For the love of English 3 speeds...
#1976
Quoted: 17 Post(s)
Liked 42 Times
- I looked and found the option for white steel fenders on the Golden Arrow called out on the catalog page that Neal originally posted (below).
My steel fenders are not white however - the finish on them and the faded gold pin striping is such a good match for the frame that I thought they were original, but nowhere have I seen a catalog reference (or a picture of another surviving example) with black fenders.
- Auchen
- Auchen
#1977
No longer here
LMBO!!! BeLIEVE me,this I know,I've had (and still have at least 5) old bike projects
#1978
Bikes: 1972 Raleigh Sports
Raleigh Light Bracket?
I had a question about installing a front headlight on my Raleigh Sports. My bike didn't come with the standard Raleigh light bracket.
Do these vintage brackets work with modern headlights like the Soma Bullet?
#1979
Quoted: 17 Post(s)
Liked 42 Times
What do you do for brakes on the old Raleigh 3-speeds?
I got the rust off my side-pull Raleigh steel calipers, reassembled them, and was re-cabling the bike today: I overcame the first hurdle, and got the knarp and cable to stay centered on the guide loop on the caliper arm.
Centering the caliper arms was another story entirely: The rear especially, was impossible, because every time I so much as snugged the nut at the brake bridge, the caliper arms bound up hard on each other.
- Auchen
- Auchen
#1980
Quoted: 17 Post(s)
Liked 42 Times
The Soma lamp is purported to mount on the fork or bars as shown.
- Auchen
- Auchen
#1981
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
And the marshals wouldn't pass it on the field. And if they did, I'm sure the heralds would have some kind of kitten-snit problem.
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
#1982
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
#1983
Quoted: 3811 Post(s)
Liked 6,715 Times
#1984
one life on two wheels
Liked 18 Times
1973 Raleigh Sports
1973/74 Raleigh Sports by (cobrabyte), on Flickr
sort of a frankenbike really, but all parts are from '72,'73,'74 Sports models, so it's mostly correct.
more here: https://www.flickr.com/photos/cobraby...th/5804826135/
#1985
Quoted: 7351 Post(s)
Liked 2,477 Times
cazoo, welcome.
#1987
What type of threading did Raleigh use for the handlebar, stem and seatpost bolts on Sports, etc.? The brown Raleigh Twenty was missing its seatpost clamp bolt and handle. I found the proper handle but the bolt I got with it is too short so I need to find a longer bolt. When I obtained the bolt and handle, I did not know that Raleigh had used a couple of different style clamps. The blue bike takes the shorter bolt.
#1988
Bikes: Many
Quoted: 5 Post(s)
Liked 10 Times
#1990
Liked 2,477 Times
Looks like a banyan tree. I've seen a couple in Florida. They're amazing.
#1991
Count Orlok Member
Likes For gna:
#1992
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
The front of the brake should have a nut and a locknut, which have to be tightened against each other at exactly the right level of tightness, kinda like cones on a hub or something. Typically you have to tighten them both down, then loosen the locknut so it tightens up against the acorn nut, and then lock the two against each other. Once you have that adjustment right, loosen the nut on the back, and center the brake as well as you can, and tighten it up enough so it's not going anywhere. Now test the brake. If it's gone off center, now's the time to take Neal's advice. Put the punch on the very top of the spring, so you're not hammering on the spring but really on the side of the piece that holds the spring. Now, if you hit the punch with a hammer, you'll be turning the whole brake bolt a little bit. Once you have it right, tighten up that nut on the back.
Likes For rhm:
#1993
Quoted: 17 Post(s)
Liked 42 Times
- Here's a (pre-clean-up) picture: It does not have the usual hex nut arrangement common on most side pull calipers as described - rather just a large slot head screw - but even that is not the issue. The difficulty comes in because the spring is not sufficiently robust to overcome the friction between the caliper arms at the single pivot, despite that they are now rust free and lubed.
(I'm thinking of stopping it at the hardware store tomorrow, to see if they have any thin Teflon washers to insert between the pivots.)
- Auchen
- Auchen
#1995
Bicycle Repair Man !!!
Thanks RHM, but I think I have a slightly different situation...
#1996
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
#1997
Liked 6,715 Times
Neal
#1998
Liked 18 Times
@ ftwelder: thanks!
@ noglider: very good guess , but it is actually a moreton bay fig tree, these trees have huge roots that grow in a wavy formation above the ground. A banyon tree has roots that grow down from the branches until they reach the ground and dig in...more like the pic below: (and yes, they are amazing, they can grow to be HUGE, enough to where you can walk through one tree and it feels like a forest.)
Banyan Tree in Hawaii by BillyCrafton, on Flickr
@ cazoo: thanks! but it is actually a modern led flashlight I picked up at the local flea market, but I do have a small collection of vintage flashlights...this one is just brighter
@ gna: cool! did not know that
