bottom bracket, among other things.
Before:
Current Setup:
Before:
Current Setup:
