For the love of English 3 speeds...
Bikes: Too many 3-speeds, Jones Plus LWB
Liked 281 Times
Has anyone come up with an elegant fix for adapting new brake cables to work with the old style calipers?
I've seen some rough solutions with a small nut and bolt but nothing that looks clean.
Those proprietary NOS cables are in short supply and often very expensive.
I've been swapping out the old calipers for the newer versions but would like to maintain originality where possible.
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Liked 445 Times
Not that far back on this thread I mentioned the use of a torch and solder which uses 95% antimony and 5% silver- that's how the original cables were made. I had to replace a frayed cable on my 1935 'Model Sports' which uses drum brakes front and rear. Usually the hardware is still serviceable even though the cable itself is not. So if you are careful with measurement of lengths, you can fabricate a cable from new materials easily enough.
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Liked 620 Times
Confound all ye reckless 3speeders! All your talk of "scorchers" has me working on a 1972 Raleigh built Supercycle I picked up earlier this summer. Some sort of step through (relabelled Peugeot?) donated the unique bars. The mudguards were cleaned and straightened and copious amounts of surface rust cleaned off. A Japanese front wheel was available so it was installed. The Schwalbe Delta Cruisers are overkill, but were attained for a reasonable $40.
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
Liked 445 Times
The bars and grips look like old Bridgestones.
Is there a red reflector in the ends?
Bridgestones were also sold under the Supercycle name.
Liked 620 Times
I've always liked those gold Supercycles.
Attachment 585796
Attachment 585798
Attachment 585796
Attachment 585798
The grips are labelled Bridgestone and do have the reflector in the end. The donor bike had CLB brakes and Solida cranks which led me to believe it was not Japanese. Perhaps the originals were drops and later changed to Bridgestone.
I have a '76 Supercycle Excalibur made by Bridgestone. It is a wonderful ride and one of my all time favorite bikes.
Bikes: Raleigh Sports
I'm getting Schorcher embemed on my brain, will these handle bars be appropriate? This is a good complete bike the neighbor wheeled out to her trash cans so it needs to come apart.
I don't even know what a Scorcher is...
Just an hour on the bikes today. Cleaned a few parts. I need a tool and I don't know what to ask for. How do I disassemble this hub? I got the outer ring off ok but the secondary ring with two slots opposite each other. It's a single speed which I'm not going to use but i want to rebuild it anyway. Is it also threaded left and what,s the tool?
5027254550_2b437d78ea.jpg This is a google image, mine still has the spokes behind the chain ring.
It's just making a hot rod out of a utility bike. A bit like taking the family 51 Mercury, gutting the interior and painting it candy apple red.
Phyllo-buster
Liked 2,069 Times
Attachment 585814 This is a google image, mine still has the spokes behind the chain ring.
Anyone else?
Bikes are okay, I guess.
Liked 2,452 Times
Sooo, lace it back on to the rim and buy that 2 prong tool and maybe?
A couple of more questions about spokes. I removed the spokes from a single speed hub, a 3 speed hub and a front hub and all the spokes are the same length, 284mm. I can't find this length for sale with a quick search. The spokes off the 3 speed hub, 1949, seem to zincier (is that even a word). The nipples (spoke lugs) on the front wheel are longer then those on the 2 rear wheels. Any significance in that?
@browngw
Nice looking golden scorcher project! I think you will be pulled into the rebel trap! Are you feeling reckless yet?
Liked 2,452 Times
Attachment 585829
Attachment 585829
Good shops usually have spoke threading tools and can make you any length you need. The different length nipples are probably different brands and that should make no difference as long as the threading is correct and you have enough thread engagement.
Lacing half a wheel definitely works. I've done it. The maybe part is whether any freewheel remover you find will engage properly and provide enough grip for you to break the thing loose.
Liked 445 Times
Zincier, I like it but I'd probably spell it zinc-ier, lest someone think it's French and pronounce it ZAN-see-yay.
Is it worth the effort?
Liked 2,452 Times
He may also want to salvage the hub, although there are ways to do this without rebuilding but which destroy the freewheel in the process. Hard to get them apart without damage unless you apply a little effort.
Gee wizz what are the origins of a Royce Union, Are they a dept. store brand?. It looks English/Raleigh to me. I'm going to go get this one this weekend. I found some pennies they are burning a whole in my pocket. I'll see if I can get it for $40. The racks are too cool and the stick shift I have not seen before. It seems to be intact with everything and looks like it will clean up well. Small frame. Its been on CL for a while here.
https://minneapolis.craigslist.org/r...329084459.html
Attachment 585906
Attachment 585907
Attachment 585906
Attachment 585907
edit:
just an example. This bike was a craigslist find at $50. It had a lot of bugs to work out, but it was worth the effort in the end.
Liked 337 Times
That looks like a Shimano 333 speed stick shifter. If you have problems with it or the hub contact me. I have a lot of Shimano hub parts and a used stick shifter for the cost of shipping.
Liked 445 Times
Lots of different manufacturers made bikes under the Royce Union badge. Some of the older ones are Raleigh made, but this one isn't. Personally, this isn't one I would go after. The market still has real English 3 speeds for dirt cheap if you have patience.
edit:
Attachment 585922
edit:
Attachment 585922
A-not English
B-not a tall frame
I would make an exception for a Rudge, Philips, Robin Hood or a nice Dunelt.
I did fix up a nice Shimano 3 speed for a friend a few years ago.
My plan was to swap out the rear hub for an SA 3 speed
but once the bike was cleaned up I opted for originality and went with the 333.
The photo doesn't really do the colour justice.
https://threespeedmania.wordpress.co...speed-project/
