Thread for Specialized Sirrus
#1351
Oh...btw....anyone pulled the "reflector ad sticker on the top tube?
It's a solid sticker but it looks stupid. I haven't ponied up the courage to start it but figured I'd add a bit of heat to it with a special tiny iron and a protective sock on it to loosen up the adhesive.
Last thing. If you take your front brake lever off and rotate it 360 it torques the hose out away from the head tube. That should have been done during assembly but the 15 year old kids don't care. It will destroy the finish and burn through any tape you put on the headtube in short order. I've seen it many times.
#1352
Pedaling Curmudgeon
A bit of heat from the iron and the sticker came off easy. One could do it with a hair dryer. Not too hot, you'll jack the carbon!
Here's a picture of that and also how my brake hose is now situated.
Brake line twisted to prevent head tube finish damage.
A little Isopropyl Alcohol cleaned the residual and then I hit it with New Finish polish and she's BEAUTIFUL!
Edit: I think I'll try pulling the brake lever and running it inside if the other cables to captivate it. As it is, from this angle it looks like it sticks out but in reality, it's oriented just fine and doesn't look out of place. Most importantly, none of the cables are near any carbon finish.
Likes For GrizzledBastard:
#1353
Quoted: 1586 Post(s)
Liked 1,220 Times
On the (our) bikes: yes, the crankset is a piece of non-branded junk -- boat anchor. Wheels are heavy, and the brakes are 'just ok'.
I've suffered through two seasons now, and this winter will be my re-make off-season. Depending on parts availability, current plan is: XT brakes (xc), and 1x12 drivetrain, with Praxis or Shimano GRX crank (38 or 40 ring for me; I'm old and weak). Wheelset: aluminum, around 15/1600 grams -- Roval, Hunt, or similar.
I love the frame/geometry/fit, and the FS works extremely well. I was fortunate: the FS 1.0 on mine was defective from the get-go; my LBS scored a current FS 2.0 (the fully-adjustable hydraulically-damped one) as a warranty replacement. So the heart of the bike is, for me, a keeper.
#1354
Pedaling Curmudgeon
LOL! I wish you hadn't mentioned FS 2.0! I'll be adding that to the list. I'll spare no expense to dial this baby in and make it mine. I'm down to just 2 bikes now...from 5. All custom builds but the Roubaix had to go recently due to my back and neck fusion and not being able to go there with drop bars any longer...not comfortably, anyway. I sold my 2 custom build Surly Karate Monkey's before my big surgery last November as I knew my hard core dirt riding wouldn't be wise on single-speed or a rigid plus bike for quite a while. Now it's just my custom build Stumpjumper Expert 6FiddyFatty and the Sirrus so the Sirrus needs the cool bling to get it up to snuff!
I'm just torn on what direction to go on that crankset and I agree on the BR8000 series XT's...best brakes around! I'm peeved because we were buying all the Shimano stuff out of Germany when I was building mine and lots of bikes for friends. You could get a set of XT's with good JO3 finned pads for around $150 USD! That's done with Shimano's newer agreement...which is understandable. I sure got my money's worth after probably buying 15+ sets plus all the XTR drivetrains.
#1355
Anyone remove or change-out their Sirrus grips and bar ends and willing to sell it to me? I just got a 2016 Sirrus Carbon Expert and the original owner got rid of these. The OCD in me wants to get this bike back to its original configuration. Thank you.
#1356
Quoted: 9660 Post(s)
Liked 6,366 Times
I just added the saddle Stix mount to our three Specialized saddles. Really integrates the light a lot better. And, good choice on the Chesters. We have RaceFace pedals on both of our Sirruses. Phone/light mount looks slick.
How did you find a matching helmet?
#1357
Liked 1,220 Times
I'm a 'custom' guy too, in the sense that when I find a stock bike with a frameset that is a 'keeper' for me, I tend to upgrade everything. Did that with my first Sirrus -- a 2010 Comp (the E5/carbon stays/fork one) -- which was sadly stolen a few weeks ago (another story). I'll now do the same with this one to an even higher level. I'm 69; this bike will last me a good number of years, so why not? I'm just hoping that parts shortages/supply chain issues won't delay things too much.
#1358
Looking good!
#1359
Liked 6,366 Times
By luck really, happen to be browsing a website looking for helmets and came across the sage green color - off course they didn't have it in stock. Went to LBS to confirm my size and fit then really just kept searching till I found one. Vendor in Sparks, Nevada had it on sale with no tax. I know its a MTB helmet but I like the fact it has more coverage, comes with ANGI and includes a visor - really helpful when knuckleheads have their lights angled too high.
I'm drawing the line at shaving my legs.
/s/ Sucked In
#1360
Can anyone quote the Praxis carbon fibre crankset part number for the 2020 X 5.0 please?
I love this bike (sage green, large, bought it May) and want to take some weight off it. My wife didn't want to keep hers (medium)so it went to a good home local to me.
#1361
Liked 1,220 Times
If you are in the U.S., just purchase direct from Praxis, choosing the crank length and ring-size you want from the drop-down list. You'd need their dedicated M30 b/b as well, "Road: BSA Threaded".
Likes For badger1:
#1362
You guys changing out cranks, please publish the details of what you got, where, and how install went. I want to get rid of the stock crank on my 19 comp carbon X next spring.
- Mark
- Mark
#1363
$50 Cheaper
glorycycles.com/praxis-zayante-carbon-s-crankset/
#1364
Pedaling Curmudgeon
I just ordered the Praxis Zayante Carbon 175 40T, the M30 BSA bottom bracket, and your going to need their BB tools for $20. Shimano BB9 or GXP tools won't fit it. I'm 3 hours south of Praxis which is in Santa Cruz, CA and they'll ship today so pending no delays, I'll have this on by Friday if not Thursday.
I got the 40T since it was a step down from the 42 that's on it. Theoretically, the 42 should fit the Praxis as its a 3 bolt Direct Mount...unless it's some proprietary crap...we'll see.
#1365
Pedaling Curmudgeon
That's not quite the same as the Zayante Carbon. It's the cheaper version and you can buy that the same on Praxis' web site. They have NO single ring in that model but it is a DM so you could crap-can the rings/spider and go with your OEM chainring. You won't find many decent chainrings for $50 so, IMO, it's worth buying the standard $300 Zayante and ending up with some variety to try if you need to make a change.
Also, if you buy direct from Praxis, you have 30 days to say "Beat It!" and send it back.
#1366
What do you all think about an SLX crankset and BB to match the derailleur and brake levers?
#1367
Pedaling Curmudgeon
SLX is good stuff. That and the MT800 bottom bracket would be a solid setup. They're inexpensive and solid.
My personal preference is to go with Direct Mount chainrings with a zillion options for aftermarket but if you're going to stick with one setup, the Shimano is a great choice..
EDIT: If you go SLX, you'll need to do some homework on chainring size options. SLX is a MTB line...which is not a big problem but I'm guessing you've noticed the chainring sizing is very restricted to smaller sizes like 32, 34, 36T. You'll just need to source a ring that will accommodate the BCD of the spider. Because I didn't want to open that Pandora's Box on top of all the other upgrades I'm doing, I avoided the XT and XTR line that I might have considered.
#1368
#1369
#1370
Pedaling Curmudgeon
Tell me you rode Demo Forrest trails?!
#1371
Pedaling Curmudgeon
If you're a mountain biker, it's pretty much Mecca for "local" California rides. The Flow trail is quite the hoot. We usually go up early in the morning, it's about 3 hours from SLO, and do 2 laps through Demo and that yields just under 4000' feet of vertical and just under 20 miles distance. Then, hit the sausage shop for sammiches in Corralitos on the way home!
#1373
Pedaling Curmudgeon
Adding another pic of furthering upgrades. I installed the Santa Cruz carbon flat-bars last night and put a 15 miler on them today. Yyyuuuge difference in damping and comfort with Future Shock! Still ultra compliant.
These are cut to 700mm which is 20mm longer than the stock 680's. 8° backsweep and 7° upsweep so they aren't very far off of stock configuration. I'm sporting the Ergon GP3 grips now. Road riding and long XC hauls have always been an issue for numbness in my hands. Not so much on an MTB because hand position is so dynamic on the trail. These things are epic! Very comfortable. They make them in all rubber, too if the cork-look doesn't fit your fashion statement. These are "smalls" which applies only to the diameter. I have average hands which sizing suggests large but I have always preferred a smaller diameter grip.
For grins and giggles, a pic of the "new" blue tint in the sun....which we're finally seeing here on the coast as opposed to fog.
Santa Cruz carbon flat-bars / Ergon GP3 grips.
2021 Sirrus X 5.0 Blue Tint/Ice Blue/Satin Black
#1374
Quoted: 580 Post(s)
Liked 1,026 Times
A bigger issue is chainline, as the SLX is MTB. A Shimano GRX crank would have a road chainline (which I would assume that the Sirrus has) and 40t chainrings.
Carbon cranks are fantastic for shedding that last bit of weight; but bang for buck, lighter wheels are a better
Since Im editing this, I'll add that the engineering of Shimano bottom brackets has several advantages over other brands. Also, crabon cranks require the large torque wrenches (50ft-lb) for installation; something to consider for the DIY crowd. I have an SLX, a GRX, and a crabon crank (Easton) and I love em all; horses for courses.
Last edited by DorkDisk; 10-28-20 at 08:32 AM. Reason: tpyo :-) SLX has hollow arms.
Likes For DorkDisk:
#1375
Pedaling Curmudgeon
