Addiction LXXVIII
Quoted: 8444 Post(s)
Liked 9,396 Times
We had squeal out. If I'd know it was $20 a thimblefull, I'd have asked if I could have the remainder when we closed!
https://www.modernbike.com/product-2...4aAvrdEALw_wcB
Luckily I rarely get squeal on personal bikes. AZ sun and sand keeps the noise down.
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
This is the first time I've ever needed a boot. Is there some way to put one in permanently, or just re-position it every time it's opened up?
Bikes: Shmikes
Quoted: 10239 Post(s)
Liked 5,962 Times
This time of year, I get squeal from the rear on both of my bikes until I heat the discs up with a few stops. I assume it's condensation from coming out of my air conditioned basement into the Mid-Atlantic mug. Plus the rear rotors are always a little dirty from sweat and water from de-sweating the bike after the last ride.
Likes For MoAlpha:
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Should Be More Popular
Quoted: 22765 Post(s)
Liked 9,164 Times
Some boots have an adhesive, like Park Tool. But for a plain one you could just use a dab of adhesive or cement/glue, or reposition as needed.
Quoted: 3400 Post(s)
Liked 3,750 Times
I have the cheap Shimano brakes on my mtb and they rarely make any noise, only when the rear one gets really hot. I'd love to put some more powerful brakes on there maybe with some bigger rotors but really they work fine most of the time. When I ride it a lot I go through pads pretty quick but no noise.
I'd like to put bigger rotors on just for the aesthetics although I think I'm limited to 180 in the front. 160s look pretty tiny on a 29" wheel, especially when everyone else is running 203s
Liked 3,750 Times
Liked 9,164 Times
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
However, if you buy gp4ks in bulk, you get them for barely over $30 and they usually do last long enough to be worth it. Stay the eff away from grave though, even individual stones. That’s what kills them is climbing partway up a stone and then kicking it out the side as it slides down, shredding the sidewall.
I have a bunch of them used in one race each, though.
Liked 9,396 Times
Mine are cheap Shimanos as well, and I doubt I work mine as hard as yours. I'm probably about your size and run 160mm front and rear and never really felt like they were inadequate when working properly. There's no big descents here.
When I'm on steep stuff I need more brake. I'm 200, bike 32, Camelbak at least 8 when full.
Liked 9,396 Times
Likes For big john:
Liked 3,750 Times
We are very close, currently I've got 8 pounds on you but 2 less on the bike. My Camelback probably isn't that heavy, I usually only half-fill the bladder since I only go ride for around an hour and a half at a time.
Liked 3,750 Times
Likes For abshipp:
Liked 9,396 Times
My fork is a 120mm X-Fusion with 32mm stanchions, and the published limit is 180 with an adapter. Probably shouldn't try to push it, even if I could find an adapter. Like I said though, it doesn't really matter since I've rarely ever felt myself wanting more brake.
My first long travel dirt bike was a Husqvarna with a 35mm fork with 11 inches of travel. Too flexy for a motorcycle! The front end would wag all over and you could feel it twisting in turns. The smaller, lightweight mtb forks give me the same effect.
Administrator
Quoted: 12040 Post(s)
Liked 6,827 Times
Bikes: Shmikes
Liked 5,962 Times
Administrator
Liked 6,827 Times
A little of everything: Beets, Swiss chard, cucumber, onions, eggplant, tomatoes, shi****o peppers, bishop hats peppers, rosemary, thyme and sage.
With the cover on spinach and garlic overwinter nicely.
*sh.i.s.h.i.t.o
*sh.i.s.h.i.t.o
Quoted: 4717 Post(s)
Liked 1,882 Times
Mostly Harmless
Bikes: Have two wheels
Quoted: 13798 Post(s)
Liked 4,643 Times
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Liked 9,164 Times
There is a relatively newer cyclist who has started riding with my little inner circle the past year or so.
He is a nice guy but he really prefers a Camelbak to water bottles.
I am trying not to be a snobby cyclist, but I still cringe a bit when he shows up with it. I have not directly said anything to him other than "doesn't that thing get hot during a long ride?"
Should I continue to bite my tongue? Or tell him he cannot be a serious road cyclist until he switches to bidons? Better yet, maybe I should post my question in the 41 with a poll??
Liked 9,164 Times
Super Modest
Quoted: 11037 Post(s)
Liked 4,778 Times
Super Modest
Liked 4,778 Times
