For the love of English 3 speeds...
Paul, can you expound? Firstly, what is the aforementioned "Sta-Tru 590 alloy front wheels?" Does this equate to what my tire size that says "26 x 1 3/8?" And will a said alloy rim work with my stock of 26" x 1 3/8" tires?
Also, if I'm understanding you, I would agree that alloy wheels from the '90s would be an appreciable betterment in performance. Especially if you care to eschew originality and save that (rolling) weight. So, if I'm getting your drift, why splurge on modern, new and expensive wheels for a rescued vintage (non-performance) ride if 1990's wheels/rims are available? Right? So, if I'm still correct in my reasoning here, what "modern" (1990's) alloy rims will fit my Raleigh/Robin/Herc/etc? IOWs, when I visit my local co-op, and the myriad wheel cache, what should I look for?
If I'm all-wet here, set me straight. Regardless, I will, as a rule, never think to replace those classic steel, original rims on my prizes, but I might, just maybe, experiment with myriad, and unoriginal projects be-damned.
Totally in agreement; it is very satisfying to get everything back together and working right. I especially feel this if I've done some cleaning at the same time.
The original steel rims on my Sports were so far gone they had to be replaced, I had no choice. To simplify I bought SunRingle's CR18s (alloy) in the exact replacement size. I don't remember what they cost in 2013, but although they weren't nothing, I wouldn't say they were expensive. And no spoke replacement was needed, except for one that was stubborn and broke. And at the LBS it was $10 to tighten and true each one. Performance wise are they better than the originals, if those had been in good shape? Not sure.
Now I have a '63 Rudge coming along. I haven't seen the bike yet except in photos but I think the rims are usable if not cosmetically perfect. I want it to be a scorcher, but it's too soon to have made all the little decisions. And as the bike wouldn't be a commuter, Panaracer's Col de la Vie tires are very tempting.
I'd just like to build something 3/4 as nice as some of the bikes I've seen in photos here.
One reason the CR18s are liked is that in the EA-3/590 ISO (oy vay) size they are available in a polished finish that doesn't exactly mimic the chromed steel but at least keeps the spirit of the original.
Liked 337 Times
Bikes are okay, I guess.
Liked 2,452 Times
In my experience most English ladies' Sports-type bikes are either 19" or 23" and this one looks smaller rather than larger. I have one of each and they're pretty easy to differentiate. There may be 21s or 22s out there but I have not seen them.
Right now I'm partway through moving many of the parts from the 19" frame to the 21" frame. I can ride 21 and 23 happily enough. 19" is a less happy ride for me.
Anyway, here's a crude field guide to sizing
Main frame tubes:
I *think* the downtubes on the 21" & 23 are more nearly parallel than on the 19. It's hard to tell in pictures, but when you're looking right on one size the downtube ("displaced top tube?) is not quite parallel to the lower downtube. I believe on the 21 & 23 they are for all practical purposes parallel, but I could be wrong and maybe it changed from one year to another.
Head Tube:
The gap between the top & down tubes on the 19 is less than on the 21 or 23. The step-through 23 head tube appears to have the dimension of the men's 25. I haven't measured it, but the 21 and 23 may have similar displacements.
Seat Stays:
This is a pretty good tell. The 19" has maybe room for 4 or 5 fingers between the brake bridge and the seatpost bolt. The 21 has room for a couple more, but the 23 has stays above the bridge about the length of a fresh #2 pencil. Or if you prefer, it should accommodate a decently sized cabbage between the seat and the fender - with the seat all the way down.
What I measured at 23":
![](https://farm9.staticflickr.com/8238/8584790136_44d15c1628_z.jpg)
On the road
Bikes: Old Schwinns and old Raleighs
Liked 948 Times
Thanks. Yes - Banjo Brothers Minnehaha barrel bag. I have a bunch of them because they're just the right balance of low-cost; compact size; and hauling capacity for a short ride. They look pretty nice and are easy to fit. This particular bike has the darkest shade of Raleigh green I have seen.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
On the road
Liked 948 Times
I'm not a huge fan of the older Sturmey coaster brakes. The TCW hubs do have the "neutral no brake" issue, though that can be avoided with careful adjustment. I think the bigger flaw for us today is the fact that the TCW relies heavily on a rather weak E-clip to hold the transmission on one side and the brake on the other. If you take apart the hub, you'll find the axle has a groove and the E-clip that rides in the groove. Also of concern is the fact that the braking power fluctuates based on which gear you're in.
If a TCW has been ridden hard or abused by slamming the hub into 3rd while applying the brake, you'll find the E-clip tears around the edges and jumps out of the axle groove. At best, this causes the hub to stop working in 3rd gear, but will still run in 1st and/or 2nd. At worst, it will lock the rear wheel. The solution is to partially disassemble the hub and get the E-clip back into place. Sometimes you can do that by only tearing-down the brake side of the hub.
In order to get 2, decent and working TCW hubs for a pair of bikes I rebuilt several years ago, I needed 4 TCW hubs, and then to assemble parts to make the best 2 hubs I could make.
On the plus side, the old coasters have smooth braking action and a relatively positive feel when applying pressure. I wouldn't ride a bike equipped solely with a TCW hub - I'd want a hand brake along with it.
Liked 337 Times
I am a fan of the S3C. As a tinkerer of all bikes (speeds of 1, 2, 3, 5, 10, 12... can I stop?) with brakes of all sorts (don't get me started). Optimistically thinking, you kinda get the best of both worlds with the SC3 don't you? Of course, as long as you don't forget that you don't have that rear caliper. Oh, and when you change to a regular AW or derailleured bike, that you don't have that solid and sure coaster brake to "back" on. Oh, and you can't free-pedal back-pedal at a 10-o'clock position at a stop light - there's that. Alas. Regardless, I appreciate them all.
One of my "next" bikes I'll install that rear caliper on a classic roadster coaster 3-spd to help alleviate that cursed muscle-memory-bike-swap problem that can happen.
Hi all,
A few days ago, a friend of mine dumped the “wreck" of “an old Raleigh" at my door.
He was on his way to the local recycling centre, but wondered if - maybe - I could use it, as I own a few post- Raleigh takeover Triumph bicycles.
Of course I could![Smilie](images/smilies/smile.gif)
The “old Raleigh" turns out to be a 1980 Superbe in pretty good condition, though it has been in the open air for quite some time.
Today, I had a closer look and started to clean it up a bit.
I plan to use it as my daily ride instead of my - 3 speed - 1954 BSA Tourer.
Digging in my boxes of Raleigh stuff, I found some better brake calipers and other usable parts to make it a reliable bike...
Rear ( stainless steel ) rim was dented, but I managed to straighten that out and the wheel turns smoothly now.
Peter
Of course I could
Peter
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Liked 445 Times
Hang on to Your Nuts!
I was browsing Amazon and saw this axle nut priced at a reasonable $42.14 (plus shipping).
Also listed, an axle key at the bargain price of $51.92 (plus shipping).
Liked 167 Times
Attachment 607213
Attachment 607214
Attachment 607213
Attachment 607214
![Roflmao 2](images/smilies/roflmao2.gif)
Bikes: Raleigh Sports
Attachment 607213
Attachment 607214
Attachment 607213
Attachment 607214
Hi all,
Peter
Of course I could
Peter
This bike should clean up nicely. Love the color. I have a question. All light roadster frames had a round lug brazed into the drive side chainstay for mounting an enclosed chaincase. They did away with these in the early 60s. How were the chaincases mounted on these later frames? Does it have anything to do with that stamped piece the kickstand is mounted on? That piece is something I haven't seen before. There used to be a tube there.
On one of my elderly italian bikes the chaincase is held by the drive side bb cup.....
Not so with the DL-1. Every one I've seen has the lug.
The brazed-on lug is there and I do like the stamped plate the kickstand is mounted on too. Far better than the aluminum clamped- on stands.
BTW, I didn' t find any frame number on the bike. Rear wheel has a 3-speed Sturmey from 1980 that I think is the original one...
Peter
Hi all,
Peter
Of course I could
Peter
Then there's the Dutch market machines, that are similar again but only came with drum brakes.
What really bugs me is that in the UK from the early 70s onwards they only advertised the one model of Superbe, what used to be called the dawn tourist, rod brakes and mattress saddle. Yet every now and again ones like yours pop up with caliper brakes and adjustable handlebars, with no explanation. I've even seen one come up looking like it'd never been ridden, but in black instead of green.
I can't tell if all these unadvertised and undocumented variations were intentional or if they were just throwing together whatever they found on the shelves.
Overdoing projects
Liked 1,304 Times
Just got my hands on an alloy Stumey Archer FM 4-speed hub from 1956 with matching 4-speed shifter. I'll probably have to take it apart and spend some time finding a 40-hole wheel that fits the bike but it looks like I'll be turning my Gazelle Superlicht into a clubman racer.
