Totally Tubular
#2976
Quoted: 1962 Post(s)
Liked 2,052 Times
I believe Tufo tires are designed with sealant in mind.
Likes For Classtime:
#2977
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 167 Post(s)
Liked 150 Times
Pinhole, not a puncture?
The latter's fairly easy to diagnose but will take time to disassemble tire & tube to first find then fix defect best with a proper patch then inspection of the casing for the agent of puncture if it's still there.
Pinhole as you describe is tougher; it may best benefit from sealant injected into the valve (if you can manage that) due to the difficulty of locating it with any confidence.
Remember tubulars have been around for a long time, well before modern sealants became available. Their use in tubulars I think is a practical one in cases such as yours.
My limited experience has me close to injecting sealant (just received an 8 oz bottle from WTB last week) into the decade+ old Vittoria and Continental tires I bought maybe sometime back around 2007 when I was last riding my road bike.
I have a new pair of 27mm Challenge Stradas as well now, likely will put sealant in those (removable Presta valve stems help!) before gluing them to the original MAVIC rims, my (so far) only pair of wheels for that bike.
(And, reading your personal data I never knew Home Depot sold tubulars?)
Likes For spclark:
#2978
Quoted: 1867 Post(s)
Liked 666 Times
Ok, so it's clear the consensus is that with tape or glue, it's a good idea to solvent wipe the rim bed and the rim strip area, at least, before taping.
What can I substitute for mineral spirits if I don't have that actual material, to wipe off the gluing surfaces of a tubular tire and its rim?
#2979
Quoted: 167 Post(s)
Liked 150 Times
Depends...
... a lot on where you live, what kind of solvents are available to you and what those various products are called.
In the US you can find odorless mineral spirits, paint thinner, brush cleaner, and pure turpentine. Those all have similar uses while somewhat variable chemical components.
Then there's lacquer thinner, acetone, Methyl Ethyl Ketone, Xylene, all much more powerful solvents than those mentioned earlier.
They're all flammable and shouldn't be in contact with your skin. The latter bunch are more aggressive, vapors more harmful in concentration, more likely to ignite when a source of ignition is close by (light switch, hot light bulb, any open flame) so should be used with proper precautions and ventilation, proper gloves at minimum for PPE.
Those last will make short work of cleaning away old tire cement, the others will take more work.
For cleaning new, unused rims you can use denatured alcohol, essentially ethanol with a dash of methanol most often added (so as to avoid taxes paid on spirits intended for drinking) but in some countries it's no longer sold to consumers.
A common substitute may be marine stove fuel or less commonly what may be called 'white spirit' or white gas, or even naptha.
#2980
Old fart
Quoted: 3610 Post(s)
Liked 3,434 Times
Likes For JohnDThompson:
#2981
Bikes: Two Peter Mooney customs, a 1980 Trek 510 townie, a Marin Stelvio set up for TTs.
Quoted: 230 Post(s)
Liked 300 Times
Isn't that going to remove some material from the bed of the rim over time? Outside of an initial roughing-up and braking, I'd like to remove as little metal from the rim as possible.
#2982
Quoted: 167 Post(s)
Liked 150 Times
There's a risk of bits of wire being thrown off the spinning arbor so if you choose this method please wear eye protection (maybe face too?) and long-sleeve shirt with the cuffs securely buttoned. Also best to carefully inspect the cleaned rim, ensure there's no bits of wire hiding inside that could find their way between rim and newly glued tire later on down the road.
#2983
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 299 Post(s)
Liked 685 Times
Also works great for cleaning brake tracks on rims to reduce squeal.
Coleman Fuel for outdoor stoves/heaters
£10/litre
https://www.amazon.co.uk/Coleman-Liq...ps%2C93&sr=8-1
"Coleman Fuel Is A Mix Of Petroleum Naphtha With A Bit Of Rust Inhibitor"
#2984
Quoted: 1616 Post(s)
Liked 2,222 Times
Use a brass wire wheel.
#2985
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 422 Post(s)
Liked 969 Times
Or a pocket-knife blade, over a couple hours, the old-school way - don't stab yourself though!
#2986
Liked 666 Times
Well, my anodized Mavic GP-4 rims don't have the pink post-glue build-up, because the Jantex tape did not leave any, and I had cleaned the rim bed with the wire brush before installing the Tufo tape or the Jantex tape. I only need a surface degreasing, now. My main concern with the process is to prevent, as a previous writer suggested, that solvents don't attach the tire materials, glue and such, which holds the carcass together under inflation/riding pressures. I worry about that with glue not designed for cycling, (such as Contac) and degreasers.
BTW, my Jantex attachment of the Gommitalia tires has been perfectly reliable.
I really can't see any product information on solvents which does not suggest that except perhaps for smell, a half-dozen different products with different technical names are really not different at all. There has been a suggestion that some solvents may damage the carcass of a tubular tire, but no anecdotes or corroboration that the problem has been real or hazardous. Anybody think this is more that a mildly suspected potential problem?
#2987
Quoted: 167 Post(s)
Liked 150 Times
But again I emphasize that any solvent used to clean rims ought to have evaporated 100% well before new tire glue or tape is applied to the cleaned surfaces.
If some significant amount of time (days, or longer) has elapsed between old glue removal and application of new it's a good idea to do a pre-app wipe down with 'denatured' (mostly ethanol) or high-concentration isopropyl alcohol ('rubbing' alcohol will work but the water in it needs more time to evaporate than the alcohol component) on a clean cotton or microfiber (as long as you don't mind using such products generally) cloth. This serves to remove any dust or other airborne contaminants that may have settled out that might affect getting a solid bond between fresh glue or tape and the rim. One can of course use fresh glue-removal solvent if that's all you have but the alcohols I mentioned are usually less costly, less flammable and don't smell as bad... but they won't do much to remove old glue residue either.
#2988
Wheelman
Quoted: 299 Post(s)
Liked 685 Times
Hiya Folks,
I've been using Vittoria Rubino Pro G+ 28mm for the last 2k miles and like them a lot (for £35).
I'm working on a new project and had these earmarked but it turns out they've been "discontinued 14th August 2023":
https://www.merlincycles.com/vittori...0c-140868.html
A couple of shops seem to have one left for £45, or there's some for around £60.
Checked the Vittoria site and that shows
Can anybody suggest a 28mm tubular they like in the £35-£45ish range that's actually 28mm ?
Rally: 21/23/25
Rubino: 23/25/28
Corsa: 23/25/28/30
So if Rubino is really discontinued I'm out of luck for 28mm.Can anybody suggest a 28mm tubular they like in the £35-£45ish range that's actually 28mm ?
#2989
Bikes: many
Quoted: 1455 Post(s)
Liked 1,406 Times
Aardwolf I bought some Vittoria Corsa Control Graphene 2.0 tubulars in 28mm and 30mm widths when they were (are?) on sale recently. They were $95/pair, so well under your price threshold. The 28s went on my Serotta and seem to run true to size. You might get lucky and find another pair or two floating around at that price.
#2990
Unglued spare tubular?
I am really new to tubular tires, and have my first bike running sew-ups. I am curious…I’m an emergency only situation, is it safe to carry an unglued spare tubular tire in the event I flat, with the knowledge to take it slow and steady back home?
I presume that at high enough pressure, the tire will stay on the rim until I get back home, but wanted advise from those who have more experience with sew-ups.
I have some Gatorskin tubulars that I intend to ultimately put on a training wheel set in going to build up, but for now needed a spare in a pinch.
Likes For Het Volk:
#2991
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4346 Post(s)
Liked 3,008 Times
1. For safest results, your spare should have an old coat of glue on the base tape - either a used tire or one that's been prepped. You'll get some extra adhesion from this than from bare fabric. So when you take off the flat tire you'll have a rim that still has some sticky glue on it, and a spare tire that's got some still sticky glue on it, and it'll be even better when they heat up together during your ride home.
2. Press the mounted spare tire up as high as you dare - the tire mostly stays on because of pressure, and the glue keeps it from creeping.
3. Take corners slowly, and minimize your braking with the spare tire wheel. Stop frequently to check on it.
#2992
Liked 2,052 Times
Get that Sprinter Gatorskin stretching as soon as you can. They are a bear to mount -- not easy peasy like your Corsas. But once you get it on your rim It will stay put to get you home. (Cool Bike.)
#2993
Wheelman
Quoted: 299 Post(s)
Liked 685 Times
But that's almost cheap enough, I'll put them on the list
Rats, turns out that's not the tubular.
Lowest price I've seen is £70 on Amazon.
#2994
Garage tetris expert
Bikes: A few. Ok, a lot
Quoted: 390 Post(s)
Liked 699 Times
Cheers, had a look and the best I'm seeing in the UK is around £50 each https://www.wiggle.com/p/vittoria-co...=700c+%7C+28mm
700x30 tubular version for $48 each. Not sure what postage rates to UK looks like.
Likes For panzerwagon:
#2995
Wheelman
Quoted: 299 Post(s)
Liked 685 Times
https://www.excelsports.com/vittoria...ular-road-tire
they also list 2x 700 x 28 for $89 https://www.excelsports.com/vittoria...ack?sku=743028
Very good prices.
International orders are a bit tricky though https://www.excelsports.com/page/int...ping-statement
and I've got no idea what the shipping is.
I might have found some Rubinos for £51 https://www.tradeinn.com/bikeinn/en/...re/137108639/p
and Corsa Control for £61 https://www.tradeinn.com/bikeinn/en/...re/137108631/p
#2996
Quoted: 2356 Post(s)
Liked 2,874 Times
#2997
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 167 Post(s)
Liked 92 Times
#2998
Wheelman
Quoted: 299 Post(s)
Liked 685 Times
Cheers,
Very good prices.
Very good prices.
"That’s is correct, unfortunately we are unable to ship to the UK." - reply from Excel Sports.
Their country selector for account/delivery address didn't include UK so I emailed them and asked.
Seems to include almost everywhere else though.
#2999
Bikes: many
Liked 1,406 Times
What would be involved in a relay? I'd be happy to shuttle it along. If you're not in a huge hurry, a local bike friend here in Chicago makes the trek back to Surrey from time to time. He's willing to carry it in his luggage. Actually, his wife is leaving Saturday for Surrey and will be there all next week. PM me your email address and I'll put you in touch with Andrew.
#3000
Wheelman
Quoted: 299 Post(s)
Liked 685 Times
I need a more long term solution and I think I prefer the Rubino for the butyl tubes (they stay inflated for weeks), although I haven't tried latex yet.
Update Just ordered Rubino x2 from BikeInn for £50.99 each + £7.99 postage, now I just wait to see if they actually have them in stock ....
Update2 2023/08/26 Tyres arrived and they're correct ones.
