Sekai Bicycle Database
#176
Bikes: '87 Centurion Iron Man; Cannondale CAAD 9
.......the serial number stamped on the BB shell is Y78 1218620 (the zero is incomplete, but that's what it is, I think).
Note the front hub is labeled Sekai, but is stamped Suzue as the maker.
Otherwise, it appears pretty standard for a late 70's bike (guessing).
It's for sale at 150 bucks, if anyone's interested. The back wheel is a
replacement, and not a particularly high quality one, but we put new tires on it.
Yeah it's a 1977 2400 which is kind of interesting, that 2400 I picked up is a 78 I believe and has DT shifters and a few other differences but that bike is really clean! (At least after you guys did your magic to it). I'm sure it's gonna make someone quite happy at that price too.
#177
Bikes: Sekai Sprint
I have a Sekai that I got for free a few months ago. I pumped up the tires and straightened the handle bars and away I went. Seems to be all original and all was great until the back tire blew out the side because they are original tires. Any idea on what year or model this is? I can get more specs if needed. any help would be greatly appreciated. I'm thinking of selling it as is because I don't have time or know-how to save this bike and would like it listed correctly.
https://spokane.craigslist.org/bik/4116356685.html
#178
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Liked 21 Times
Norco was the Canadian distibutor for Nishiki in the 1980s. Some Norco bicycles were manufactured by Kawamura, who manufactrured most, but not all Nishiki during this period. Your particular Norco is a 1984 model model manufactured by Yamaguchi. If you can post pictures and/or the brands and models of the major components, I should be able to identify the model and position in the line up.
#179
Cyclist
#180
Version 2
https://www.ece.ubc.ca/~gillies/sekai...eftSeatlug.JPG
I will have to find S/N and date codes, but I am seriously wondering if there were two different tubesets at the same time for the 2700, or if there was a just a wholesale move away from the hi ten tubes in 1979-1980?
HI, I have a bike that has your ver 2 sticker , and curved seat stays.
If you flip the bike onto the seat and handlebars, you can read the serial number which is on the bottom of the bottom bracket
My bike starts with Y79 ------
My bike was built in 1979, and purchased in the spring of 1980
#181
[QUOTE=BlackFoxSees;16148286]
S#: Y79 - 0507051
I believe it's a 1979, based on the serial number and components. Sekai seems to have used a pretty straightforward serial system, which I guess they altered between the late 70's and '81. I'm under the impression that most of the components are original, but a mechanic suggested that the brakes aren't.
/QUOTE]
I strongly believe your bike frame was built in 1979
S#: Y79 - 0507051
/QUOTE]
#182
Hogosha Sekai
Liked 21 Times
Updated update: Added navigation links. Update(Compressed my multi-post On this page), navigation on pg 1 is now updated, serial checking updated, a few decal graphics added, and general page 1 clean up.)
I'll do some digging and check to see what the difference in their 70's/80's date codes and get back to this we'll have some confirmation. Too bad T-mars on hiatus he'd have the definite answer.
Compiling. And T-mars still invaluable even if he's not posting any more.
80's format, Yamaguchi and Miki serials should match other than initial letter.
Digging 70's info still.
https://www.bikeforums.net/archive/in.../t-873496.html
https://www.bikeforums.net/archive/in.../t-586624.html
Okay.
80's Mikki's and Yamaguchi's formats SHOULD follow this.
Myfxxxx, where y is a number designating the year and f is a letter designating the fortnight.
At least for some Sekais the Y## format and m ## one should actually equate like eclipsegirl thinks, however this does not apply to all Sekai formats.. apparently not even all Mikki or Yamaguchi manufactured frames. If you would like to contest this assessment, all I really ask is you site sources for me so I can update info accurately.
How can you confirm it was built in 1979? That's another piece of info I'd love to have for the resource.
Apparently, Miki made both Sekai and Sakai frames. Sekai frames were manufactured by Miki and assembled by Sakai Export. It not uncommon for a manufacturer to produce more than one brand. The serial number format should be Myfxxxx, where y is a number designating the year and f is a letter designating the fortnight. The same serial number format shows on on some Norco and Centurion models, though it is unclear whether these frames were made by Miki or another manufacturer with the same serial number format. For instance, Merida of Taiwan uses the same format.
Okay.
#183
Ride, Wrench, Swap, Race
Liked 1,392 Times
I had a Sekai 500 from the late 1970's or so. It had very-relaxed frame angles nearly as relaxed as a Schwinn Varsity or Continental!
Good thing then that it was in a very large (for me) frame size, as I was thus able to lean foreward fully on steep hills.
The bike had DB HiTen tubing, steel rims and was heavy, but rode very nicely.
I upgraded the crankset to an alloy half-step triple (with perhaps only a 36t granny) that was at least entertaining to use, that's the way I remember it.
I was able to trade the Sekai 500 for a nice, running Honda MC, so that's the last I saw of it.
#185
I doubt that Andy Muzi has the records that go back far.
I purchased my bike in the spring of 1980. My bike frame is unusual. It is made for small people. I am 5' 2" and have a very hard time large or average size frames. Not a lot of people would have been interested in that tiny frame.
The lug on the front stem is a single lug, not the usual two lugs.
Can I prove that it was built in 1979? No.
I believe that it was built sometime in 1979, and after export to the US, and then to Madison Wi, it was not an immediate seller and was in the shop in the spring of 1980, when I was looking for a bike.
#186
Hogosha Sekai
Liked 21 Times
And did anything materialize on your search for decals?
#187
Ah, I apologize if the previous posts appeared confrontational but I am simply seeking facts to attempt to solidify things to move this database forward in helping people. Would have been quite a missing link to be able to verify those points I'm sure you can see.
I did my own searching on the net, as I am sure you did too. There was one long article about the Brothers, helped by about 4 bike shops in the the US. I want to say that article was my source, but I am not sure.
Andy just handed me a nice set of white decals once when I went in there. For any one who is searching for Sekai decals, Andy Muzi and Yellow Jersey are the only one to get decals from. He got his from the widow of one of the Japanese brothers who started Sekai.
Given the right time and place, I will approach Andy about his knowledge of Sekais. Being one of the few dealers, and still in existence, he may have a wealth of info.
I encourage you to write to Yellow Jersey Privately and get him talking. He can be very intimidating. HE IS VERY OLD SCHOOL about bikes. Give him a chance and he may open up to you.
Andy is also in the middle of a move from Madison Wi to Arlington Wi. Less overhead. as stated, if you know you OLD SCHOOL stuff about bikes, are you are ? deferential to him, he is very informative.
#188
Hogosha Sekai
Liked 21 Times
I'd love to talk to either, but I am down here in the bay area and time is a limited commodity for myself trust me though, I've been contemplating a road trip to pick these brains while we still have them around! The nature of this seems much more like a face to face venture to me anyhow.
#191
Bikes: Sekai Sprint
Steve,
Any way to get those pics of the Sprint posted again because they are no longer available. I believe that I have a Sprint and was hoping to compare it with your pics because it doesn't seem like there are a lot of Sprints in this forum or anywhere for that matter. Mostly 2500's, 2700's and other randoms ones.
Thanks
Thanks
#192
Hogosha Sekai
Liked 21 Times
Steve,
Thanks
Thanks
https://oldtenspeedgallery.com/owner-.../#.UmbXGnAw3s4
Same bike pre-fix up
Another sprint can be found here
https://www.flickr.com/photos/mrjoeba...n/photostream/
One more sprint for good measure
https://www.bikeforums.net/showthread...=1#post8555354
#193
Bikes: Sekai Sprint
Thanks for the information. I have a Sekai sprint with lug nuts and a different crank than any I've seen and seems like the rest is original. The crank doesn't have a stamp on it at all either. It just seems like my Sprint doesn't meet the same specs as others and I wasn't able to find a serial code on the bottom. I have it listed on Craigslist and was thinking of selling it to get something better but wasn't sure it is worth it or not, or if it would be better to just fix this old Sekai up. Pasted here:
any ideas?
any ideas?
#194
Hogosha Sekai
Liked 21 Times
any ideas?
any ideas?
#195
Bikes: Sekai Sprint
My Sekai Sprint seems different than the others I've seen. It has a 3 Pin Seguino Maxy chainring and the cranks are cottered but I wasn't able to find any markings on the cranks. The serial number I got off of the bike was ID12566. It was stamped on the side of the vertical bar as there was nothing on the bottom like I've seen others. Is the Seguno 3 pin even that good and is it the original by chance? Any input would be great!
#196
I thought I'd add my bike to the database. Got this really nice Sekai 2000 for $90 off of craigslist. Ordered some nos down tube and seat tube stickers from Yellow Jersey. I'll just be doing a light rebuild of this one because it's in such nice shape. S/N is Y0F9054 so based on what I've read that puts it at about 1980. Suntour GT derailleur has a date code of WA so that puts them at about January 1980. The bike has a sticker form the original Velocipede bike shop that sold these bikes in Seattle.
#197
Bikes: old ones
Liked 10,458 Times
...very pristine and very colorful. You must be happy to have found it in that large size.
#198
Hey, I AM peddling!
Bikes: Dahon Espresso 26" and Raleigh Passage 4.0
Here is a photo of my Sekai 1000 - serial # Y1N1659 I was the original owner but sold it after getting a whiplash from a rear-end type car accident. I found it sitting alongside the road a few blocks from my house - it had A "FREE" sign on it so I picked it up not realizing it was "My" old bike. When I was cleaning it up I found the MN I.D. program number engraved on the bottom of the frame was in my handwriting and was my I.D. number. I took it to my favorite bike shop and had it overhauled - It looks pretty good for something that is at least 30 years old! Can anybody tell me what info is in this serial number? I think I bought this bike sometime around 1975 but can't be sure and I am curious. Thanks in advance for any info! 8-)
#199
Hogosha Sekai
Liked 21 Times
That appears to be a 1981 Serial.
#200
I just picked up a 1983(?) Sekai 4000 off of CL this afternoon. It's in great condition with just a little dirt, grease and paint chips. I'll get photos after I clean it up and it stops raining (so July maybe!). I was surprised that it was Tange Champion #2 tubing, does anyone know when they changed over from #1?
Sekai 4000
58 CM CtT
Color; Dark Silver
Frame; Tange Champion #2
FD/RD; Suntour Cyclone M-II
Crankset; Sugino AT w/2 rings
Serial # on BB; M3C05037
Sekai 4000
58 CM CtT
Color; Dark Silver
