Sunshine
Quoted: 11048 Post(s)
Liked 7,596 Times
Drum brakes worked just as well as disk did on the initial braking action, they stopped the cars, in a panic they would lock up the tires, and it was the tires adhesion to the pavement that stopped the car, not that they were drums or disks. The major issue with drum brakes was overheating and they would fade with repeated braking, the disk can do to. Brake Pad Fade (Mechanical Fade):
- Occurs with disc brakes.
- When a brake pad operates beyond its designed maximum temperature range, its friction material (brake lining) starts to degrade.
- Dynamic Brake Fade:
- Can happen with both disc brakes and drum brakes.
- In disc brakes, dynamic fade often results from using low-quality or unsuitable brake pads. It can also occur due to brake caliper lag (where the caliper remains stuck to the rotor even after releasing the brake pedal).
- In drum brakes, dynamic fade occurs when the brake material or friction surface of the brake shoe vaporizes at elevated temperatures.
- Brake Fluid Fade:
- Brake fluid can also experience fade due to excessive heat.
- When brake fluid overheats, it can form air bubbles, leading to a spongy brake pedal feel and reduced braking performance.
Quoted: 782 Post(s)
Liked 1,814 Times
So I will apologize to your wife up front on this one, but I realized that a couple pairs of my bibs really need to be replaced, so I ordered a couple Ultimate Adventure Bibs from Black Bibs.
Likes For jaxgtr:
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1128 Post(s)
Liked 257 Times
Quoted: 10254 Post(s)
Liked 5,219 Times
Picked up a new blendr light mount for the madone gen 7. Went with a different one, All my bikes have the MTB light mount, It’s nice, has a place for cables and such, However, the mount seems to wear out quickly and the light has a lot of play. My madone had started making a rattling noise and I could not figure out what it was. Took the light off and the noise stopped.
Also picked up a bat cage for the underside cage mount on my checkpoint. Dining a longer gravel ride on monday so need all the water I can carry. My camelback sketches me out.
Quoted: 782 Post(s)
Liked 1,814 Times
Check out this place for some 3D printed stuff. I bought a number of items from them for the tail lights as the Bontrager mounts as you said, weak or wear out. These are much better. They have a bunch of stuff, if you search terms like Trek, Bontrager, Garmin, Wahoo, etc. I bought the Bontrager tail light \ varia mount that attaches to my Versus saddle. It is fantastic, pricey, but worth it.
https://www.shapeways.com/product/6E...li=marketplace
Bontrager
https://www.shapeways.com/marketplace/tech/mechanical-parts?type=product&q=Bontrager
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 223 Post(s)
Liked 372 Times
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Likes For Shadco:
Liked 5,219 Times
Bontrager
Bontrager
thanks amigo, will def give one of those a try in the future. New light mount is already making noise……
Liked 5,219 Times
Quoted: 9660 Post(s)
Liked 6,366 Times
BeastMaster
Dahon upgrade
Upgrading my 2012 Dahon Mu P8 w/ a pr of Conti’s & a slew of LitePro components.
32mm replacing 42mm
Should lighten the load
The before pic
32mm replacing 42mm
The before pic
Sunshine
Liked 7,596 Times
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
Is this the wheelset? Its 1740g...what is the weight of your current wheelset? I would figure a 20" low profile box rim wheelset would weigh less than 1740g.
Admittedly though, I know nothing about the component weights of folding bikes.
Quoted: 645 Post(s)
Liked 1,553 Times
Just ordered a Kask Protone Icon helmet to replace the Smith I’ve been using for years.
Likes For Ogsarg:
Quoted: 682 Post(s)
Liked 456 Times
* It probably isn’t because you can’t mount that upside down thanks to its lensing. Would be like having main beam on all the time.
Quoted: 682 Post(s)
Liked 456 Times
Just bought one of these Stashed wall-mount rails to try to clear some of our garage floor of bikes. Planning to get it installed tomorrow.
https://www.stashedproducts.co.uk/pr...ge-system-wall
BeastMaster
BeastMaster
Additions to my bike tool box
To complete my folding bike upgrade, needed some new and improved tools.
Sunshine
Liked 7,596 Times
Buys a heavy wheelset to lighten a bike, but doesnt know the weight of the current wheels.
Buys random Amazon stuff and poorly redacts the Amazon prices, as if knowing the prices is bad or matters.
...this has quickly become my new favorite BF thread.
Keep
It
Going!
Keep
It
Going!
Likes For mstateglfr:
BeastMaster
WOW, judgmental aren’t we.
New bar plugs installed, nice little detail. The logos could be printed a little more centered, but whatever, they're at least both the same.
Before:
After:
Before:
After:
Liked 5,219 Times
Is that the crazy expensive and heavy Bontrager commuter pro light*? I bought one and it rattled from minute one. Replaced it with the slightly less expensive but still overpriced one.
Used it for 4 years. No issues. I ride mostly at 4 am in the dark so it works well. Better than any other brand I have used.
Quoted: 682 Post(s)
Liked 456 Times
Quoted: 1207 Post(s)
Liked 1,371 Times
Added a Gopro mount to the Black Inc handlebars. Test fitted my new GoPro10.
2015 Bianchi Intenso
Likes For malcala622:
Liked 1,371 Times
Bianchi polka dot jersey
Liked 5,219 Times
Likes For bampilot06:
