Immersive waxing / it should be more popular
#1276
I usually ride in decent conditions, but one race a few years back was held in mucky conditions. Like stretches with 6” deep mud. Drivetrain was caked. Of course that chain was trashed anyway.
I suppose a regular bike wash in the backyard hose would get the worst off, then maybe alcohol to dry and into the wax.
#1277
Likes For Kontact:
#1278
Not quite yet ready to try the whole hot wax approach but after reading the results from ZFC I have gone ahead and purchased some Flowerpower drip wax. Been a Rock N Roll Extreme fan for many years now but the results are pretty impressive with some of these newer lubes; plus there is no PTFE in the Flowerpower. Am very curious how it will compare to Rock N Roll.
#1280
Liked 3,713 Times
I have heard one should dry the chain for several hours or even heat it to get the water out else all the faffery with wax or drip of transmission fluid mixed with goat guts is for naught.
#1281
I am not a scientist and do not play one on TV ... but the data seems to indicate that water gets deep into the rollers and stays there, and added wax or lube does not displace it.
Wax has some displacing characteristics but oil coats and blocks moisture. I'm a big proponent for doing what fits best for you. If you think dropping a chain and tossing it in a crock pot better fits your needs then do that. Or if you're happy with just freshening up the lube with an oil based product, then so that. Chains are arguably inexpensive, this is more based on personal preference.
#1282
Method to My Madness
Liked 1,575 Times
Unfortunately, heating the chain to evaporate residual water also promotes rust.
Likes For SoSmellyAir:
#1283
Liked 3,713 Times
#1286
Yes, whether wax displaces every last bit of water is the focus of my discussion above with elcruxio. My concern is that it would not.
We can theorize about the tenacity of water for staying put, but I don't think there is any real reason to believe that water resists hot paraffin any more than oil resists solvent. Liquid wax has more capillary action than water and will make a very good effort to displace the heavier fluid.
#1287
One step chain waxing - make it yourself (youtube.com)
OZ Cycle just published a new video in which he does not sterilize the chain before bathing it in how wax. Interesting watch!
And then you have to exercise the waxed chain extensively to simulate what will happen in the first 30 seconds of riding the bike.
#1289
Bikes: SL8 Pro, TCR beater
Liked 596 Times
Funny how a new "easy way" involves so many steps. This requires and additive that apparently converts the chain lube to a wax-like substance, instead of just dissolving it away. Why would anyone assume that the actual wax and this coagulated oil are highly compatible?
Still 10x better than ending with a black chain & drivetrain
Likes For eduskator:
#1290
I still think it's best to strip off the new chain from any lube or grease before its 1st hot bath. That's what I do and I don't bother with any cleaning at all after the initial one. I just re-dip them for 15 minutes and shake it a few times in the meanwhile, then wipe away the excess as much as I can once it's out of the pot. Yes it's stiff at first, but it takes less than 1 minute of playing with it to break all rollers free.
#1291
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Liked 576 Times
Anecdote: 1500 miles on 10 speed KMC. My (bad) practice is wax after rain or if I hear squeaking. Light drops on way home weren’t enough to wet the chain but reminded me it had been a long time since I waxed. Plugged in crockpot; ate dinner. Checked for wear: less than 0.75. Removed chain, dropped into wax and swished. Reinstalled and tested. Done.
Likes For flangehead:
#1293
This is what I’m after. I tend to ride my road bike hard and put it away wet, and eventually that black crud requires lots of labor to clean off, messes with shifting, causes drivetrain parts to wear before their time.
Likes For McFlyRides:
#1295
Liked 576 Times
I didn't keep track, but I probably rewaxed no less than once and no more than 3 times before I hit 1500 miles. Still below 0.75 with a Park simple chain checker.
I'm a commuter, lazy and disorganized. As I said, my (bad) practice was to lubricate when I heard a squeak.. with waxing, if it gets wet I know it's gonna squeak soon so I rewax after a rain ride.. the issue comes in if there's a dry spell and chain doesn't get wet... I suspect I do need to rewax before it starts squeaking.... but I don't have a trigger...
#1296
Liked 596 Times
I used to do 350kms, now I do 300kms. I like quietness!
#1297
Liked 576 Times
OK, I've been reluctant* to say this but here goes: I'm not convinced the squeaking of a waxed chain necessarily means the important lubrication isn't still happening. I've had cases after a recent waxing when I got wet, not downpour soaked but just surface wet, and within 2-3 days started hearing squeaking. I saw light surface rust on the plates.. I'm thinking that accounts for the noise.. hard to imagine how the slight wetting sequence could have affected the lubricant along the pin rotation deep inside...
Which means a mileage-based rewaxing would be a better practice to achieve a longer chain life.
* "Do I contradict myself? Very well then I contradict myself, (I am large, I contain multitudes.)" - Walt Whitman yeah and I can't stick to my diet either...
#1298
#1299
Just Pedaling
I used to wax my chains at @500 miles, but have since shortened it down to @200 miles simply because I enjoy waxing. I have 3-4 chains in rotation for each bike so I end up waxing at least every other week even though I don't need to. I have found over the last 5-6 years of waxing that my drive train and especially cassettes have lasted much longer. I blame this on the fact that I'm not running my drive train covered in oily sludge.
#1300
For folks that run waxed chains on their mountain bikes or gravel bikes, what’s your maintenance like for dry riding? Say you want to clean a few mud splatters or dust off the bike but aren’t due for a rewax, do you avoid getting the chain wet? Do you dry wipe the chain or air compressor the dust out of the cassette or chain?
