Addiction 2022.3
#2426
Should Be More Popular
Quoted: 22643 Post(s)
Liked 8,957 Times
I use extractors as a last resort. If you do, drilling the right size hole and centering the hole is key to a stuck bolt. Also apply a little heat, especially if there is a threadlocker product on the threads. If a bolt is really stuck, like cross threaded or rusted, an extractor will probably just break.
Are the crank bolts the Shimano style with 2 pinch bolts? Those are probably hardened bolts. Are they stripped? You might be able to pound a bigger Allen wrench in there, maybe an SAE size.
Cleat screws might need a good soaking with a penetrating oil. Are they Allen head or slotted? An impact driver might help if you can borrow one.
12 Piece Easy Out Small to Large Screw Extractor Kit Set Easy Out Screw Remover Set (Case Included): Other Products: Amazon.com: Tools & Home Improvement
#2427
Quoted: 9656 Post(s)
Liked 6,366 Times
The shimano ones are the 2 pinch bolts. It almost makes me wonder if I got a counterfeit set because the metal in these bolts is so soft, they got stripped by my park tools torque wrench. I have some bolts from older cranks that are not stripped so I need to take these ones out and put new ones in. The cleat bolts are cheap-o Look stock bolts/screws that always seem to strip on me. Possibly user error, as my mechanic is a certifiable idiot in his field.
Likes For Mojo31:
#2428
Bikes: Shmikes
Quoted: 10184 Post(s)
Liked 5,886 Times
I think it’s a series of finger or earlobe sticks, while doing some sort of ascending protocol on the bike. They can estimate it from respiratory gas analysis, the way they do VO2, but it’s not as accurate for this. Lactate also tells you a lot about your general metabolic health.
Likes For MoAlpha:
#2429
Quoted: 8321 Post(s)
Liked 9,129 Times
The Look cleat screws I get are 4 mm Allen and they are cheap/cheesy. If you can't get them to move you could try a sharp chisel and tap around the outside of the screw head in the direction you want them to go. Be patient.
Time to ride.
#2430
Bikes: Shmikes
Liked 5,886 Times
#2431
Mostly Harmless
Bikes: Have two wheels
Quoted: 13732 Post(s)
Liked 4,542 Times
Just getcha the bike: Porsche eBikes: Sport & Cross | PORSCHE SHOP
#2432
Mostly Harmless
Liked 4,542 Times
Shimano Crank Arm Clamp Bolt Excel Sports | Shop Online From Boulder Colorado
Universal Cycles -- Shimano Hollowtech II Crank Fixing Bolt/Pinch Bolt
Likes For rjones28:
#2433
Liked 6,366 Times
Likes For Mojo31:
#2434
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3234 Post(s)
Liked 1,866 Times
I have a couple bolts that are a challenge to remove so I think I need a bolt extractor. These include the bolts to my cleats and the 4mm crankarm fixing bolts.
I don't see that Park Tools makes a bolt extractor. Any suggestions for a budget bolt extractor for bicycle-sized bolts?? Most of the ones on ScamBay seem to be designed for autos and are too big.
#2435
Liked 1,866 Times
#2436
Liked 1,866 Times
Down tube shifters and platform pedals and you're good to go.
Oh, and iso square taper bb.
This is one of the many reasons I stopped where I did. Personal finances is the biggest reason though. And simple incomprehension at paying $2000 for a bike, 25 years ago.
#2437
Liked 8,957 Times
Nope, too recessed. I have spares as above so I don't mind if I destroy the stripped ones. I am disappointed in Shimano that they stripped so easily. I was using a good tool and the right torque per spec.
#2438
Liked 8,957 Times
#2439
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
#2440
Liked 1,866 Times
Eddy Merkx and the like did just fine with the old tech. Maybe you're too soft. Just a thought.
If LAJ is lurking, this should bring him out.
Likes For seedsbelize2:
#2441
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
And watching small tube TVs.
And using dial-up.
And so on.
Yes I know that was tongue-in-cheek.
#2442
Klaatu..Verata..Necktie?
Quoted: 10475 Post(s)
Liked 11,989 Times
I have several of his CDs, myself.
Likes For genejockey:
#2443
Habitual User
Quoted: 5022 Post(s)
Liked 8,212 Times
I was expecting to have to use a chain tensioner, but it happened to work out very nicely. With a new chain, it is a little tight, but it stretched out pretty quickly and is perfect now.
Likes For Eric F:
#2444
Silver Comet Fred
Bikes: 1
Quoted: 8865 Post(s)
Liked 3,016 Times
I have 9 of his CD's counting the 9/11 memorial release. All but one from 1980 ending with Night divides the day in 2002. I was inspired to listen to them today at work.
Likes For DougRNS:
#2445
Silver Comet Fred
Bikes: 1
Liked 3,016 Times
#2446
Silver Comet Fred
Bikes: 1
Liked 3,016 Times
#2447
Liked 6,366 Times
#2448
Silver Comet Fred
Bikes: 1
Liked 3,016 Times
I honestly don't recall if that cable is a PTFE coated cable or not, but I have used those fancier cables in the past and I can say for my usage, it does not extend cable life.
I actually do think this is a PTFE coated cable, it's the one that came with the R8000 groupset.
#2449
Silver Comet Fred
Bikes: 1
Liked 3,016 Times
#2450
Mostly Harmless
Liked 4,542 Times
We were on phone line DSL until a couple of years ago.
We watch video content on YouTube with a 13" iPad. Does that count?
