For the love of English 3 speeds...
Rain or snow, 65 years old on a roadster. Love it!
A beautiful place.
A beautiful place.
The pedals were bad but there was a run on them about 25 years ago when a lot of guys were rebuilding their Raleigh Choppers. I saw NOS pars go for up to $100 when ebay was the wild west for auctions. I had a cool set in white on this Eatons Glider (Colt).
They were still crap but at least they looked good.
I've never seen them in white
On the road
Bikes: Old Schwinns and old Raleighs
Liked 1,129 Times
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1969 Raleigh Superbe: 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold), 1966 Schwinn Deluxe Racer (sold)
Liked 1,019 Times
Likes For Unca_Sam:
www.theheadbadge.com
Liked 4,537 Times
I had a hell of a time deciding whether this belonged in the Wacky World of eBay thread or here, but I'd say there's enough redeeming qualities about this thing for it to go here: https://www.ebay.com/itm/274760670508
What happens when you smash a 1975/6 Lemon Yellow Sports into a Bronze Green 1973+ Raleigh Superbe? 1970's interior decor on a bike.
-Kurt
-Kurt
Likes For cudak888:
Liked 333 Times
V
I've been working on the Resilion brakes on my recently acquired '52 Claud Butler Ladyback tandem. I began by removing the rear brakes and soaking them in Evaporust which worked nicely. Then, after much thought, I've decided to reproduce the complete housing/ cable assemblies, rather than cut the existing assembly apart to harvest the hardware and merely take the easy way out and just replace cables and housings. I'm a machinist so. It's a nice lunchtime project. I made drawings of all components and started with the hardest part, the sleeve where both cable ends feed out from the main cable coming from the brake levers. I need front and back. First I made a crimp tool to size the brass as it goes from round to oval where both ferrules fit inside. Then, using the original part, sized the tube from the round dimension, and drilled it so the wall thickness was matched.
Turns out the tube is actually stepped bigger, so the first run of parts didn't size up, but proved the aluminum crimp tool will work. After developing the correct diameter of blank on the second attempt, I used a harder hex brass I had for years...
Here's the original crimped fitting next to the correct size blank, but failed crimp, and the underdeveloped size, but good crimp. You can see the part on the left collapsed completely. On the second attempt, i supported the inside with keystock to prevent failure. It still failed. The nice crimps were on undersize formable brass.
Heres a shot of how much the wall collapsed with and without internal support. I made bigger stepped parts from harder brass, which I had, but the crimp failed due to material hardness. I've ordered the soft formable brass from Mcmaster-Carr and will be attempting more trickery soon.
From left to right; Revised size of barrel (2) This brass was easy to machine from hex stock i had previously. 1st attempt to crimp, but finished size was too small. Crimp tool worked okay. 2nd attempt with max dia from stock using formable brass. Aluminum crimp tool can be seen on the right.
Bikes: 50 and 51 Raleigh Superbe Sports Tourist, 53 Hercules King Coronation Celebration, 55? Automoto roadster, 68 Raleigh Sports, 76 Zebrakenko Wind, 80 Raleigh Tourist, 82 Trek 720, 87 MCycle custom, 90 Specialized Hardrock
Liked 13 Times
-Kurt
-Kurt
Likes For Rherdegen:
I think it would be fun to have one of these where each part was a different factory original color.
Likes For BFisher:
Liked 4,537 Times
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Liked 445 Times
A couple of recent offerings here in Toronto
An interesting BSA Balmoral at a reasonable $200.00 (with the disliked pedals)
and...
A ladies DL-1 at a not so reasonable $900.00!!
and...
Likes For gster:
Bikes are okay, I guess.
Bikes: Waterford Paramount Touring, Raleigh Sports 3-speeds in M23 & L23, Schwinn Cimarron oddball build, Marin Palisades Trail dropbar conversion, Nishiki Cresta GT
Liked 2,489 Times
Liked 2,489 Times
Bike Doctor
Bikes: Norco Cape Cod tandem, KHS Tandemania Cross, 1952 Claud Butler ladyback tandem, 1971 & '73 Raleigh Suberbes, 1985 Gazelle Sport Solide, 1985 Rossi professional
Liked 52 Times
All the hardware is brass and plated brass on this girl, except the small threaded hex sleeves, which I'm making from brass. I'll not bother to plate anything, but might "age it" if it looks too shiny.
Liked 445 Times
A couple more Toronto listings
A decent DL-1 @ $300
A Raleigh built Glider @ $290.00
Likes For gster:
Liked 445 Times
An English bike (a Bitsa) in a Canadian garden with a French gargoyle...
Liked 2,489 Times
Likes For thumpism:
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Liked 628 Times
-Kurt
-Kurt
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
Liked 4,537 Times
Jokes aside, that Favorit pulls it off a lot better.
Were those green Bluemels from one of those oddball early 1960's Superbes that came with these?
-Kurt
Liked 445 Times
What a Tool!
I've had this pedal wrench for years. It's quite chewed up
but still works
I just noticed today that it's made by CYCLO.
but still works
Liked 2,489 Times
Likes For thumpism:
On the road
Liked 1,129 Times
If you really have to have a Dutch type opafiets, that's not a bad buy. They're a little bit different because of the parts they use and those drum brakes. Some people really like them, and some prefer the English variation, but the build quality usually is pretty good.
Likes For SirMike1983:
Liked 4,537 Times
Thanks to [MENTION=471395]dmark[/MENTION] - who also took the pics - this Humber should be on its way to me soon. I'm taking a guess that it's a '48 at the latest due to the shifter - haven't seen the rear hub date or the Dynohub (I think it's an 8 volt GH8) - and I snapped it up just because how utterly perfect it is. A couple of flaws, yes, but examples this nice don't come around often. Only downside are galvanized spokes that don't look too good. The rims don't match the perfection of the frame either. Might have to rebuild those at some point.
No bifurcated fork on this (I suspect the factory ran out and went with standard forks), and even though it's a rod brake model, it rolls on 26x1-3/8" wheels, as some pre-1950s models were.I'm guessing it's rough equivalent to what's shown in the 1936 catalog as the Dawn Tourist X - the only rod-brake chaincase model with EA3 wheels: https://www.velo-pages.com/main.php?...geViewsIndex=1 EDIT: Cob X Tourist, basically the Humber equivalent to the Dawn Tourist X: https://threespeedhub.com/wp-content/...og-1936-UK.pdf
FYI, [MENTION=471395]dmark[/MENTION] is looking for a rear wheel or 40 hole 1950's Raleigh Westrick rim for a Rudge that has a Westwood on it at the moment.
-Kurt
-Kurt
Liked 679 Times
Look what just came into the bike Exchange
Ho hum, just another Ladies Raleigh 3 speed.
But look again . This is a 24" Raleigh Space Rider, with a Sturmey Archer 3 speed and coaster brake.
I already stripped it down and will start cleaning and polishing everything tomorrow.
It looks like it was hardly ridden and probably kept indoors . Good paint, minimal rust. Still weighs a bloody ton - 37 lbs. to be exact.
Some little girl is going to get a very special bike when it is done.
Likes For capnjonny:
Liked 445 Times
couple of continuing projects
Both of these bikes are typical "Bitsa" builds
Bits from here
Bits from there
A 1961 Superbe that was dropped off at my house a while back/
It had been painted (poorly) and while stripping it I decided to
leave the frame as is.
It's got a 61 hub and an EA1 front rim/tire .
I'm not sure why, but I guess that's what I had available at the time.
A stamped eye on the heron chain ring indicates 1961 or earlier.
Rides and shifts well.
I'm taking it out today for a 30 mile ride.
This one's a bit of a mess.
It's a Raleigh 10 speed frame (24")
running another 61 hub with a Gyes leather saddle.
The wheels are out of proportion and I'm thinking of finding another
23" Frame and swapping parts over and giving/trading this frame to
a friend.
At one point it was set up as a single speed coaster brake but that back wheel
went to a more deserving project for a neighbour.
Bits from here
Bits from there
a friend.
