For the love of English 3 speeds...
Bikes: 30's Speedwell Club Racer, 40's Speedwell 'Z' racer, 50's Unknown Aussie with nice lugs, 50's Speedwell Roadster, 50's Repco Roadster, '63 Raleigh DL-1, 70's Raleigh Sprite, Puch Promenade with Nexus 8
Liked 30 Times
I've never had a steel stem stuck but I did have pawl pins rusted tight in an AW hub once. I was worried that the whole assembly might be toast until I gave it an overnight soak in evapo rust. In the morning the rust was gone and the pins came right out. Just a thought.
Liked 337 Times
Is the fulcrum clamp the shift cable stop on the top bar close to the front with the slotted plastic insert? If so I'll send you one I still have the box with your address on it. It should be in decent shape after a clean up & complete. I robbed that picture not the one.
![](https://tse1.mm.bing.net/th?id=OIP.EGp_k_U-YgCfUNGtv0KUYAEsDh&pid=15.1&P=0&w=202&h=152)
Bikes: Raleigh Sports
Are the calipers aluminum? Do they have markings?
Liked 337 Times
I have those levers on a Sears 3 speed made by Steyr in Austria. They are indeed Weinmann levers mated with Weinmann aluminum side pull brakes.
Bikes: Too many 3-speeds, Jones Plus LWB
Liked 281 Times
Haven't seen this shifter before. Maybe a 1961
https://minneapolis.craigslist.org/r...400884505.html
Attachment 590294
Attachment 590294
Thanks for the info. The calipers are Schwinn script Weinmann. It's possible the levers and calipers came from the same bike because the Schwinn script may not be original to this 1960 Varsity. The stem and bars are available cheap if anyone here needs them. Here's a pic of the Schwinn after switching to drops (repainted and incorrect decals):
![foo](vb/cache//ds.jpg)
I've always heard that Schwinn made all of their bikes in that era. They wanted anything with "Schwinn" on it to be built in their Chicago factory. They only started to outsource bike production in the mid-70's, when they realized they could not build lightweight 10 speeds (except Paramounts and the fillet-brazed models) in house, so they had Panasonic build the Le Tour.
Anyone else want to weigh in?
Phyllo-buster
Liked 2,069 Times
Liked 281 Times
^^ That too is a Brampton. I have the first style (in the prior photo) on one of my bikes so I know they made them both ways. Funny that the Hercules and Brampton shifters look identical. Is the Hercules rebranded?
I suspect that Brampton was the actual manufacturer of the Hercules branded Sturmey Archer clone hubs as well as the shifters.
Phyllo-buster
Liked 2,069 Times
A quick question to the cognoscenti: best shifting technique on a British 3-speed that would go easy on the mechanicals?
I just joined the British 3-speed club by acquiring 1960 (?) Raleigh-in-disguise Sports. I got my first (thrilling!) spin yesterday, and want to avoid damaging the machine.
As an example, I haven't lubricated the hub yet (discovery stage), and there is a slight delay in shifting - normal, or should I adjust my technique?
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Liked 16 Times
I just join the British 3-speed club by acquiring 1960 (?) Raleigh-in-disguise Sports. I got my first (thrilling!) spin yesterday, and want to avoid damaging the machine.
![Roflmao 2](images/smilies/roflmao2.gif)
Rule #2 add some oil to the hub
When riding on an IGH you need to let up a bit when shifting, some people stop pedaling completely.
Unless the hub is way out of adjustment and you put our 750 watts of power you will be hard put to damage a Sturmey-Archer AW. Good news is if you do manage to break it, there are plenty of repair parts available.
Aaron
![Smilie](images/smilies/smile.gif)
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Cleaning and oiling the shifter mechanism can really help. It's possible the cable tension is not correct. Make sure the cable is still on the pulley and the pulley moves freely.
Also check the small chain where it enters the hub. Make sure the links are not coming apart and it moves freely. The links may be stiff there. Penetrating oil and working the links back and forth helps.
![](https://farm5.staticflickr.com/4581/37773150975_75ed56e275_k.jpg)
Yes, oiling with plain old 30 weight (lawnmower, sans additives) oil?
I did sense the need to pause slightly during the shift.
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Liked 981 Times
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
Old fart
Liked 3,476 Times
Sturmey-Archer Spare Parts from Harris Cyclery
As does BikeToolsEtc in Oregon:
Bike Tools Etc. - 1000's of bicycle tools and parts for the home mechanic!
On the road
Bikes: Old Schwinns and old Raleighs
Liked 946 Times
Huh?![foo](vb/cache//ds.jpg)
Schwinn built their own 3 speeds, variously using lugged and brazed (Paramount Tourist), fillet brazed (Superiors, early New Worlds, and the early Continentals), and eletroforge weld (lots of post war models).
Harris Cyclery in Massachussetts carries Sturmey-Archer small parts:
Phyllo-buster
Liked 2,069 Times
I have been to Harris to get other parts. As I look at their web site I do not see the spring cap listed. This hub had a thin washer placed below the bearing race in the assembly. The spring cap fits snug between the bearing and glide on the bottom of the axle cone. I feel that the thin washer would hang up while trying to slide up ad down as you shift..
Liked 281 Times
Automatic transmission fluid works quite well; WD-40 is good if the bike has been in long disuse- spray the hub full of the stuff and go for a ride of a mile or two. Once back, rotate the wheel so the oil port is down and with a paper towel or rag, drain the hub by spraying even more WD into it while the oil port is down. If you have compressed air, spray that into it next and then add a normal lubricant. Almost any will do; 10-30 works OK but I think the automatic transmission fluid is better. The hub should rotate as freely as the best Campagnolo hub or you have a problem.
Shifting: Easing off of the torque is all that's needed. You don't need to stop pedaling. Shifting should be instantaneous.
