Crushed Campy dropout: How would you fix it?
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
From the picture, it appears to be a Campagnolo 1010B dropout, post portacatena drilling, so probably early 80s. These are forged, mild steel dropouts and should be amenable careful bending. The chrome plating may well crack with this, but not necessarily the underlying steel.
I'd say go ahead with bending it back into shape. You're no worse off if it does crack, as the other alternative is already dropout replacement. But as I mentioned, a crack in the chrome does not necessarily mean a crack in the steel, so if you see a crack, pick off the surrounding chrome to visualize the underlying steel.
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Is it forged or is it microfusion? I can't tell from here. Old long ones as in gugie's photo are never a problem. Some of the real old ones are not even forged, they're just chromoly and you can do anything to them. Microfusion is gonna crack. Try it and see. If it cracks it was gonna crack and no subtleties of technique would have made the least difference.
Quoted: 5 Post(s)
As it was bent from pressure on the derailleur I would bolt a chunk of steel in it's place and lever on that- I worked in autobody repair and we always tried to reverse the dents as done
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
Waiting for post-pix
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
This. I'd prefer hard maple blocks on a woodworkers vise just because I have them. I think the dropout adjuster screws should be in place.
Likes For clubman:
Quoted: 3241 Post(s)
Liked 2,512 Times
What about a ball joint/tie rod fork? That seems like a good tool for the job.
If this doesn't end well, i.e. two pieces, the hanger could still be useful to someone for a repair.
Disraeli Gears
I would not feel safe riding on that dropout, period. Where it's bent is the weakest portion, with the least metal: the turnaround with the adjuster hole through it. A bend like that has surely exceeded the elastic limit of the material, and it seems to me that the steel must be partially fractured, even if it looks OK.
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,000 Times
If you are worried about a crack after you straighten it, have it magnafluxed, could be relatively cheap at just about any great motor machine shop.
Quoted: 413 Post(s)
Liked 109 Times
Pictures are out of order but....
A. Owner used a variation of the 2 axle technique to open dropout. RD hanger bolt was threaded in and tightened. Its hollow allowing for a screw driver to be passed through. From there it was simply applying even pressure on both sides to open it a bit.
B. The owners with suggested a lead pipe for the final opening. Diameter was big enough to fit over entire lower section. Because it was lead, a sifter material, there was no worry that it'd mar up the drop out. A little leverage on long pipe is all it took
C. I've zoomed in on close up pics (not posted) and I think its OK. There appears to be crack but its not, its metal deformation from when it was compressed then stretched back.
2-Wheeled Fool
Liked 677 Times
Looks like just the chrome is cracked a little. Tap it with a small wrench. Does it make a "ting" or a dull sound like a tunk?
Likes For J.Higgins:
Quoted: 413 Post(s)
Liked 109 Times
Haha...wish I could take the credit. A lot of it came directly from this thread, I was just an intermediary as the frames 1,000 miles away. I really like the '2 axle technique'. As a side note, the seller bailed and said, 'tough luck'. The shippers insurance said, "tough luck, poor packaging". Paypal came through with the requested partial refund, the buyer filed an "item as not described" claim. In the end it work out ok.
low end rider
Bikes: 80's. hoarder.
Quoted: 56 Post(s)
Liked 43 Times
So does it ting or what?
I've found cracks in dishware that way.. couldn't see them easily, but that dull thud is a giveaway.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
Quoted: 3464 Post(s)
Liked 2,831 Times
Painter stated he had never seen a frame packed so well.
returned 26 weeks later (est was 12 weeks) not my packaging, dropout partly closed up...
So it goes.
Liked 4,396 Times
I sent a frame for repaint, made custom wood fillers to fill the whole slot with lands to keep the width dimension, same with the fork, special reusable packing... With instruction to make an easy repeat.
So it goes.
So it goes.
-Kurt
Liked 2,512 Times
So it goes.
So it goes.
Quoted: 1609 Post(s)
Liked 2,216 Times
It appears to me that the lower portion of the DO performs two functions. First is the location and mounting of the RD. Second is a surface for clamping. The upper part of the DO supports the weight of the bike and rider and where all the forces are applied, not the lower half. So how robust does it really need to be?
Quoted: 413 Post(s)
Liked 109 Times
Likes For miamijim:
