Bianchi Serial Number Identification
#1601
Quoted: 4722 Post(s)
Liked 3,048 Times
Hello and thanks! It does not have eyelets on the dropouts, and the brakes are Modolo 'America'. I believe European models of the same bike had Modolo 'Flash', and I suspected it was simply a branding choice, since the calipers on these two brakes appear almost identical. I will measure the seat post and get back to you. The cranks are Ofmega, although once again I believe, but will also double check this. I am also unsure if the paint colour is original. Up close it appears to have been repainted (some what poorly), although parts of the frame might be original paint (the rear triangle look has a clearly higher paint quality than the downtube). The old girl has definitely seen some use and rebuilds over the years.
Edit: The chainring bolts and axle nuts are stamped 'Ofmega', but there is precious else to go on in terms of markings on the crank arms themselves.
You shouldn't need to measure the seat post. The size should be stamped into the post. The usual locations are at the top of the tubular section or on the lower tublar section, just below the minimum insertion marks.
#1602
Hi can I check if the experts here can help identify my Bianchi SL3 Reparto Corse. Celeste green gradient. SL Carbon fork. Passed down to me but since I stumbled upon this very interesting thread, I was just too curious not to ask...
Serial number TE1432251V.
Many thanks in adv.
Many thanks in adv.
#1603
Bianchi Goddess
Quoted: 2969 Post(s)
Liked 3,064 Times
Many thanks in adv.
Many thanks in adv.
Sugar "Kane" Kowalczyk
#1604
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR-5 Viscount Aerospace Pro Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista
Quoted: 3130 Post(s)
Liked 6,801 Times
Many thanks in adv.
Many thanks in adv.
Bianchi Goddess
Liked 3,064 Times
Those wheels must be a later addition. The closest I can find online is the 2002 SL Aluminum Centuar. The frame graphics are different but this could be a catalog V actual production or even a regional thing.
It seems the SL3 designation might refer to the later model with carbon stays or again could be regional. It's also possible this is a different frame built up with Centaur so it looks like the SL or SL3
https://www.bikepedia.com/Quickbike/...spx?item=37573
#1606
Quoted: 5 Post(s)
86-87 Blue Campione del Mondo
Hey everyone, would really love some help getting a solid ID on a vintage Bianchi frame I bought. Turns out Bianchi serial numbers are a nightmare.
Color: Mediterranean Blue
Details: Campione del Mondo 86-87 decal
Serial Number: 61126937
I only have the frameset, no other components. Initial digging makes me think squadra? I can't seem to find any other blue frames within those years. Any help is appreciated! Unfortunately cannot post pics as this is a new account.
#1607
Bianchi Goddess
Liked 3,064 Times
#1608
Quoted: 5 Post(s)
Bianchi decals on the downtube and seattube, nothing on the top tube! Edoardo Bianchi sticker where a head badge would go. Colorado Springs sticker is rectangular!
#1609
Forum Moderator
Liked 6,801 Times
Liked 3,048 Times
#1612
Bianchi Goddess
Liked 3,064 Times
That is a Broadway a pretty basic all terrain bike but we didn’t recommend taking off the pavement very far.
HiTen frame and fork and pretty basic everything else.
#1613
Liked 3,048 Times
I'd be hard pressed to call this an "all terrain bike" when the tyres weren't knobbies, were only 1.5" wide and the crankset was only a double with a 38T low. I'd classify his as a city bicycle, though it could be used for very light off-road excursions such as flat fire roads and picnic grounds.
#1614
Quoted: 5 Post(s)
#1615
is this a Bianchi frame / fork?
I am trying to learn a bike frame and fork is a Bianchi, and if not, does anyone have any ideas? Would anyone know where I might get lucky and find a catalog or original bike specifications? I tried to post photos, but as a relatively new user it would not let me do that. If anyone has a work around for that problem, let me know.
The frame/fork I'm looking at has been changed substantially so many of the original parts may be missing, and some additional parts have been added. The downtube and seat tube have been sprayed with a darker blue paint right over where the Bianchi name labels would be, but I think the top tube and upper parts of the seat tube, etc. may be original paint which is a lighter, sort of royal blue metallic paint. The reason I suspect it is a Bianchi is that many of the frame details are the same as a gray colored 1984 Bianchi Alaskan that I have seen on this website an on a johns-recycled-bicycle blog (bikeforums also won't let me post a URL yet), but the fork is different and the paint color is different. I have had one discussion with a bikeforums member who suggested this might be a different color because it is a Bianchi ATB instead of a Bianchi Alaskan. The fork on the 1984 Bianchi Alaskan is a bi-plane crown design. The one I'm looking at is a brazed crown/leg connection, but not bi-plane, but otherwise the shape and dropouts are identical. Apparently both ATB and Alaskan may use the same frame with these details: The front triangle is welded with a unique gusset under the head tube/top tube joint. The rear triangle appears brazed to the front triangle with lugged/inserts at the chain stay/bottom bracket joint and scallop ended external brazing of the seat stay/seat tube joints . The cable housing guides and stops are unique; 3 sort of bent triangular brake housing guides on the top tube and 2 double cup shifter housing stops on the down tube . All of these features match those I've seen on the 1984 Bianchi Alaskan I previously mentioned. A label on the upper seat tube states "Cr-Mo 3 Main Tubes" just like on the Alaskan. There is a Made in Taiwan decal on my bike near the bb too, and if that is correct, the serial number 51003793 seems match the "KHS" manufactured serial number pattern that I have seen associated with Bianchi in the "Asian Serial Number Guide" provided by T-Mar in other posts on this forum (suggesting a 1985 manufacturing date). The bike also has DiaCompe cantilever brakes, Suzue hubs and Araya 26x1.75 alloy rims, if that helps. Not sure if those are original, but they appear to be. Stem/handlebars/grips don't look original to me. Derailleurs are gone.
Again, if someone can help figure out how I can attach photos, that would make this much clearer. Meanwhile, any ideas are appreciated.
#1617
I have an S9 Matta of as of yet to be determined age. The guy I bought it from said the guy he bought it from claimed it was a 2006. I checked with a local shop that was a big Bianchi dealer back in the day and got a firm maybe. The parts and pieces on it led the shop to believe it was purchased as a frame and fork.It was covered with a mix of several bike's decals, mostly Bianchi with no paint except the celeste lettering on the bottom bracket. I got bored and cleaned them off and let a local metal polishing shop make it shine. I'm in the process of putting it back on the road and while knowing when it was made would be nice I don't think it's going to ride better or worse for not knowing. I'd post a picture of it but appears I haven't reached picture posting point yet. It reads as L1167 with a sideways S underneath that and with 51 next to the S. Guesses are welcome, educated or not.
#1618
Liked 3,048 Times
To identify the exact Bianchi model we'll require phographs and/or brands and models of the major components (derailleurs, crankset, brakes). I see there are some chain photos in your gallery album but none of the Bianchi, so you've uploaded photos in the past.
#1619
Liked 3,048 Times
Welcome to the forums. The serial numbers suggests October 1985 manufacture. That is late enough in the calendar year that it should be a 1986 model. The only Bianchi ATB I've seen from the mid-1980s that used lugless construction was the Alaskan but it wasn't produced after 1984. It does appear to be from the same contract manufacturer used by Bianchi for the Alaskan. The frame looks similar but the fork is different. I don't think this was originally marketed as a Bianchi.
At least the gusset did its job and prevented a bent frame, though the fork was not so lucky. It looks like you've got a big project in front of you.
Sample photo assist. More photos here: https://www.bikeforums.net/g/album/23369629
#1620
Liked 3,048 Times
Likes For T-Mar:
#1621
The serial number is consistent with a Japanese manufactured model from August 1988. That's in the grey region where it could be either a 1988 or 1989 model. Provided it still has its factory decals, it should be easy to identify the model year, as the 1988 models used the round Campione del Mondo Colorado Springs 1986-1987 decal.
#1622
#1623
Liked 3,048 Times
#1624
The bike had an ITM stem and bar combination from the nineties on it on a Cane Creek C2 headset. It was set up as a 3X9 with Ultegra brifters, cranks, ultegra rd6500 with a dura ace front d. The wheels were from Rolfs from 2004 or 5. No carbon stays, typical ugly ti welds and a Bianchi carbon fork without a label on the steer tube. Lot's of Bianchi decals, both celeste and blue along with shimano and a few small campy stickers for good measure. I see one set of new decals online for a supertube bike in blue that would work on it but I have to admit that I like this clean look.
Likes For noirwest:
#1625
Bianchi Goddess
Liked 3,064 Times
Suntour AR derailleurs, Dia Compe 500 brakes, Custom A crankset. “Asking for a friend”
