Press Fit Bottom Bracket
#51
Quoted: 4416 Post(s)
Liked 4,872 Times
I think this is what is driving the move back to threaded BBs. They have become a major selling point with PF gaining such a bad reputation. Be interesting to see if the industry remains divided or if the other big brands will return to threaded BBs simply because of customer demand.
#52
Quoted: 696 Post(s)
Liked 910 Times
I dislike press fit BB’s but I have a Trek with a press fit with over 6000 bad weather and winter miles and its as quiet and smooth as day 1.
#53
My last road bike was a Giant. After a year of ownership the BB started creaking. Replaced it with a new one and less than a year later started creaking again.
Same situation with my Cannondale Mountain Bike I had and My Specialized Fat Bike that I had.
It's absolutely true. Threading and facing frames is more costly and so is the labor to install the threaded BB which slows down the production line.
It is a customer preference!! Customers prefer to have a quiet bike and not one that creaks with every rotation of the crank!!! That and threaded cups can be serviced with simple wrenches and threaded cups allow component makers to have complete control over every moving part of the crankset from pedal to pedal.
I have seen hambini's videos and I thought that buying giant would be better off since they control the manufacturing. Not sure if I just got unlucky. However, this is an admittance of failure to build frames according to specs from big brands. As I said, PF has been around for more than a decade. And Specialized started using threaded BB only on lower end frames. S WORKS still gets PF BB. This shows that as a technology it is superior and my experience with my 11 yo Defy proves it can be quiet and reliable as well.
#54
Quoted: 850 Post(s)
Liked 344 Times
b) no, S-Works bikes using pressfit (or threaded) BBs indicates diddly squat about the superiority of the technology. As evidenced by point a.
Engineering truths are not defined by marketing. Or even what consumer demand makes economically viable. It simply is what it is. I say this as someone who also believes in the theory of pressfit but I'm also capable of admitting that the industry simply does not care enough to execute it correctly.
#55
a) no, the SL7 has a threaded BB at all levels
Anyway, contacted today by LBS and seems I am due for a frame replacement.
#56
I ran a Wheels Manufacturing BB30OUT BB30 outer to Shimano 24mm inner BB that threads two sides together in the middle. So it wouldn't deter me if that was an option on the bike. But probably would probably avoid some of the wider press fit standards where that isn't an option.
Likes For avalanche00:
#58
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
I’ve only been riding for 10 years, but in those ten years I’ve only had bikes with pressfit bottom brackets. Only one ever even made a peep, and that was an aluminum Felt with BB-30. My Cervelo has been flawless, despite what Hambini may say.
I don’t care about the BB standard because I’m not going to change the bearings myself if needed anyway.
#59
Quoted: 426 Post(s)
Liked 274 Times
How many people have bottom bracket issues with bikes built before 2019?
I have bought three brand new bikes since march 2020. Maybe it was just bad luck or I bought a bike at the peak of the shortage and bike mfg was not doing the QA that they used to do.
cannondale systemsix aero road bike : no problem
cannondale topstone gravel bike : bottom bracket and crank set replaced
giant revolt adv 2 gravel bike : bottom bracket replaced
Maybe because I rode the gravel bikes a lot harder they had issues that the road bike never did.
My next bike will have a threaded bottom bracket. I torn between upgrading my Giant with a Hambini bottom bracket which should resolve any future issues or sell my bike and buy a ibis or stigmata gravel bike which both have threaded bottom brackets and are a tad lighter.
#60
Fat n slow
Liked 2,085 Times
Likes For phrantic09:
#61
Liked 2,979 Times
The more often I rode in areas that contained a lot more dirt covered areas/construction activity the more I found myself servicing the BB. Which then got me thinking about the what ifs... What if the BB used a set of needle bearings on each side rather than ball bearings?
-Oh Hey!
-Oh Hey!
#62
Dead but dreaming
Location: Bay Area, CA (East Bay - Contra Costa County)
Bikes: 2020 Santa Cruz Stigmata, 2022 Cannondale Synapse
Quoted: 171 Post(s)
Liked 326 Times
I just got a 2022 Cannondale Synapse (not delivered yet) and part of my decision to get it was because they moved back to threaded bottom brackets.
Likes For KJ43:
#63
Quoted: 2976 Post(s)
Liked 1,182 Times
2015 Giant Road Bike with PFBB......constant BB issue with that bike...Wheels manufacturing didn't make a fix for this model
2016 Cannondale Bad Habit with PF...constant BB issue with that bike...Wheels manufacturing didn't make a fix for this model
2016 Niner Air9 with PF BB...constant issue with creaking...Fixed with Wheels Manufacturing thread together cups.
2018 Specialized Fatboy Carbon with PF BB...One issue with creaking a few months after ownership...covered under warranty and so far hasn't been a problem.
I still own the 2016 Niner and the 2018 Fatboy Carbon. Sold the others. The rest of the bikes in my household...Trek road bikes, FS Spot mountain bike, Specialized Sirrus, Kona Woo Fat bike...all threaded BB...Zero issues.
Likes For prj71:
#64
I'm new to this game, but I've wrenched my own motorcycles for years and I only know about press fit bearings... if they fail you bang them out and press the new ones back in. If they go into a threaded housing once you've undone it don't you still need to bang them out? Or does the threaded cap somehow take up the slack? That seems sketchy... I guess I'd better do some research as I think I've got pressed on my new Madone...
#65
Liked 1,182 Times
If you have a newer Madone you have a threaded T47 bottom bracket.
https://www.trekbikes.com/us/en_US/e...cket/p/593089/
#66
Liked 1,182 Times
Weird because my 2021 Domane is threaded. They must have had some frame inventory to work through before switching over the Madone to threaded.
#70
Quoted: 426 Post(s)
Liked 274 Times
Metal bikes, steal, alloy, Ti they can machine or drill perfect circles and in alignment with each other. So no issues or very little issues with those bikes.
#72
Liked 1,182 Times
I used to be an auto mechanic and know what you mean. Never had issues with pressed in bearings. From what I have read and watched on youtube it's mostly the carbon frames. They can't make the holes the perfect size and aligned perfect with both sides. It causes some bottom brackets to not fit perfect and then over time creak when you apply power.
Going forward I will never own a PF BB again and I'm glad to see the major players slowly switching back to threaded.
#74
Liked 1,182 Times
Problem with that video is he is trying to say that PF BB is the same thing as head set bearings, wheel bearings, and suspension bearings. He couldn't be more wrong since those bearings are not subjected to the same forces, loads and rotations as BB bearings. The BB is the bearing assembly that allows your cranks to spin (a lot) and withstand loads and abuse regularly. Think about all of those times you get off the saddle to hammer down while cranking up a hill or to get some more speed...that's a lot of radial loading on the system. There is also a lot of side forces applied to the BB bearings from jumps, drops or riding rocks and roots. Then there is all the moisture, mud, dirt, or grime that you ride through that the BB is subjected to. Headset bearings, wheel bearings and suspension bearings live an easy life compared to the BB bearings. Head set bearings and suspension bearings don't continually spin either....they rotate on an arc an average 90-120 degrees..maybe a little more on the suspension bearings depending on design. Also head set bearings are only subject to axial loads not radial loads. And even though hub bearings spin a lot, the loading is more uniform.
#75
Ultimately, if threaded bottom brackets is important to someone when buying a bike more power to them.
