Vintage handlebars - drops too short
Old 04-20-22, 11:21 AM
smd4
Quoted: 3514 Post(s)
Liked 2,927 Times in 1,776 Posts
Originally Posted by shoota
If you set up bars/levers with the ramp in mind then you wind up with what the OP has. Nothing wrong with that per se, but it can create other issues, as we see here.
If I can trust a straightedge placed up to my monitor under the bottom of the drops and under the tips of the levers on photo 2, he has his levers set up correctly for vintage drop bars. The issue is the rotation of the bars--which is apparently comfortable to the OP.
smd4 is offline
Old 04-20-22, 11:31 AM
shoota
shoota's Avatar
Quoted: 1873 Post(s)
Liked 692 Times in 468 Posts
Yeah that could be possible, hard to tell without a straight on side shot.
2019 Salsa Warbird
shoota is offline
Old 04-20-22, 11:32 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Maybe you could install bar-end shifters to give you a little more length... the opposite of the chopping some folks do when bar-ends make the ends of the bars too long.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 04-20-22, 12:07 PM
GamblerGORD53
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 324 Times in 249 Posts
I have to say +1 to chucking the whole bike. Looks suicidal IMO. The extensions linked above have a very negative review and I can see why.
I have DIY made extensions myself with 7/8" alu bar and a lot of time without a proper lathe or drill press. They did turn out perfectly workable with 70s plastic grips that I love.
But I really don't see how they would work with bar tape. I've never used tape or drops on any bike.
GamblerGORD53 is offline
Old 04-20-22, 12:22 PM
The Golden Boy
Extraordinary Magnitude
The Golden Boy's Avatar
Quoted: 2608 Post(s)
Liked 1,703 Times in 937 Posts
Cool bike!!
I’m a fan of this generation of Trek 400 Elance. Butted 531 main frame and CrMo stays and fork- perfect bike to upgrade.
Add me to the “put the bars you want on there” queue.
Commence to jigglin’ huh?!?!
The Golden Boy is offline
Likes For The Golden Boy:
Old 04-21-22, 06:34 AM
Jeff Neese
Quoted: 1083 Post(s)
Liked 687 Times in 441 Posts
Originally Posted by mstateglfr
Shoota nailed it- rotate your bars downward. The brake levers are at a really high angle right now and also effectively high up on the bars. Those bars were not designed to have the ramps be flat, they were designed to have the ramps angle down at 12deg or so. Rotating the bars down will effectively push the drop ends towards you and give you more room on the drops. Also, your wrist angle wont be wonky when it the drops and reaching for the brake levers if you rotate the bars down.
I can certainly play with the angle a little. It doesn't feel like that will help much - it just seems they're too short. Like I said, maybe I just got used to having bar end shifters on my other bikes. The Nitto Randonneurs have a shape that's more conducive to horizontal ramps and also longer drops, so maybe next winter I'll swap them.
Jeff Neese is offline
Old 04-21-22, 08:10 AM
Pompiere
Pompiere's Avatar
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,007 Times in 516 Posts
Originally Posted by SJX426
Very nice-looking bike!
However, it looks too small a frame with the extended post and stem. Do you like the short reach?
I recently swapped bars from the Cinelli 64 to a more ergo style. I don't like the current set up and may return to the Cinelli.
Wrapping and unwrapping tape with Ergos is significant and is to be avoided. I reused my tape, and it looks bad which is motivation to change the tape and bars.
Running a heat gun on low setting over the tape lets it relax and return to near its original flatness. I am constantly fiddling with my bikes, so that helps save buying new tape every time I change the bars.
Pompiere is offline
Likes For Pompiere:
Old 04-21-22, 08:51 AM
Gary12000
Bikes: '71 Raleigh Inter, '98 Tommasini, '83 Trek 500, 83 Trek 720 '
Quoted: 118 Post(s)
Liked 199 Times in 110 Posts
When i had just put new tape on, within a couple weeks i realized i needed to make a change that meant un-taping.... i did just one side, and then used a little sliver of 3M double sided tape every few inches
rode those bars and tape for about a year and then put the bike in the rotation for occasional rides, the tape is still on there, riding a smaller bike than you normally ride can be quite comfy if you can get the ergonomics set up.
its all part of the process and its fun.. except re-taping that aint fun...lol
Gary12000 is offline
Old 04-21-22, 09:32 AM
Feldman
Quoted: 117 Post(s)
Liked 71 Times in 51 Posts
Originally Posted by rccardr
Two words: Nitto Noodles.
Or Nitto 176's.
Feldman is offline
Old 04-21-22, 10:00 AM
Jeff Neese
Originally Posted by Feldman
Or Nitto 176's.
I use Nitto 135s on two of my other bikes and I really like those.
Old 04-21-22, 11:24 AM
Classtime
Classtime's Avatar
Quoted: 1952 Post(s)
Liked 2,013 Times in 1,112 Posts
My MB GJ came with some MB branded bars with short flats and as much as I wanted to use the OG bars and stem, I could not get used to it. I am commuting on that bike and do not want to ride 160 miles a week with bars too short in the drops. When I drop down into them, I end up with a three finger grip. (my drops are parallel with the ground).
Classtime is offline
