For the love of English 3 speeds...
Bikes: 1973 Raleigh Sports, 1964 Raleigh Sports (Canadian?), 1969 Triumph Ladies, 70's Columbia Sports III, 07 Diamondback Venom
The official park tool spanners are HCW 5 and HCW 11 but a punch for the lock ring is fine. You might be able to unscrew the adjustable cup by hand. If it's too stiff to unscrew by hand, grab onto that raised part with pliers for leverage. The threads are fine and delicate, so you don't want to use any tool to hold the outside diameter. It shouldn't be very tight. The fixed cup on the other side is another story. It's a LH thread and a real bear to remove, so don't. Just reach in with a rag and a stick to clean it out.
For those clips on master links, I use a screwdriver to push it forward before I lift it off with needle nose pliers.
Bikes: Raleigh Sports
Both crank arms need to come off to to remove the shaft. It would be better to remove all 45 year old petrified grease out of the cups. It can be hardened on to parts may need scraped with pick type tool in a manor not to scratch the bearing race it will break up with a very light scraping. Hardend grease is too dry & stuck and solvents don't soften deposits.The bearing track in the cup not very wide Its the same width as on the shaft
I have shot grease into the fixed cup without complete disassembly/shaft removal with a big syringe before but is a short cut and is only adding fresh grease to a dirty hardened grease and will eventually start mixing hard dirty grease into the bearing. Not the way to go.
The fixed cup on the sprocket side does not need to be remove to do a BB grease nicely. Careful not to loose bearings down frame tubes I think each side has 11 bearings. When you repack it will look llike one is missing but is correct.
Youtube seems to have vidios of most procedures and find very helpful.
I always save the chop sticks that come with Thai take out. They're handy for all sorts of things and this is one of them. I have a headband flashlight I use when working on bikes. Another handy tool that puts light right where I need it. So I use the chop stick to place the grease into the fixed side cup and the light to see inside the bottom bracket. Grease will hold the 11 drive side bearings on the spindle while I fish it through the hole in the fixed cup. I hold it in place with one hand and screw on the adjustable cup that's already loaded with the other.
Speaking of bearings, this is just something I do. Many times, if you reuse the old bearings you can feel a bit of roughness as you spin the crank. When you use new bearings, it spins smooth as silk. When I go through the trouble of rebuilding a BB I like the satisfying feeling of a silky smooth rotation when I'm done even if it isn't something you would notice riding the bike.
Liked 337 Times
I use an artist's palette knife to scrape hardened grease from the cups. You can find one with a profile that nearly matches the curvature of the cup.
Can you use that on the fixed cup while it's still in place? Usually mineral spirits will clean up the cups, but if there's still some dark spots I'll go to a stronger solvent like acetone or naptha. After that, I'll call it quits and put the BB back together. I don't like removing the fixed cup. Even though I have the Bikesmith fixed cup tool it puts so much torque on the BB I'm afraid I'll bend something. Maybe that's a needless worry. I have done it a few times. Mostly with the friction method, but the last time with the Bikesmith tool. This tool is worth every penny if you're determined to remove fixed BB cups.
Liked 337 Times
[MENTION=398265]BigChief[/MENTION] Most palette knives are long enough to reach the cup while it is in place. Like you, I leave the fixed cup in place whenever I can.
Bike Doctor
Bikes: Norco Cape Cod tandem, KHS Tandemania Cross, 1952 Claud Butler ladyback tandem, 1971 & '73 Raleigh Suberbes, 1985 Gazelle Sport Solide, 1985 Rossi professional
Liked 52 Times
A quick and dirty trick I have used in servicing junk dept store bikes that need bottom bracket lubrication is to just remove the seat and pour a couple ounces of motor oil down the seatpost. You can see dirty rusty oil run out the axle on both sides as it flushes while you spin the crank...
Lots of good tidbits for repair work! I never remove the fixed cup either.
Got the NDS arm back on, got to use the same nut with the pin I got from the LBS.
Bikes: old ones
Liked 10,458 Times
So i got a couple pics for ya
First is it looks like someone tried to use a hammer and chisel to undo the lock ring in the past...
Other than the lock ring tool is there any other safe way to unscrew this? I don't want to damage it anymore than the previous "mechanic" did
Bikes: Too many 3-speeds, Jones Plus LWB
Liked 296 Times
Also I'm a bit rusty on chains but this one is a master link type?
Untitled by David Ashe, on Flickr
if so how does one remove it? I am replacing the chain but i wanna keep the original stuff
UGH! So i managed to get a wrench for the lock ring.
Now onto the BS of the evening: I have a drill press vice, which failed to remove the pin from the crank of the 64,i used a 3/8's socket as noted and slowly cranked it but alas the angle was wrong so i stopped but not before the handle on the vice bent and snapped off...
No biggie i can just return it tomorrow. it seems the only way to get he arm into the vice flat is to tilt it 90 deg on it's side.
So i tried the nut on the end hammer method and well all it seems to do oddly is push the nut onto the pin ... seriously? I have resprayed it with PB blaster but i feel there is a larger issue:
I spun the crank while waiting and i think it may have a bent axle (it could just be the sprocket is bent but its making me worried that whoever last worked on this over tightened everything, im currently at a loss
Bikes: old ones
Liked 10,458 Times
...the biggest problem in extracting cotter pins is that many of them were not coated with grease prior to reinsertion, and many of them have been in place for a long time, in all sorts of weather. So they corrode in place to some extent. If you already hit it with a hammer, and did not hit it hard enough to pop it loose on the first couple of tries, it's probly bent by now.
Even the dedicated cotter press is not 100% guaranteed. Sometinmes no matter how skillfully you apply the pressure, the pin bens on the threaded end, rather than breaking free. some other things that can help are the application of a 50/50 mix of acetone and ATF, right down into the space that is open in the crank arm after you remove the nut and washer. And heat, applied carefully and judiciously to the pin with a butane torch can sometimes expand and cool it so the mating surfaces break free.
I have drilled out at least a dozen of them in the time I've been doing this sort of stuff. It's actually not that difficult, if you set up correctly in the first place. All you drill out is the threaded end and just a little past where the pin goes into the crank. then you insert a pin punch of the correct size and hit it with a big hammer. the cotter is softer steel than either the crank or the spindle.
Somehow you need to have the arm you're working on secured in a vice while you are doing this.
If you have manged to remove the drive side crank arm, you can usually just pull out the remaining arm, spindle, and adjustable cup to make it easier to work on.
I'll describe my next step process. If the press bends the threaded end of the cotter and it isn't budging, I center punch the end of the pin so the drill doesn't wander off. Then I drill down enough so there's a concave surface on the end of the cotter. The whole point of this is to make sure the punch you drive the pin with doesn't slip off to the side. You want the full force of the punch centered on the cotter. Then I cut a piece of 2x4 to fit between the crank arm and a hard surface floor. Concrete or pavement works well. Also, I make a notch on top of the 2x4 to make room for the pin to drop out. Wood makes a great support for the crank arm because it won't scratch the chrome. It's important to have a punch that's as hefty as possible and still fit snugly in the concave surface you made in the top of the cotter. The only catch here is you need access to a good punch set and a cement floor. Hang in there, you'll win in the end.
I did notice that the whole thing seemed a touch loose in the BB like i can rock it also, the non drive side cotter was in fact rusty on half of the rounded end, and that the drive side pin non threaded side isn't but has like grip marks from pliers on it like someone squeezed the top of it. Also i think the sprocket might just be a little warped in one spot but i can fix that.
I'll get pics tomorrow
Funny story i had planned on making the 2x4 piece and going that route first, and my entire deck is concrete so i am good there.
Update tomorrow!
This could be plain luck, but I haven't had to do this since I started using the Bikesmith cotter press. That has a concave surface on the drive pin which centers the pressure much better than the flat bench vise jaw. The thing you want to avoid here is the drill slipping off the cotter and making a mess of the crank arm. So start with a center punch then a small drill to get the hole started. It might even be a good idea to file a small flat surface on the cotter end before you center punch.
I have seen here on this thread people having to drill the cotter all the way through before they could punch the cotter out. In all my years of 3 speeding, I have never had to do this. Hope I never will. So far, I have been able to punch them through using a 2x4 for support and I think the concave surface made by the drill helps a lot.
I may someday have to eat my words here, but I think the whole trick to getting cotters out if they bend with a press is to make a countersink with a drill that's in line with the cotter. When they're bent, it's like trying to hammer a bent nail without that. Put some support under the crank and give her the dinnah like they say up in Maine.
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Liked 445 Times
Liked 445 Times
I use a grease gun with a long nozzle - I think the brand is Finish Line. I hold a small flashlight in my mouth to aim light. To remove grease I use a long screwdriver with paper towel or something on the end, my fingers and Q-tips.
Liked 296 Times
With regards to cotter pins- if I can make a recommendation?
A can of Kroil is very helpful. If the bike shows a lot of corrosion, don't attempt to remove the cotter before giving the nut side (nut removed) a good dose of Kroil (available from Kanolabs.com). Let it sit for 15 minutes at least. Then use a good cotter press like the Bikesmith (a cotter press is mandatory for cotter installation BTW- so if you work on older bikes, a cotter press is an important tool). Work it on a bit, but pay attention to the cotter- is the threaded end staying straight? If the cotter is freed up, the torque on the press will drop dramatically. If the cotter is bending, the torque will be higher. You can avoid nightmarish tales like seen on this thread by paying attention to this subtlety.
If the cotter is not freeing up right away, have some patience and give it another dose of Kroil then let it sit for a day and try again. Kroil has a nasty odor so better do this in the garage...
Liked 337 Times
I use a modified Harbor Freight chain tool as a press, and lots of patience and penetrating oil. I allow about a week for the penetrating oil to work - applying it every day, then I apply the press. If the cotter doesn't move, I lightly tap on the crank arm using a wood block as a cushion.
I find that I can crank the press a bit more - maybe not all the way - but an hour or two later it comes out.
So far, about a dozen bikes, I have not had to drill a cotter. Maybe I am lucky.
Old fart
Liked 3,684 Times
https://www.amazon.com/Advanced-Desi...eedle+injector
Works well to inject grease into cable housings as well.
