Addiction LXXVIII
#1726
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
I am done riding until the plague passes. I read the Merida paper yesterday afternoon and decided it was best. Nurses are being attacked, in public places, for being on the front line with the capacity 'to infect us all'. ¡Sad!
I truly hope it doesn't devolve a lot further. There was another story about a family in a town nearby being isolated and accused of being infected. The husband lost his job over it. Very superstitious.
#1727
Destroyer of Worlds
I've been doing a lot of "virtual" riding. It's fun, and it relaxes me...to a degree. And, in true video game fashion, it allows me to unlock and use "neat" things, which always makes me feel good.
#1728
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,873 Times
#1729
Bikes: Shmikes
Liked 5,873 Times
For example: https://quoteinvestigator.com/2014/06/19/new-path/
#1730
Quoted: 20810 Post(s)
Liked 9,456 Times
#1731
Liked 9,456 Times
#1732
Destroyer of Worlds
Enjoy. I don’t know who U.S. Cavalry is, but that path quote is attributed variably to R. W. Emerson and someone named Muriel Strode.
Likes For N00b_Cyclist:
#1733
Quoted: 8287 Post(s)
Liked 9,062 Times
Check obvious stuff like gas cap, big leaks. Find the vent control solenoid. It should have battery voltage on the pink wire with key on engine off . It's probably near the front of the tank. Sometimes the wire breaks inside the insulation. If you don't have scan tool with outputs you cold apply power and ground to the vent solenoid and it should click. If that checks out test the purge solenoid. It's on the engine near the throttle body. It should have power on the pink wire too. It should pass vacuum when it has power and ground. If you have data on your scan tool look at the fuel tank pressure sensor first. It should read 0 vacuum key on. If it reads something other than atmospheric pressure with the engine off, it needs to be replaced. The only exception is if you drive a while and stop and open the gas cap and there's a lot of vacuum. This would still see the FTP sensor go to 0 once the vacuum is relieved.
If you drive a lot of dirt roads the canister could be restricted. Let me know if you have any questions about evap stuff.
I didn't see the part about the evap code being consistent last night.
#1734
Quoted: 10238 Post(s)
Liked 5,187 Times
In other news, we have to make final decision for daughter 2 college by the end of the month. My wife and I have accepted that although it’s pricey, we are willing to accept NYU. USC is still possible but distance makes us less comfortable with that option, even though it’s arguably the best school for film and the best school for “student experience.”
Just my two cents.
Edit: Happy Belated Birthday!
#1735
Super Modest
Quoted: 10963 Post(s)
Liked 4,621 Times
#1736
Super Modest
Liked 4,621 Times
Bike Content: Single bike out of the van, tandem assault vehicle going in.
Should be 50s with 15 mph wind in an hour or so. I was going to stay in but wife said load the tandem and I don't argue with my wife. Nope. Never.
Keep the chain tight!
Likes For Trsnrtr:
#1737
Liked 9,062 Times
We had a random (1 to 10 minutes)low rail pressure and fuel pump low voltage codes this week, fuel pump 10 amp fuse with cracked filament. Continuity test of fuse ok, initial start 25.6 VDC, then dropped to@11 VDC, after random amount of time . Replace $.05 fuse, clear code problem gone, 6 hours of diagnostics , oh what fun.
#1738
Liked 9,062 Times
#1739
VFL For Life
Bikes: Velo Volmobile
Quoted: 28632 Post(s)
Liked 1,858 Times
Anyway, I never thought this was a surgery problem. My neck has started to creak and make noises, though. Not sure if that's aging or what.
#1740
Bikes: Shmikes
Liked 5,873 Times
Hard to know for sure, but I sense some outdoor mask shaming here.
#1741
Mostly Harmless
Bikes: Have two wheels
Quoted: 13718 Post(s)
Liked 4,532 Times
#1742
Liked 9,062 Times
I want to ride, too. Nice day, first dry day in a while. Now to decide where/what to ride.
#1743
Should Be More Popular
Quoted: 22603 Post(s)
Liked 8,929 Times
#FirstWorldProblemsAreStillAnnoying
#1744
VFL For Life
Liked 1,858 Times
#1745
Liked 8,929 Times
#1746
VFL For Life
Liked 1,858 Times
#1748
Super Modest
Liked 4,621 Times
#1749
Super Modest
Liked 4,621 Times
Likes For Trsnrtr:
#1750
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12782 Post(s)
Liked 7,696 Times
