However, the main issue is if you want to climb out of the saddle, the bag almost always grazes your inner thighs.
Reflective Sidewall Tires
Hey guys! I'm new to this forum but I hope to get some good advices.
I've got my new equip from Amazon and now it's much easier and safe to ride a bike during rainy days. But nevertheless I'm still wondering about reflectors for late night riding especially in wet weather. Does anyone have info about cool reflectors?
You'll probably want to research front and rear lights. Consider seeing (the road)vs. being seen (by others).
Aside from that, reflective sidewall tires can boost your visibility to cars:
Don't know about their durability, but https://www.ridewithfiks.com appears to sell kits you can apply to your current tires. My preference would be to buy a tire set with reflective sidewalls from the manufacturer. Try Schwalbe Marathons.
And there are also vendors who sell reflective striping kits for cars that you could apply to your bike's frame:
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Recently I've moved to Mawsynram, India. If you don't know this place is full of heavy rains. So I was forced to learn a lot of info about riding in wet weather. Thanks to bestadviser.net/how-to/how-to-keep-riding-in-wet-and-cold-conditions I've found all info that I need. I've got my new equip from Amazon and now it's much easier and safe to ride a bike during rainy days. But nevertheless I'm still wondering about reflectors for late night riding especially in wet weather. Does anyone have info about cool reflectors?
-Tim-
Quoted: 1814 Post(s)
Liked 923 Times
Around-town bike shoes.
REI, sale $35 with dividend applied.
Replacing some with regular laces that are wearing out but also require care to keep from getting the laces in the chain.
Quoted: 7397 Post(s)
Liked 2,572 Times
I bought some things from biketiresdirect, and they arrived yesterday.
Pearl Izumi bib shorts
gloves
a cue sheet clip
Park Tool magnetic bowl
I normally wear size medium, so that's what size bib shorts I ordered. They're tight, but I'll keep them. I rode them to work today, and they're not bad. I'm not sure I should order size large next time. I'm probably on the cusp.
I normally wear size extra large gloves, and I was really annoyed to see I had received size medium. I can't even get my hands in them. I checked the order. Oops, I ordered medium. I told my wife to keep them.
gloves
a cue sheet clip
New toy - did rear wheel redish (5 sp to 6 sp freewheel) and some truing.
Is there any good trick to do right the vertical truing? Every time I tried to tight or loose I got the lateral true off and not much improvement on vertical. Since is minimum I just left as is....
Bikes: 2018 Specialized Roubaix Comp, 1995 Trek 470
Quoted: 62 Post(s)
I just got a new headlight, the Niterider 950 Boost OLED. I was just going to get the regular (non-OLED) one, as the OLED models usually retail for over $100, but Bike Closet had this one for only $60 (plus shipping; I threw in some extra tubes which also had a great price to make it worth it) so I couldn't resist. I have to say, with bike lights having so many different modes and brightness settings, it's actually really helpful to have the little display so you know what setting you're on, and it's also very convenient having an idea of how much run-time you have remaining. Overall, with a little usage, I have to say I'm very impressed with this light. The mount kinda sucks though; it doesn't stay in position that well, but there's a lot of 3rd-party mounts for Niteriders so I might end up getting one of those eventually. Personally, I wish there were some way of combining a rigid mount with my bike bell (a clone of the Spurcycle) to save space on my handlebars.
Before this, I think my most recent purchase was the aforementioned bell. It's a "Rock Bros." bell, which is a very good clone of the Spurcycle, and only costs about $9 (with shipping!) on Ebay. It also looks better if you want color options besides black and stainless-steel, since it is also available in brass and antiqued brass finishes. I got two of them, one for each bike. I do recommend the simple modification I read about somewhere to protect your expensive handlebars from scratches, which is to put black heat-shrink tubing over the steel mounting strap. I did this and it looks great, and prevents any kind of scratching or rubbing on my nice bike's black handlebars. I didn't bother with my old bike though.
Before this was a "Gravity USB" taillight from PDW (Portland Design Works). It has an accelerometer so it acts as a brake light when you slow down. Only about $42 (w/ shipping) from A-main cycling.
Quoted: 1332 Post(s)
Liked 398 Times
New hat. First good Bontrager thing I've owned, and I'm actually really impressed with it.
Kit doesn't match
I've done the same thing with gloves and socks... instant gifts!
Liked 2,572 Times
Yes, address two spokes at a time. When doing lateral truing and the rim is too far left, loosen the left and tighten the right so that you don't create a low or high spot. When doing radial truing and there is a high spot, tighten a left spoke and the adjacent right spoke so you don't take the lateral off.
Liked 2,572 Times
A quarter turn is often a good amount. More if the change needed is big, less if small.
And if I turn more than 1/4 of a turn, the previous and following spoke (and their counterparts) will be turned by half the turn of the main spoke (so if that one was 1/2 turn, the spoke before and after that spoke will be turned by 1/4 of a turn).
- Soli Deo Gloria -
Liked 736 Times
Rapha Pro Team on sale at Competitive.
Thank you Sylvain!! Makes sense - lets see if I can get the radial truing right
Mitochondriac
I just ordered a set of Hunt 50 Carbon Aero disc wheels. Can't wait for them arrive in late October...
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
Stuff is arriving........
This just came last night. Rims, hubs and spokes in transit.
never tried them on (or any cycling shoe), just ordered from the uk, sure hope they fit...im typically a us 9 or in a few cases 9.5...they only had 9.5 so hoping they work out and are comfortable. normally $200, got them for $118
Bikes: Specialized Crux Elite X1, Specialized Roubaix SL4 Expert, Specialized Crux Disc
This guy!
Gary F.
2019 Specialized Crux Elite X1
2015 Specialized Roubaix SL4 Expert
My bike page: https://www.gwfweb.com/bicycles
Build a bike stand! https://www.gwfweb.com/bicycles/stands.html
Gary F.
New Kickr Core smart trainer.
Also a pair of these in 26" for my commuter:
Interocitor Command
ProBikeKit emailed me a 12% off code so I just had to use it. Bought four Continental GrandSport Extra tires in 700x32 and a 5-pack of innertubes.
Foldable, made with PureGrip compound and has a double NyTech breaker.
https://www.continental-tires.com/bi...nd-sport-extra
