View Poll Results: Frame Material Preference
Carbon Fiber
40
31.25%
Aluminum
10
7.81%
Steel
61
47.66%
Titanium
17
13.28%
Voters: 128. You may not vote on this poll
Frame Material Preference Poll
#126
Quoted: 338 Post(s)
Liked 408 Times
I think it is correct. This is the reason that people who tour on bicycle chose steel because it's the only material that even a person with a simple welder can repair, be it anywhere in the world, you won't see that happening with any other frame material, especially CF or TI. Even in the US you still have to send the CF somewhere for the repair, whereas a local person could fix a steel bike.
People tour on steel because the touring scene is largely retrogrouch heaven. The internet tour-o-sphere swears by leather tensioned saddles from the end of the 19th century as the pinnacle of comfort on a bike. The wheels need to have 12321314773213 spokes (ok, slight hyperbole) because that's what needed to be done in 1980 when time had stopped.
Likes For Branko D:
#127
Quoted: 4080 Post(s)
Liked 7,667 Times
Repairing carbon today is not what is was in the 90s. You might want to get acquainted with this century.
#128
Quoted: 7163 Post(s)
Liked 11,368 Times
Someone trots out the old trope about a village welder repairing a steel touring bike, even though no one actually knows anyone who's had that experience. And then they ignore the strength and repairability of cf, even though such frames are regularly repaired.
Likes For Koyote:
#129
Quoted: 1291 Post(s)
Liked 1,392 Times
Please explain to us uninformed how you propose someone replaces a tig welded top or down tube and how that is easier? Carbon repair is much simpler and easier to access. Since the incidents you are referencing Google and the internet has become ubiquitous, try a carbon bicycle repair search you would be amazed.
#130
Quoted: 4227 Post(s)
Liked 2,491 Times
No, the reason people choose steel for touring is because quality steel frame can take some serious abuse and keep on going. Carbon may be OK for racing on smooth roads but it isn't practical for loaded touring in rough terrain and it lacks the utilitarian qualities and durability of steel.
Likes For wolfchild:
#131
Liked 2,491 Times
You're just going to have a random welder in Timbuktu repair a high end steel alloy tube? It might hold until you get home, sure. Is it going to be anything close to the original? No. It's going to be about as close as buying some CF, epoxy and sandpaper on Amazon and repairing your CF bike yourself (which would, again, probably get you home, too), and the material properties of the bike will be compromised..
#132
Liked 11,368 Times
Honestly, these old claims have a little validity. Sure, a bent steel frame can be cold set back into shape fairly easily -- just not by any old schmoe with some tools and no knowledge. But this idea that you'll take your frame to, say, a guy who fixes boat trailers and have it welded back up after a crash? Ridiculous. Laughable.
#133
Liked 7,667 Times
Likes For tomato coupe:
#134
Quoted: 338 Post(s)
Liked 408 Times
Here's an old, old article where frames were fatigue tested. While the forces are higher than normal for a rider climbing out of the saddle (cca 750N for a relatively light rider putting out a mean torque of cca 85Nm), they are significantly below maximum achievable on a bike (for instance, if you do accelerations into a sprint from a standing as part of your training, forces over 2.5 times the cyclist body mass were measured - about 1900N).
12 High-End Frames in the EFBe Fatigue Test (sheldonbrown.com)
#135
Quoted: 18596 Post(s)
Liked 16,096 Times
Yep.
But…That was in the late 90s, and the bike was older, so the tubes were likely thicker that today’s tubing. That’s a big “but.”
Likes For indyfabz:
#136
Liked 16,096 Times
Likes For indyfabz:
#137
Liked 11,368 Times
Likes For Koyote:
#138
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1267 Post(s)
Liked 341 Times
Baloney Koyote .
Every little town in Asia has a welder/ brazer who can fix anything steel. Won't be fancy or lasting most likely of course.
I broke my fork near the top at the same spot 2 times in Vietnam and again in the middle of Chengdu. Average cost was $10. It was rusting along the way as well.
The first break was perfectly clean, like cutting paper with scissors. My drum brake was too good, but the fork was made really poorly also.
CF repair is mostly about supplies than skill. It might depend if you are tight for tire clearance.
I did a test with wrapping CF around a broken fork. Then 2 days later whacked hard it with a hammer. ZERO dent.
#139
Liked 11,368 Times
Baloney Koyote .
Likes For Koyote:
#140
Liked 16,096 Times
#141
Quoted: 338 Post(s)
Liked 408 Times
So, with a bit of CF and epoxy you can bodge a CF repair yourself which won't be pretty or quality, but will hold... just like finding the village welder to fix your frame?
Likes For Branko D:
#142
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Actually…I was on a supported tour. A participant broke his frame (IIRC, it was one of they stays near a read dropout.) He found a local welder who fixed it. He finished the tour and continued on to his ultimate destination credit card style.
Likes For Lombard:
#143
Liked 16,096 Times
I dunno. The tour was through a lot of Pennsyltucky. Just rode across PA again in September. Seemed to be a lot of them still around. Saw several lawn mover repair signs in front yards. But, I will admit, no old school busses.
Likes For indyfabz:
Likes For phughes:
#145
Quoted: 8447 Post(s)
Liked 9,404 Times
Touring bikes don't need to be light. My first touring bike was a tank.
A carbon fiber touring bike could be built strong enough to outlast the next ice age. Downhill racing bikes, enduro bikes, and freeride bikes are made from cf and are subjected to punishment that a touring bike would never see. Even gravel bikes take serious abuse off-road and some brutal gravel races have been won on cf road bikes.
Here is some fun road bike stuff.
#146
Liked 16,096 Times
Especially since people who do a good deal of touring tend to be, um, “frugal.” I’ll never forget the two sweaty, dirty looking guys I met at a restaurant in Rexford, MT in 2019. The federal campground in town doesn’t have showers. They rolled their eyes and snorted when I told them the restaurant had showers for $6/person.
#147
Liked 9,404 Times
Yep.
The guys I toured cross country used bikes they already had. One was a beater with no name on it, one was an old Mondia which I think was an actual touring bike, and the other was a Cannondale touring bike he got used someplace.
Others I have done short tours with have used their regular road bikes, mostly cf.
#148
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1128 Post(s)
Liked 257 Times
Ah, yes, the semi-mythical stories about people getting local welders in Timbuktu to repair their steel-framed touring bikes as they heroically pedal around the world. Right. Tell you what: you go get a quote on having a top tube replaced (so, old tube removed, new tube welded or brazed in, including the cost of the tube itself), and don't forget the new paint job. I'll bet it comes to more than the cost of my friend's cf top tube repair, which was under $300.
While it is often true that steel is easier and less costly to repair (especially mere bends which can be cold-set back into shape), and many steel frames function just fine with dents here and there, it is not always true that it'll cost less than a similar repair to a cf frame. That's why I wrote it like this:
or do it yourself:
#149
Liked 257 Times
I can't think of anyone I know who bought a new touring bike. I got my first touring frame cheap from a friend and scrounged up parts to assemble it. I did buy new rims and hubs and lace them myself.
#150
Liked 9,404 Times
That could depend on where a person lives. Where I live it's very difficult to find a good used any type of bike, not alone a mid level or better touring bike. I had a touring bike I bought used but it got wiped out when a car sideswiped me and ran, so after months of looking for another suitable used replacement I came up empty so I bought a new one. I think people buying new touring bikes is more common then you think, I loiter around on the Adventure Cyclist forum and a lot of people talk about buying a new touring bike, a lot more than those looking for used ones. Some of that may be due to the buyer wanting the latest technology especially in brakes.
My point was acceptable touring bikes can be had cheap, even new ones.
