For the love of English 3 speeds...
Bikes: Bianchi Volpe, ANT 3-speed roadster, New Albion Privateer singlespeed, Raleigh One Way singlespeed, Raleigh Professional "retro roadie" rebuild, 198? Fuji(?) franken-5-speed, 1937 Raleigh Tourist, 1952 Raleigh Sports, 1966 Raleigh Sports step-through
Liked 27 Times
I am puzzled about one thing. Height at the top of the seat tube is the same as on my Raleigh Sports step-thru (21 inches from BB to top). But at the front, there is a 2-inch difference in the length of the head tubes, which puts the Rudge MUCH lower at the front (I mean the top of the head tube) than the step thru Sports. I did not expect this.
Phyllo-buster
Liked 2,069 Times
I think the women's frames taller headtube gives the top/downtube(s) enough separation to maintain adequate structural integrity.
One more photo.
This bike is fine. So much for repainting—that’s over. It lacks the hand chainring, but has the old style brake cables and an oil port in the BB. Plus the head tube badge and frame decals, wow. The hub says ’63. Rims? Eh, that’s not superficial rust, I don’t think. Other chrome is darn good. The indicator chain was broken, you’ll see that in the snaps, so I put in a new one and it shifts nicely. Need to pull the left side crank out; it nudges the left chainstay. The B72, well, with plenty of foam crammed underneath, it might give me a little time.
Or, a later style right side up faceplate with no embossing, just printed on graphics and a ball and keyhole style ferrule. The change happened around 62-63.
I really like this bike. Always been especially fond of Rudges.
Nice! You got a good one. I suspect the left side crank is bent. Easy fix. The paint, transfers and chrome look really good. I love bikes like this. Needs some work, but has tons of potential. For me, it's fun to pick away at the things that need fixing. Looks like somebody changed the shifter at some point.
Bikes: Raleigh Sports
Niagara does sell long stems that are style appropriate and "north" style bars, both in 25.4, and they're not expensive.
Too bad if you replace as the ones on the Rudge look to be in good shape.
I'll straighten the crank, no problem. God knows how many times they needed pulling out on my bike when I was a kid. I was wondering about that shifter.... The grips don't match, so, no surprise. But the paint! It is so good! Now I've got it, how do I deal with those old-style brake wires if they need replacing? Just screw something to the end of the new wire to anchor it in the caliper?
There were extra long stems, but I think they were rare. Problem with replacing with a repro is bar diameter. The old steel bars were small diameter -- about 23mm, as I recall.
I hope you don't need to change them. I never do unless they're frayed. I have seen people use cable knarps, but the cleanest method is to silver braze a piece of steel that fits the caliper onto a new cable end. Another method to swap out the calipers for later Raleigh calipers that use a pinch bolt.
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Liked 445 Times
Re Brakes
Those cables (NOS) are pretty hard to find these days and
expensive.
I generally replace the calipers with second generation ones that accept a regular cable.
BC's advice to build custom cables is another option.
Paint and decals all look good.
You can try cleaning the rims with tin foil and water
but I suspect some of that rust will remain.
Keep your eye out for discarded rims outside bike shops etc.
These projects can be a "Slow Burn".
I found a rounded crank arm last week and installed on a project I
had "finished" 2 years ago.
Keep the photos coming and try to document your progress.
Amongst the parts included with this basket case was a rounded crank that made it's way over to this bike.
Bikes are okay, I guess.
Liked 2,452 Times
Looks like they're breaking up the set that was advertised for $150.
https://richmond.craigslist.org/bik/...565325045.html
Vintage Ladies Raleigh City Bike - $50 (Chester, Va)
![](https://images.craigslist.org/01717_ezAE9Pe44pj_600x450.jpg)
East Hundred Road
condition: good
make / manufacturer: Raleigh
model name / number: Sports 3 speed
size / dimensions: 54cm
Ladies Raleigh Sports 3 speed, very good condition but will need tires for daily use. Frame
measures 54cm and seat and grips are included. Call or text show contact info
for more info.
East Hundred Road
condition: good
for more info.
![Love](images/smilies/1luvu.gif)
Liked 445 Times
Yes!! That's part of the fun. I like this Rudge a lot. To me it's very much worth long term touch ups. I would have fun hunting down better rims, pinch bolt brakes if it needed new cables and a period correct shifter. Someday I'd get it a new Brooks B66 and a Carradice bag
At first, I think I would just do the normal servicing, clean and touch up rusty spots on the paint, go over the paint with polishing compound and wax and ride it for the summer.
Get it serviced and on the road and then work on the upgrades/improvements etc. as time permits.
+1 on the tin foil for the chrome - most of not all of that surface rust will be gone with a little elbow grease. I use WD40 as a bit of a lune when I do the foil trick.
Liked 1,467 Times
The '63 Rudge above is almost identical to the one I had when I was a college student in the 80s - only mine had a front dynohub. It was a wonderful bike and is one of exactly two bikes I genuinely wish I had hung onto. I suspect you will find it to have a special ride quality that I somehow never quite got out of the allegedly identical Raleighs. Maybe it was all in my head.
Beautiful bike, btw.
multimodal commuter
Liked 575 Times
www.rhmsaddles.com.
www.rhmsaddles.com.
multimodal commuter
Liked 575 Times
Another way to make a custom cable is to crimp a spoke nipple onto the end of the cable. You need all the correct Raleigh small parts from an old brake cable, as well as new housing, cable, and a spoke nipple. If you use a proper crimper tool, the spoke nipple is virtually impossible to remove. For a crimper, I especially like one made by HPK for Bell Systems, by the thousands, back in the days of land line telephones; available on ebay for $10-$20. If you get it in the wrong place, you need to cut it off and try again.
www.rhmsaddles.com.
www.rhmsaddles.com.
All great suggestions. Thank you all. I hadn't thought of using WD40 with the aluminum foil. This bike is much cooler than what I anticipated. I keep the Sports step thru mechanically perfect because I ride it so much, but looks-wise it's kind of a beater. That won't fly with this Rudge. First thing is straighten the crank so I can spend time on it. It just nudges the chainstay and I want to avoid making a spot in the paint.
I don't think so. I suspect the shifter shown is made in England, but not by Sturmey Archer. Brampton made shifters that looked a lot like that --same curve to the trigger, anyway. More than a couple other English companies made Sturmey Archer hubs under license; BSA, Brampton, and Hercules come to mind, and I may be missing something.
