For the love of English 3 speeds...
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
1989Pre Thank you! Unfortunately, the saddle’s splitting at the front rivets, so I’ll have to replace it— I’m hoping to find a b66, but no luck so far on CL/eBay. The tires are Kendras, max psi 55, and the shifting’s super smooth! Its a really nice ride, I’m excited to get out on it 😊
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
Likes For 1989Pre:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
Likes For 52telecaster:
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 857 Times
Thanks. It's actually a 5-speed Sprite with the S5 hub. It's the cleanest early Sprite I've come across. I put it up for sale in the for-sale forum here if anyone is interested.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Likes For SirMike1983:
On the road
Quoted: 373 Post(s)
Liked 857 Times
Tires are Michelin World Tour white walls. I run them 60 - 65 PSI range.
Standard Member
Liked 940 Times
Thanks. It's a 5-speed Sprite with the dual paddle type shift levers on the top tube. But the headlight mount is the same as a Sports. You need a two-piece clamp that is specific to the Raleigh-style lamp bracket. If you have that clamp, you can use pretty much any basic headlight. That headlight is a retro LED that uses AAA batteries. The original B72 came with the bike was a little dry for doing much rider use any more.
Bikes: 30's Speedwell Club Racer, 40's Speedwell 'Z' racer, 50's Unknown Aussie with nice lugs, 50's Speedwell Roadster, 50's Repco Roadster, '63 Raleigh DL-1, 70's Raleigh Sprite, Puch Promenade with Nexus 8
Quoted: 149 Post(s)
Liked 30 Times
I just picked up a Sprite last week! 70's metallic sky blue, with a solid black band on the seat tube. Can't post a pic coz the forum is not playing with my computer like it normally would. I've swapped out the steel rimmed wheels for alloys for better braking on the hills around here.
With the self adjusting brakes - how do you get them to loosen off? If one might have accidentally pumped the brakes while the wheel was off ... and they kinda over-adjusted themselves
Likes For arty dave:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Tall-framed Dutch IGH goodness for $150 in OH.
https://www.facebook.com/marketplace...31761314691518
Liked 2,446 Times
Deleted.
Standard Member
Liked 940 Times
Liked 2,446 Times
Likes For thumpism:
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
Likes For cudak888:
Liked 2,446 Times
Someone buy this! Seller says single speed but that rear hub looks Sturmish. $25 in CT.
https://www.facebook.com/marketplace...17413526203652
Likes For thumpism:
Liked 2,446 Times
Likes For thumpism:
CORSA CLASSIC
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 360 Post(s)
Liked 470 Times
This is the '57 Triumph though; I was able to get a spare for the Superbe (I think it was from nlerner or clubman but don't remember offhand). Now you have me second-guessing whether I should be using these, given that the bike might be ridden now that it's refurbished.
I have a feeling your early Dynohubs might be suffering from the same issue as my '47 was. I wrote up a bit about this; let me know if this helps:
https://www.bikeforums.net/21227463-post43.html
-Kurt
-Kurt
Unrelated question - I want to run a lighter square taper crank on my '64 Triumph, and ideally run a modern spindle with the original Raleigh cups as others have done.
Do you know where I could find the right spindle? Or rather, which one to get? I've tried a few with 5S, 5L, but they are too long for a single ring crank to match chainline on a SA hub.
Count Orlok Member
1961 Raleigh Colt for sale:
https://www.facebook.com/marketplace...e-bc5bf8773788
Even has tools with it.
Liked 4,396 Times
-Kurt
Likes For cudak888:
Quoted: 360 Post(s)
Liked 470 Times
Hmm. Try rebuilding the hub per the manual, just for the heck of it. It might bring something forth. Couldn't really tell you at this point without seeing it.
The "5" spindle is simply a spindle for a 70mm Italian BB. If you can find an Italian BB spindle (provided they're not for something like Campagnolo thin cups), you should be in business. A Shimano 105/600 Italian BB spindle ought to be a good place to start.
-Kurt
-Kurt
Likes For Ged117:
23” frame Men’s Sport, somewhere between 1969-1972 from the decals, looks like with the original Brooks saddle bag. $250
https://boston.craigslist.org/sob/bi...612783414.html
(Slightly tempted to buy it just for the bag then try to flip the bike 😂 )
Likes For Elddir_Mot:
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
The Lake Pepin 3 speed tour is coming up- May 20th
This year I'm thinking of riding a Rudge Pathfinder with which I've been tinkering.
Likes For robalong:
Standard Member
Liked 940 Times
When I bought my Rudge almost 4 years ago, it had some (1970's?) Regency (Japan) tires on it that served me well. The rear was fading away, though, and the rubber around the beads had crystalized, breaking off into flakes and chunks whenever I changed a tube. Those tires had a 7mm white stripe. The time had come for my Rudge to wear some new rubber, so it received N.O.S. Michelin Sport white-walls, made in Stoke-on-Trent, England. There is no p.s.i. recommendation on these tires, so I have them pumped-up to the same spec as my earlier tires, which is 50 p.s.i. I had to bring my rear axle a little forward in the dropout, because these tires were contacting inside the fender (they had appeared to be about the same profile as the Regencies). Not only are these Made in England, but there was even a small Halford's tag on the cellophane, which looked hand-wrapped in spirals around each tire. These were in New York state, and I don't know the story as to how they got there. The instructions specify the use of powdered chalk on the tube and rim-strip upon installation. As you may have noticed, the bike is minus a chain. Mine was stretched, so I have a Renold Elite on its way from Germany.
Likes For robalong:
